Page 46 of 46 FirstFirst ... 364243444546
Results 901 to 908 of 908
    Mar 2004
    #901
    The diagram oj88 posted would be the usual setup for generator with solar system ... but have seen some solar inverters have input for generators ...
    #902
    I mean hinde pa pwede hiwalay yun genset lang ang mag supply sa bahay bypass na yun solar? Parang ordinary setup lang na Meralco /genset.
    Pag gamitin genset off yun solar/grid system para genset na lang mag power.
    Yan ang typical setup ng mga non-battery solar system.
    Signature
    Sa mga meron solar sa bahay, ano ba actual efficiency ng solar panel. 20% lang ba talaga?
    #904
    Yan ang sabi, but I don't think measurable ng end user yan? Yung indicated capacity ng panels is already the actual capacity na e
    Signature
    Feb 2014
    #905
    yung rating ng panel is from artificial "lab" conditions at 25 degrees c. which you'll never achieve in the real world
    w/ my old polycrystalline panels i could get at most 75% of the rating on the sticker. monocrystalline should be slightly higher. then there are bifacial that are even higher still if you could somehow reflect light into the back of the panel
    #906
    Quote Originally Posted by Vodka View Post
    13kw ang nakainstall na panels sa akin. bifacial sya. I am able to harvest max of 12kw during the first few months after install. Now 11kw nalang peak. Baka need to clean the panels na.
    Signature
    Nov 2017
    #907
    It could be the hotter weather derating the modules (even more than when it was first installed since the modules power rating is obtained at 25C and 1000W/m2)
    So bale x4 ng KW ng System ang ma harvest sa whole day?
Generator sets
