Results 551 to 560 of 885
July 26th, 2014 12:06 AM #552
July 26th, 2014 12:19 AM #553
brownout tapos low batt ang mga gadget? bad trip
bili na kasi ng genset
- Nov 2009
- 3,484
July 26th, 2014 12:47 AM #554Hundt & Weber ang orig motorized 220V 250A, supplier quoted me for SquareD contactor-type P30k plus 40k with install/warrantey.
Perkins has Telemecanique, i dunno the price never failed yet.
Maganda sana Telemecanique kaso under Sheinder Electric narin parang SquareD. Cant find Ferraz Shawmut supplier.
BTW the ATS i made is just for my room, in lieu of MTS na nasa cupboard
- Jul 2004
- 240
July 26th, 2014 12:33 PM #555Mga pre, where do you place your gensets sa bahay? Ive been reading on carbon monoxide poisoning kasi so pinag iisipan ko ngayon kung saan ang best place to put my genset. Maliit lang kasi yung house and wala naman kaming garden space or such. Pinagawan nyo ba ng housing yung genset nyo tapos nilagyan nyo ng exhaust fan with a tube going up ? Yun kasi iniisip ko para ibuga yung carbon monoxide pataas...
Any suggestions?
July 26th, 2014 12:44 PM #556
July 26th, 2014 03:12 PM #557
Sa amin sa may veranda sa likod bahay...may bubong at well ventilated.....
July 26th, 2014 06:41 PM #558
Sa akin di pa tapos yung housing ng genset. Panay kasi ulan kaya di ma-assemble yung mga panels supposedly sa open-air terrace. I plan to mount sa side ng housing a small exhaust fan power of which directly from the genset. On the opposite panel a louvre para well ventilated ito. For the genset exhaust, I plan to mount an extension tubing through a hole bore on the housing panel adjacent to the exhaust. The protruding pipe to be attached an elbow turned to point downwards, to prevent rainwater, dust, soot, insects etc. For the power cable, I will also bore a hole with a diameter same like a garden hose since I will be using an old garden hose to insulate the 10amp cables that will run through garage ceiling and finally to utility breakers. If you're short of space, and kung may garage ka at least, pwede mo ilagay doon yung genset. assemble the tubing for the exhaust long enough to provide you clean CO free environment. You can point the tube upwards, pero yung end should be turned somewhat downwards to avoid elements and precipitation. Good luck on your project.
Posted via Tsikot Mobile app on S3LTE
July 26th, 2014 06:52 PM #559
