Results 51 to 60 of 78
- May 2017
- 2,128
March 25th, 2019 10:29 PM #51
haha hindi ako marunong maglinis ng carburetor, plan ko lang kasi palitan na ang buong carburetor set hehe, sa inyo pareng 12vdc, how do you clean the carburetor? Btw, regarding the filter, are you referring to the air filter or the fuel filter?
Salamat for your helpful tips pareng 12vdc!
- Nov 2009
- 3,509
March 25th, 2019 10:41 PM #52^Remove the air filter to reveal the butterfly, the bottom bottle is held by few screws - blast it with brake/carb cleaner. Pwede rin naman palit buo para may spare pero ang usual nasisira jan recoil string, clutch, tank cap, throttle cable. Wala fuel filter, direct sa carb. May mesh filter yta un orig sa ibabaw ng tank.
Pinapalinis ko nalang sa ngayon sa shop na nag hahasa din ng chain saw blades. Sya na kasi farm mech pati ng gaso pump and the Kubotas diesel.
- May 2017
- 2,128
March 25th, 2019 11:27 PM #53
- May 2017
- 2,128
- 54,247
May 18th, 2019 11:20 AM #55
- May 2017
- 2,128
October 15th, 2020 10:30 PM #56Guys may brand new 2-week old Hoyoma TD40 kami. Ok naman siya gamitin, pero this 2nd week of use, kapag pinipindot ang gas, namamatay siya let's say after 1 hour of continuous use. Kapag paaandarin ulit, agad naman siya aandar tapos mamatay siya after 10 minutes of use ulit. Ano kaya problema nito? Baka nasa air to fuel mixture problem ba? Kailangan ko bang pakialaman ang idle screw para maiincrease ang air/fuel ratio?
Ok naman ang engine running in idle mode, hindi naman namamatay. Starting ng grass cutter has no problems, easy to start pa rin. So malamang ok naman ang sparkplug and ang compression naman nito is still good.
Nasa paggamit lang ng grasscutter when our helper is using it in the field after more than 1 hour that's the time namamatay after pindutin ang gas...
Any suggestion or similar experience?
Btw, yung 2T: 50ml to 1 liter ba gamit niyo or mas prefer niyo ang 25ml to 1 liter? Mga 30 ml gamit namin e para iwas magbara ang carburetor...
- Feb 2014
- 2,705
October 15th, 2020 11:35 PM #57meron na bang FI na weed wacker? i hate screwing aroudn w/ carbs
i'd rather suffer through a power outage than to start my generator LOL
i have light duty needs so i just use an 18v. but there are powerful electrics out there
November 1st, 2023 01:47 AM #58
Are the cheap grass cutters at Lazada decent na for a small area of grass (more or less 50 sq m) I just need the area where my fat lab pees and poops to have short grass ALWAYS so I will be the one to cut na lang. Our all around kasi decides when he wants to cut or not
I don't like gas, just electric.
November 1st, 2023 03:17 AM #59
pwede na yung mga cordless grass cutters kung small area. pili ka na lang ng may maraming nabenta at good reviews
- May 2007
- 278
November 1st, 2023 07:01 AM #60Using the below, 2 years na working pa din
https://shopee.ph/product/223360172/...YaArp2EALw_wcB
A 70/30 water to coolant mix may improve cooling efficiency but that's at the cost of less...
Coolant...
