Results 771 to 780 of 1411
March 30th, 2019 10:40 AM #771
Metal is fine. You won't be bothered w/ wood borers. You can budget-insulate w/ fire-rated polystyrene of the stud thickness stuffed between wall panels. Just prep areas where you might wanna hang or attach heavy items. If you need to randomly hang light frames, check for the proper drywall anchors like those in pic for your desired application. You could space your vertical studs 16"oc instead of 24", should you want sturdy, sir.
March 30th, 2019 01:30 PM #772
Thanks Sir Travs, is 16" already the perfect balance in terms of economy and strength?
Sent from my Mi A1 using Tapatalk
March 30th, 2019 01:42 PM #773
Yeah...drywalls are commonly 48" wide. 16" would give you studs at 3rd of width....way sturdier than half w/c 24"oc gives.
You may keep the horizontals 8' apart(board height) or half that. Sample a panel to get the feel of stability you're ok with.
March 30th, 2019 03:21 PM #775
Sir Travs, do you have better alternatives in mind? I also saw at Philconstruct, a lightweight board made of mixed polystyrene and cement and another, a polystyrene board with welded wire mesh at both sides for plaster, any comment on these two? Thanks [emoji4]
March 30th, 2019 03:35 PM #776
Yeah, alternative boards & 3D panels(EVG is the popular brand) have their advantages. The latter is locally licensed by Eastern Wire Mfg, Inc. It's pretty simple & doable. Great if you've shotcrete. It'll be lighter but harder to break than your traditional CHB. Compare costs & manpower load/skill requirements. Discussions on these will be lengthy & boring.[emoji4]
Read up on the system instead? Call will be yours.
EVG – Hersteller fur Schweissanlagen, Drahtrichtmaschinen, Kaltwalzanlagen, Betonstahl-/ Betonfertigteile-Anlagen
March 30th, 2019 03:55 PM #777
Nice! I'll try to explore this 3D panel, thanks Sir Travs!
March 30th, 2019 04:11 PM #778
- Nov 2017
- 1,748
March 31st, 2019 01:32 PM #780
Maganda nga yan Sir Max if one has the equipment, sakin mano mano lang, division lang naman ng rooms sa 2F
I need to buy new tires. Why can't I find Michelin PS4 anymore? What they are offering is the...
Finding the Best Tire for You
