*KAMBAL: I guess there's something wrong with your suspension - palagay ko sa mulye, baka may naputol. Silipin mo to check it out, or find a suspension specialist kahit iyong mga backyard shops lang. Hindi pwede DIY dito sa palagay ko.
Load plus is only a helper mulye which goes to work kapag mabigat ang load.
Guys, pa ask lang sang auto supply kaya nakakabili ng thermostat pang 4JA1 engine. TIA.
mga sirs, may ngpakabit ba sa inyo ng pnp hid sa crosswind? question lng po, normal ba na mawawala yng indicator sa dashboard na nkbright ang ilaw mo kpg ngphid ka?
*benzmizer and red16: ah...gulat kc ako e. nung bgong kabit kc yng akin umilaw pa yng indicator ng isang beses bago nwala e. salamat ulit mga bossing sa info.
suggest ko magpalit kayo ng assembly ung may projector kasi sabog ung ilaw nakakasilaw sa kasalubong ung mga headlights natin kasi hindi naka design for hid
hi bosing, meron ako xuvi 2003 model, tingin ko sobra makaldag sa likod, kung palagyan ko kaya ng plastic spacer lalambot yung ride nya? compared ko kasi sa sportivo 2009 nung friend ko yung sa akin, talagang iba yung ride nya,,,
p.s. saan kaya pwede magpakabit at how much po kaya aabutin just in case?
T.I.A.
I hate to be the goat to this but it may be true that it is a common practice in tropical countries like the Philippines to remove the thermostat to keep the aux fan running and keep your engine cool, studies show that it isn't entirely "good" doing so.
The thermostat was developed for a purpose.... and it is to keep your engine in it's "ideal" temp as designed. As the saying goes, anything in excess is bad.... and this proves true too that when your engine is not in its designed working temp, fuel efficiency is affected.
I would still suggest that you keep the thermostat as it should be. Just make sure it's in good working order so as it'll give the correct readings and turn the aux fan as needed.
Good day mga sir. Ask ko lang kung normal ba sa crosswind during cold start then switch ON the aircon afterwards ay may delay cya bago gumana? I mean napansin ko kasi pag start ko sa umaga then on ng aircon hindi kaagad nag eengage ung compressor ko.it takes around 3 to 5 mins bago cya mag cut in kahit na taasan pa yung thermostat setting.tnx.
please, i need your help. . . Last thursday, i went to province and left my crosswind at the airport parking. Pagbalik ko ng sunday, ramdam ko na parang ayaw nyang magengage to 4th gear or last gear, hindi naman naka-off OD ko (A/T auto ko). PArang 3k na RPM ko pero nasa 60-70 kph lang takbo ko. . . hanghang kanina tinodo ko rin sa coastal road, ganon pa rin. . .sa subdivision lang, hindi mo ramdam na may problema.
Prior to that, kayang ko 80-90 kph at 2k RPM lang. . . at saka swabe ang takbo. . .ngayon hirap. . .I checked the ATF, ok pa naman level at kulay nya. . .
Eto lang mga kakaibang nangyari prior to thursday. . .nagpadeisel ako sa petron instead of the usual Caltex...
Ano kaya problem ng crosswind ko. . . thanks in advance. .
