Results 811 to 820 of 1411
- Mar 2021
- 636
April 18th, 2021 02:20 PM #1
April 18th, 2021 05:08 PM #2
Shingles poor in the tropics? Where did you hear that, sir? They don't corrode & when installed to factory specs, they hold the factory material warranty assigned to that particular variant, 20/30/50years....
I've seen metal roofs suffer way more typhoon damage than properly applied asphalt shingles. These are the reasons why top tropical resorts specify them.
Again, key here is to strictly follow the minimum roof slope, the proper underlay material & thickness, the proper moisture barrier, & the correct proportion of ridge ventilation. Improper install, cost/short-cutting may have given this type of roofing the false negative impression.
Amongst the available notable brands we've tried, IKO from North America has been the most consistent. Guess, them being the lone vertical roofing & waterproofing conglomerate got its pluses. Even IKO's granules are produced in-house. Owens & Certainteed outsource their raw materials from 3M & other companies. Some of their lines come from different plants, too. Consistency of batches over time come into play when the roofing will require sectional repairs or overlay.
Where metal roofs have the advantage over shingles? The latter requires a high minimum slope of 15°. Shingles can't do flat roofs. And, where you have a secondary & lower shingled roof, avoid it used as a relay to heavy water volume from roof valleys above them to avoid visible wear patches long term. Those said valleys above lower roofs, we normally apply selective sectional welded stainless gutters.
Roofing material choice(shingles/tiles/metal) is usually dictated by application, design intention & cost. When properly done, all these can perform to expectations.
April 18th, 2021 02:07 PM #3
Yes Sir CVT, in fact, may lower roof ako sa likod, hindi naman kita sa kalsada, pero shingles pa rin, sa gate pa lang di na makakalusot ang long span. Ung kulay ang malupit, kasi the only color my wife likes is the same as our neighbors, yun lang ang di nasunod sa gusto nya [emoji38]
Sent from my Mi A1 using Tsikot Forums mobile app
- 54,293
- Jun 2015
- 2,751
May 23rd, 2021 05:14 PM #5Yung pang waterproof ba ng swimming pool ok ipang waterproof sa firewall? And what's it called?
May nakausap kasi ako regarding sa pagpapa-waterproof ng isang firewall namin. He recommended something that's supposedly used for swimming pools. Costs 5k per 4-gallon bucket but he couldn't remember what it's called.
Sent from my Nokia 6.1 using Tsikot Forums mobile app
May 23rd, 2021 05:31 PM #6
Check w/ Sika, they've a number of options. Crack Isolation Membrane(viscous liquid form), & Cementitious waterproofing among them. Unlike pool conditions where concrete won't be dehydrated nor be subjected to constant significant thermal fluctualtions due to them holding water, firewalls will require periodic attention/reapplication.
Should you want a permanent solution where possible, go for longspan prepainted roof sheets installed vertically onto your firewall. Make sure to overlay a good flashing layer to cover the area where the wall meets the roof.
May 24th, 2021 12:18 PM #8
Yup, depends on the look you're after. Opaque Graphicote Glass or Aluminum Cladding are a couple & are pricier, but INFERIOR to longspan ribbed metal roofing for the application. Why? Those 2 rely on sealants which have lifespans shorter than the material they seal.
If you prefer retaining the look of concrete/masonry, there's a nonDIY system...EIFS. Pleko, Dryvit, Parex, LaHabra are some of the brands.
May 24th, 2021 12:40 PM #10
An advantage of using long span for walls is one contractor will do the roof flashing along with the walls and roof. He can also do the waterproofing. Less pointing fingers in case of issues. I believe the long span roof flashing also requires sealants such as Sikasil G8.
But it will look out of place in residential applications. Actually ACP will also look out of place.
What we do for new construction is use an admixture for the plaster such as Sika 1. We also use it for walls without ledges above.
Ongoing problem pa din Pala ito even among euro cars ...
Takata Airbag Problems
