Results 741 to 750 of 1411
February 20th, 2019 01:08 PM #741
Sariling sikap kasi ito Sir Max, so mga taga rito sa amin na mga old school workers ang gamit ko, my mistake was to trust that they knew what they were doing, hindi pala man lang tinignan ung plano so may mga dowel where they were not needed and none where they should be. Ngayon nakatutok na ako. Neighbor ko kasi ang aking consultant and kung maswertehan lang na available sya. So no need to worry pala ako na the dowel exposed to soil will rust enough to creep inside my post and eat my column reinforcements. [emoji26]
Sent from my Mi A1 using Tapatalk
- Nov 2017
- 1,748
February 20th, 2019 02:08 PM #742No worry sir kung sa dowel lang concern mo. Mas nakakaworry kung yung footing rebars mo hindi nila inangat ng 75mm (3") sa lupa. I seen footing rebars naiwan sa ilalim at binuhusan sa ibabaw [emoji16] dun sa isang project ko na mat foundation. Hinukay namin mga 4 meters depth sa adjacent bldg with proper shoring support naman.
February 20th, 2019 02:13 PM #743
Thanks Sir Max, Yung footing ko I made sure we placed 3" spacers, which reminds me na dapat pala ma check ko if I still have spacers, baka short cut nila at pakyaw kasi 🤨
- Nov 2017
- 1,748
February 20th, 2019 02:53 PM #744
February 20th, 2019 03:05 PM #745
Yes sir, meron din ako luma na 1/2" pvc, i-secure ko na lang horizontally with tie wire for my 2F slab spacers
- Nov 2017
- 1,748
February 20th, 2019 08:39 PM #746
February 20th, 2019 08:41 PM #747
Saan sir nakakabili? Nakita ko sa olx pero por sako ang bentahan
- Nov 2017
- 1,748
February 20th, 2019 08:43 PM #748
February 20th, 2019 08:46 PM #749
Salamat sa guidance Sir, Kung Wala sa hardware, papagawa na nga lang ako
February 23rd, 2019 09:28 AM #750
Here I am again masters [emoji3] May I hear your opinions regarding pouring the second floor slab in sections? I reckon, we can pour the entire second floor in 6 working days at the most using just a bagger concrete mixer. This is a backup plan if the cost of ready mix will be prohibitive due to subdivision restrictions, mainly big concrete mixer trucks and pump crete are no longer allowed. That leaves me with small trucks and probably a hose requiring additional labor on my part. I've done the math and there is a safe 20% savings on manual pouring. But how are the pouring sections divided? Or where should I "splice"? Thanks
Kung walang spare tire, invest on a Inflator kaysa sa sealant. Inflate the flat tire +10 psi than...
Liquid tire sealant
