Page 21 of 41 FirstFirst ... 1117181920212223242531 ... LastLast
Results 401 to 420 of 809
    Apr 2012
    #401
    Plain render. No materiality yet. Gonna change some windows to make them floor to ceiling. But this is the base look.
    Its a 4 bedroom house with some nice views which i want to take advantage of.
    The property is on a slope so no choice but to build multi level.
    Starting soon. Hopefully! Attachment 42195Attachment 42196Attachment 42197Attachment 42198
    Sent from my SM-G998B using Tsikot Forums mobile app
    Fitnesscape designed?
    Coz the Pena’s penchant of having a carport beneath the pool.
    Mar 2013
    #402
    No. I considered them but they are too busy. They are turning away clients actually.
    The irony is... One of the lots that this house sits in (its on 2 lots) was originally owned by them.
    #403
    Grats, sir. Unsolicited 2cents...Please pay extra care & attention to exposed suspended slab thicknesses(do thicker than designed or necessary); integral waterproofing; your monolithic pour skeds(time/weather); curing; slopes(for surface water drains: opt free-fall or, if you can't, go trenches, never isolated drains); & more surface waterproofing. Choose your outdoor deck & pool materials really well. These will help lessen your periodic upkeep & risk of extensive collateral damage. Water is life but can be 1 of every home's worst enemies... like termites.
    Sent from my SM-S901E using Tsikot Forums mobile app
    Mar 2013
    #404
    These are great tips which we will be watching carefully and discussing with the project managers, construction team and architect.
    Salamat. Im also scared of leaks hehe
    #405
    Watertightness is tricky. Misses can be masked by surface solutions short term, yes, but it's the long term integrity we always wish for.
    Are you planning gutter-free, sir? If not, external fully welded painted stainless gutters are the next most functionally ideal w/ some degree of aesthetic penalty. Those built midstream & hidden above roofbeams almost always are a source of recurring migraines.
    And Odette, she taught new lessons. Many of those w/ tall glass openings on high elevations did not stand a chance. Factor higher wind-load tolerance in, if you can. Stone-coated metal roofs showed their superior wind resistance & worth above other roofing types.
    Apologies for going on & on. I'm definite you got everything covered. Enjoy the journey, good sir.[emoji4][emoji120]
    Mar 2013
    #406
    Thanks bro. Yes good tips. Am also conscious about extreme weather and the potential leaks. The downspouts will definitely be hidden.
    As for the roof will share your advice with our architect as well. We will be putting solar panels and solar heaters (for the pool) on the roof as well.
    The more tips the merrier. Do you know anyone who can supply non standard (i. E. 4m high) glass panels for the doors? Id hate to divide the panels....
    #407
    Look into GAF Solar Shingles.
    Solar roofing for your home | GAF Energy
    Not a fan of placing anything on top of roofing that'll need periodic servicing. Seen countless times how roofs, w/ so much attention put into their installation to ensure longterm dry shelter, get irreversibly damaged by 3rd party(HVAC, Solar, communications, etc) guys who only give a damn about their own tasks....& all you get are apologies.[emoji2957] My OCD dictates me to avoid them like the plague. Haha.
    Mar 2013
    #408
    I need solar hehe. And the solar heating for the pool.
    Otherwise its too expensive to heat the pool.
    #409
    Solar shingles or if you have some spare space, a mini solar farm perhaps?[emoji4]
    Jun 2011
    #410
    Ganyan pala dapat. Stainless nga gutter namin pero rivet + silicon ang joints. Ayun may leaks sa ibang joints. Special welding daw pag stainless tapos hindi basta kakapit ang paint?
    #411
    Quote Originally Posted by bxr monkey View Post
    Riveted SS gutters are only a slight upgrade to regular rust-prone ones. Proper paint type & prep are key. Powdercoat is even an option if short selective sections can fit the oven. The welded & painted SS gutters we've long installed have remained leak/rust/trouble free w/o any signs of peeling. UV & the elements will eventually degrade any finish though.
    Jan 2016
    #412
    Why do you have to weld the gutters? Are the rivets not strong enough? I'm sure it's not because so it won't leak, as it's raining man [emoji12]
    #413
    To rid the reliance on sealants which have limited service life. Welds last & stay watertight. Constant leaks will lead to rot or rust on its mated surfaces like fascia boards( even the ficem type) or metal purlins behind & might eventually affect the eaves & its fasteners. Worse if those gutters are hidden.
    My personal preference? No gutters or just on vital areas esp those concentrated valleys. In place of them are ground trenches to collect the rainfall. Zero maintenance.[emoji4]
    Jun 2011
    #414
    As always, maraming salamat sa inputs.
    Bale huwag lang doon sa mga dadanan ng tao/car. Otherwise basa sa waterfalls. Hehe.
    Doon naman sa rain gutter grill/screen/mesh para hindi mag-collect at bara ng mga dahon... wala yatang ready made available locally, kailangan pa-customize?
    Jan 2016
    #415
    Marami sa Shopee mga gutter filter/strainer, iba ibang klase
    #416
    Lotsa gutter spout strainers online. Unless you opt ųPVC gutters, most are custom fabricated...won't take much to add a protective screen.
    Below is a sample of selective 'seamless' stainless corner gutter catching 2 valleys. No rivets, watertight & straight w/ no fillers. The 2 spouts have not been installed at the time the pic was taken.20220713_215137.jpg
    Jun 2011
    #417
    Oo nga, mayroon pala online. Wala talaga sa mga hardware store na puwede mo makita sukat. May nakapag-install na from online sellers at standard ang width?
    Jun 2011
    #418
    Ayos. Challenge nga itong slope, madaming stairs. Hehe.
    Kung iyong driveway/garage aabot sa likod at ilalim ng pool, okay siguro may railings sa dulo ng back driveway bago umabot sa terraced garden? For safety.
    Iyong water tank sa rooftop, ground level, or underground? Maganda nga may water tank at solar for emergencies.
    Mar 2013
    #419
    No water tank. Malakas tubig dito thankfully. If there is an emergency... Theres always the pool hehe.
    But yes Solar and solar water heating on the roof tops.
    Nov 2017
    #420
    When I renovated my house more than 10 yrs ago, i have added an overhead tank good for 2 days use.
    Very useful especially pag may water shortage or may typhoon.
House Construction
