Page 5 of 8 FirstFirst 12345678 LastLast
Results 41 to 50 of 78
    #41
    ^Safe naman bro, always wear your bag upfront and yung suotin mo pang divi getup. wag yung pormang prang mag oopisina sa makati.. hehe
    May 2017
    #42
    Maraming salamat for the advice pareng 12vdc!
    May 2017
    #43
    Guys, tanong ko lang ano ibig sabihin ng "lean" as in "lean carburetor adjustment". Does "lean" mean using more fuel so as to stop the engine from dying out?
    #44
    more fuel = running rich
    more air to fuel = running lean
    May 2017
    #45
    Salamat pareng 12vdc! Ngayon gets ko na, kaya pala sabi nila yung piston/ring mabilis na nasisira kapag lean"running lean" kasi yung piston mo hindi sufficiently na rerelubricate ng oil.
    #46
    errr...
    grass cutters or automobiles?
    for grass cutters with two-stroke engine, i suppose so.
    for automobiles,
    i think, it's not really the lubrication, as it is the combustion.
    but what about those electric grass cutters? are they ok for ordinary lawn work?
    May 2017
    #47
    errr...
    for automobiles,
    Dr. D, balik niyo po yung 3 points na binura niyo, malaking tulong din yun and logical too...
    #48
    i decided against it, po.
    "wrong thread".
    but thank you.
    May 2017
    #49
    pareng 12vdc, doon sa TD40 Carburetor, how do you use the idle adjusting screw, kapag namamatay ang brush cutter kapag idle siya, to the left o to the right direction po ba iaadjust ang adjusting screw?
    #50
    ^Parang pakanan idle-up, idont exactly remember. Basta sa idling problem linis carb at filter. Iwasan din yung may stale fuel sa carb kung matagal hindi gagamitin nagkakaroon ng mineral deposits.
Cheap and Good Quality Grass Cutters
