Page 3 of 4 FirstFirst 1234 LastLast
Results 41 to 60 of 78
    #41
    ^Safe naman bro, always wear your bag upfront and yung suotin mo pang divi getup. wag yung pormang prang mag oopisina sa makati.. hehe
    May 2017
    #42
    Maraming salamat for the advice pareng 12vdc!
    May 2017
    #43
    Guys, tanong ko lang ano ibig sabihin ng "lean" as in "lean carburetor adjustment". Does "lean" mean using more fuel so as to stop the engine from dying out?
    #44
    more fuel = running rich
    more air to fuel = running lean
    May 2017
    #45
    Salamat pareng 12vdc! Ngayon gets ko na, kaya pala sabi nila yung piston/ring mabilis na nasisira kapag lean"running lean" kasi yung piston mo hindi sufficiently na rerelubricate ng oil.
    #46
    errr...
    grass cutters or automobiles?
    for grass cutters with two-stroke engine, i suppose so.
    for automobiles,
    i think, it's not really the lubrication, as it is the combustion.
    but what about those electric grass cutters? are they ok for ordinary lawn work?
    May 2017
    #47
    errr...
    for automobiles,
    Dr. D, balik niyo po yung 3 points na binura niyo, malaking tulong din yun and logical too...
    #48
    i decided against it, po.
    "wrong thread".
    but thank you.
    May 2017
    #49
    pareng 12vdc, doon sa TD40 Carburetor, how do you use the idle adjusting screw, kapag namamatay ang brush cutter kapag idle siya, to the left o to the right direction po ba iaadjust ang adjusting screw?
    #50
    ^Parang pakanan idle-up, idont exactly remember. Basta sa idling problem linis carb at filter. Iwasan din yung may stale fuel sa carb kung matagal hindi gagamitin nagkakaroon ng mineral deposits.
    May 2017
    #51
    haha hindi ako marunong maglinis ng carburetor, plan ko lang kasi palitan na ang buong carburetor set hehe, sa inyo pareng 12vdc, how do you clean the carburetor? Btw, regarding the filter, are you referring to the air filter or the fuel filter?
    Salamat for your helpful tips pareng 12vdc!
    #52
    ^Remove the air filter to reveal the butterfly, the bottom bottle is held by few screws - blast it with brake/carb cleaner. Pwede rin naman palit buo para may spare pero ang usual nasisira jan recoil string, clutch, tank cap, throttle cable. Wala fuel filter, direct sa carb. May mesh filter yta un orig sa ibabaw ng tank.
    Pinapalinis ko nalang sa ngayon sa shop na nag hahasa din ng chain saw blades. Sya na kasi farm mech pati ng gaso pump and the Kubotas diesel.
    May 2017
    #53
    Maraming salamat pareng 12vdc, very much appreciated for sharing your valuable experiences!
    May 2017
    #54
    malapit na naman ang rainy season
    #55
    great!
    our grass will grow lush and green again.
    May 2017
    #56
    Guys may brand new 2-week old Hoyoma TD40 kami. Ok naman siya gamitin, pero this 2nd week of use, kapag pinipindot ang gas, namamatay siya let's say after 1 hour of continuous use. Kapag paaandarin ulit, agad naman siya aandar tapos mamatay siya after 10 minutes of use ulit. Ano kaya problema nito? Baka nasa air to fuel mixture problem ba? Kailangan ko bang pakialaman ang idle screw para maiincrease ang air/fuel ratio?
    Ok naman ang engine running in idle mode, hindi naman namamatay. Starting ng grass cutter has no problems, easy to start pa rin. So malamang ok naman ang sparkplug and ang compression naman nito is still good.
    Nasa paggamit lang ng grasscutter when our helper is using it in the field after more than 1 hour that's the time namamatay after pindutin ang gas...
    Any suggestion or similar experience?
    Btw, yung 2T: 50ml to 1 liter ba gamit niyo or mas prefer niyo ang 25ml to 1 liter? Mga 30 ml gamit namin e para iwas magbara ang carburetor...
    Feb 2014
    #57
    meron na bang FI na weed wacker? i hate screwing aroudn w/ carbs i'd rather suffer through a power outage than to start my generator LOL
    i have light duty needs so i just use an 18v. but there are powerful electrics out there
    #58
    Are the cheap grass cutters at Lazada decent na for a small area of grass (more or less 50 sq m) I just need the area where my fat lab pees and poops to have short grass ALWAYS so I will be the one to cut na lang. Our all around kasi decides when he wants to cut or not
    I don't like gas, just electric.
    Apr 2012
    #59
    pwede na yung mga cordless grass cutters kung small area. pili ka na lang ng may maraming nabenta at good reviews
    May 2007
    #60
    Using the below, 2 years na working pa din
    https://shopee.ph/product/223360172/...YaArp2EALw_wcB
Cheap and Good Quality Grass Cutters
