In my experience with gasoline gensets, its better to leave the fuel than drain the reservoir. Those jets gets clogged more easily when air interacts the metal turning into surface corrosion. If fuel is still in the carb, bottom parts are insulated from air thus there's less tendency to corrode. Just like any engines, warm it up every month or week (if possible) to lubricate/insulate the internal parts. If neglected for long period of time, drain the stale fuel from the reservoir, replace gear oil, clean air filter before trying to start. Check readiness of genset if power outage is anticipated like Typhoons/ rotational brownouts. I also stock spare spark plugs and fuel hose because they are the consumable parts that usually break.
Yep display ito sa ace last time i went there..
Sent from my SM-N970F using Tsikot Forums mobile app
Can anyone recommend a reputable store in Raon/Evangelista?
Saan pa ba maraming portable gensets, or is this it?
I thought I made a mistake!!! I kept on saying that I think it's too much. Thank you for confirming.
Any idea where to buy a cheap one? I'm contemplating for diesel, silent type. It might be too expensive for something I won't be using regularly.
Any idea which one is easier to maintain, gasoline or diesel?
