Hello sir, I'm currently in the market scouting for a new set of tires rin. I'm looking at 265 size instead of the stock na 245. There are a lot of brands out there but I would suggest narrowing it down to type of tires first ( h/t or a/t or m/t ) for highway/city driving or mild off roading or off road respectively. From there you can narrow it down to the size, personally I would suggest 265 size instead of the stock na 245. Yes mas mabigat ng konti Po ito compared to stock but it shouldn't affect performance that much. Budget for tires can be from around 6 k up pero if you go for branded tires Medyo dapat around 8-10 k each ang budget mo po. Aside from bridgestone, I like Yokohama, michelin, Pirelli, Mickey thompson. Some of my friends also suggested federal and nankang Kung medyo budget conscious. Kung may budget naman po then Nitto tires but i find it a bit too pricey na po. Good luck in finding the right tire Sir.
10mm diff sa rear left vs ryt.. tpos 3mm sa harap, xmpre mas mbaba daw ung left sja kc andun ung lhat ng load, at ito pa ang cnabi, kc daw ung mga sa japan manufactured e designed sa slope ng kalsada sa japan..di ko alam kung maniniwala ako o hndi dun sa mekaniko. from the start alam ko nmn na di tlga xa even, gusto ko lang mlaman kung pasok xa sa limit/tolerance.
![Google Play 2010 Mitsubishi Strada [continued 2]](https://play.google.com/intl/en_us/badges/images/generic/en_badge_web_generic.png)
