Results 451 to 460 of 908
July 21st, 2014 11:45 PM #452
July 21st, 2014 11:51 PM #453
these past few days nun nag brown out ang sinubukan kung gamitin na genset to test the efficiency is yung 6.2kva na gasoline genset.. the nine liters of gasoline lasted for 6 hours hangang tumirik... or 1.5li per hour.. if compute natin for 24hours... nasa Php 1872 per day.. using a 6.2kva genset
sa estimate ko yung 2.5kw namin or 3.2kva would consume less than 1 liter per hour of gasoline...
July 21st, 2014 11:59 PM #455
*Uls
Yup. Maliit lang nga yung mga nakita ko nung nag canvass ako last saturday sa raon. The prices are around 42K - 48k with brands like Yamada, Yamma, Firefly etc. Grabe dami ng bumibili nung generator last saturday, akala mo siopao lang yung binibili sa sobrang dami ng tao. Hirap mag canvass dahil di ka mapapansin nung mga salesman.
Canvass ulit ako bukas, binondo naman. Tingin ko konti na lang tao nun dahil may mga pasok yung iba unlike weekends.
Other than gensets, ano pa business nyo? I'm also looking for crane rentals.
I may be stupid, but I am not a fool.
- Jul 2004
- 241
July 22nd, 2014 12:15 AM #457Glenn - thanks pre pero as per yung Elemax 7600 (6.5kva), it has a capacity of 28 liters but would only run a max of 7.2hrs as indicated sa spec sheet nya. That gives a costing of P5,133/day. I'm not sure bat mas matipid yung 6.2kva generator mo. I am only basing all these from spec sheet. I get the number of fuel tank capacity of the unit then get the max no. of hours the generator would run. It came out na pinaka ok yung Diesel elemax SH07D then the elemax SH3200 (P1,870/day).
uls - pre you really think that would cost more than 100k? dang if that's the case I think i would just get the elemax SH3200 (around P45,000) or the honda EP2500CX (around P36,900)
Thanks
July 22nd, 2014 12:31 AM #458
ganun din po sir.. pati doorlocks pwede mo din palitan ng magandang klase po... yung insulation foam naman dalawang klase po yan yung isa 2" FOAM lang po.. yung isa maliban sa 2"foam nilalagyan din ng rock wool (selected areas only)
nag pasok na kami dati ng genset na parang pinto ng kotse kung sumara... meron pang shock yung mga pinto to assist sa closing and opening ng doors...
and if the doors dont close tightly... alignment lang po yan...
July 22nd, 2014 12:38 AM #459
- Jul 2004
- 241
July 22nd, 2014 12:44 AM #460*Glenn = Elemax SH7600 and SH3200 are made in Japan. Elemax uses Honda engines. Complete line-up, pics and specs can be found here: ELEMAX GENERATOR JAPAN: EX Series - Products Line up
Honda EP2500CX not sure but I think made/assembled in China already pero I think Japan pa din yung parts. Their specs/pictures/SRP price can be seen here: http://www.hondaph.com/view/power-pr...wer-generators
Note: Honda Philippines recognizes the Honda generators such as the EP2500CX and they will honor the warranty. As far as I know, they will not, however, honor the warranty of the Honda engine placed in the Elemax generator.
A 70/30 water to coolant mix may improve cooling efficiency but that's at the cost of less...
Coolant...
