Page 58 of 81 FirstFirst ... 84854555657585960616268 ... LastLast
Results 571 to 580 of 808
    Mar 2004
    #571
    50T was high pre-covid? ... but now materials cost more? ... not sure ... used to be 25T-30T was minimum ...
    On another note ... how much do build and sell usually mark up? ...
    Jan 2016
    #572
    Mine was done at 25k pre COVID. My neighbor was quoted 30k after lockdown but was revised to 35k due to inflation, this is basic finish.
    #573
    Depende pa din sa location ng project.
    Labor in NCR is higher, also with gravel and sand.
    Signature
    Mar 2004
    #574
    Aren't materials more expensive the farther away from NCR you are ... additional shipping cost ...
    #575
    Depends on the material and where you’re located. Cements and wood come from the provinces. Shipping cost for other materials might be negligible. But with labor costing as much as 30-40% of the project, that is significant.
    Signature
    #576
    that's what happened to our house in the province, it's slightly more expensive than Manila.
    #577
    First time ko nakarinig ng ganyan.
    Unless yung workers lahat galing din ng Manila.
    Signature
    Nov 2017
    #578
    Mas cheaper pa din sa province nung nagpagawa ako ng vacation haus late 2020 to 2021, kumuha ako ng separate contractor for the whole roof trusses structure using thicker gauge roofing, significantly cheaper compare sa Manila.
    Solid narra door na custom size na height and width, 6 in total, sobrang mura compare sa Manila.
    #579
    No, province. I meant the materials
    Totoo ba ngayon na ang singil ng electrician per "butas" like outlet or switch? Papalitan kasi yung mga outlet/switch sa bahay namin sa province and he said P300 each e total of 31 yun We haven't had any electrical work done in our house in Manila e yung mga little things yung all around na namin gumagawa
    Jan 2016
    #580
    Yes, per butas but usually that price means he will lay down all the wires, pipes etc. as in full lay out ng electrical system ng under construction na bahay. Pag simple palit lang ng outlet or switch much much less because pwede palitan ang isa in 10 minutes or less. let's say na 15 minutes na, so 4 in 1 hour, in 8 hours, that's 32 outlets. No one's going to pay 9300 kesos for that hehe. I would give it to him for 1000 lahat na. That's generous na given na hindi kailangan electrician ang magpalit nyan. But still better to get an electrician just in case things pop up that only an electrician can solve right away.
House Construction
