Page 57 of 186 FirstFirst ... 74753545556575859606167107157 ... LastLast
Results 1,121 to 1,140 of 3710
    #1121
    hi ask ko lang, paano ba tangalin yung bulb don sa park light? papalitan ko yung sa Left HL ko. try ko kanina ang hirap tangalin eh.
    May 2010
    #1122
    The seatbelts are manufactured by Autoliv (in Laguna?) Just google their address and contact po.
    I think weak point talaga ng Crosswind iyan. Even the units I use have lazy seatbelt retractors.
    thanks sir otep
    #1123
    Quote Originally Posted by Sportiv08 View Post
    im not sure kung pareho tayo ng headlight, sa xuv 2002 kasi pipihitin mo lang yung socket to unlock/pulled from the HL assembly, tapos plug and play na yung peanut bulb
    Jan 2011
    #1124
    Quote Originally Posted by chitobarba1972 View Post
    sa akin paps 2005 XUVi, I'm using Petron Rev X - TREKKER. So far so good
    ako, i'm using mobil delvac mx 15w40, ok b 2?
    Aug 2009
    #1125
    Quote Originally Posted by sportivonidave View Post
    ang pagkaka alam ko babakbakin muna yung naka lagay na undercoat then apply ng epoxy based primer.. then pag natuyo lalagyan na ng epoxy based paint.. yung pag tanggal ng undercoat ang hindi ko sure kung paano.. d2 lang ako sir sa rainbow
    Pwede kayang direct apply na ng epoxy primer? kung masyadong nang manipis ang undercoat pra less work narin? May variant or colors b ang epoxy base paint or isang klase lng? thanks! San sa isang rainbow sir? dami nun dito?
    Jan 2011
    #1126
    Quote Originally Posted by Mac40 View Post
    Lumakas po yung hatak pero nung hindi pa naaayos yung injection pump, malakas ang vibration ng engine. Alam na po nila kung alin ang titingnan base sa usok, tunog ng makina at vibration kung alin may deperensya. Pero just the same, palinis na rin po ung nozzles para sigurado. Pero hindi ko sure na yan ang dahilan kung bakit humina ang hatak ng car nyo, marami pong factors ang nagcocontribute kung bakit nagkakaganyan ang ibang sasakyan. Mas maige po kung pa-check nyo sa magaling na mekaniko ang car nyo.
    Mga boys alam nyo ba kung san sa q.c or caloocan may reputable na ngseservice ng injection pump ng isuzu xwind ntin? natry ko kc sa Bosch sevice center sa tapat capitol med, sbi nila 10k dw... parang mhal ata un.. any info? thanks much!
    Feb 2010
    #1127
    Quote Originally Posted by jayghost213 View Post
    I just don't know kung magkano sa Diesel Central located at Q. Ave.. baka maraming need palitan bro kaya umabot ng 10K... try mo sa Diesel Central, nandyan ang ka-tsikot natin na si 4jgtootsie aka "Ramon"
    Feb 2005
    #1128
    Try ATI din kaso not sure if there is within your area.
    Nov 2007
    #1129
    dito sa pasay or makati san ba mura and ok magpacheck ng injection pump?
    Mar 2011
    #1130
    Sa tingin ko bro mahal na yun sa 10K yung sakin kasi inabot lang ng 5K kasama na tip dun sa mechanic, ang sabi nya ang madalas lang masira sa injection pump ng isuzu x-wind natin ay yung delivery valve w/c costs P750.00 each or a total of 3K, plus yung repair kit na 1.2K, camshaft oil seal * P120.00 and labor *P550.00 plus tip na P130.00. Nung nagtanong ako sa cas sa Isuzu Gencars ang quote sakin dun 13K, grabe kamahal so naghanap na lang ako ng magaling na calibration shop dito samin sa Bicol, mura lang pero magaling magtrabaho.
    #1131
    Quote Originally Posted by red16 View Post
    I think kailangan mong bakbakin undercoat if may suspect ka na medyo may kalawang na underneath nito kasi ang epoxy primer ay nilalagay sa metal to protect it from rusts.... Magiging useless naman epoxy primer mo if sa babaw nang undercoat mo ilalagay.... Ako I'm using "Guilder" epoxy primer gray and "Para-Lux Epoxy Primer Gray EP-1500"... Meron ding yellow and red(Not sure) but gray ni re-recommend palagi....
    If may kalawang na and tinatamad kang mag kiskis, pwede mo rin lagyan muna nang "Rust Converter" and wait for few hours... Makikita mong unti-unting mawawala ang kalawang at kung may matira man, kunti nalng.... Just follow procedures sa label nang rust converter on how to use it and please be careful on handling it kasi mainit sa balat pag kumapit....
    #1132
    Nang inacquire ko XUVi last year, meron nang nakalagay na tulad nito:
    [SIZE=4]"SFVR"[/SIZE] ang nakalagay sa label......!!
    An Anti-Pollution, Fuel Saver-Engine Preserver device for all kinds of cars, gasoline-fed or diesel-fed combustion engines..... Merong nakalagay na adjustments na iniikot on how to minimize fuel consumption and so far under normal speed sa hi-way going city and our town(Speed from 80 - 100km/hr) nasa 16:1 liter ang ratio over distance and fuel.....
    Maganda ang acceleration and I could reach 120 to 130 km/hr(at may ibubuga pa) considering wala kaming NLEX o SLEX o ano mang super hi-way dito kaya din rin gaanong maka accelerate into higher speed..... Natatakot lang akong magpa bilis nang masyado kasi nga ang tinatahak ko na daan dito ay 2 lanes lang, maraming intersections at ang iba ay populated pa kaya di ko pa na try isagad.....
    May 2010
    #1133
    dito lang kame sa rainbow ph.1 pagbaba ng vicas.. sa likod lang namin ang magdalena .. tama si isr phyro kung pano ilagay ang epoxy based na primer sa under chassis.. matrabaho lang talaga
    Aug 2009
    #1134
    Quote Originally Posted by zalphyro View Post
    Ako I'm using "Guilder" epoxy primer gray and "Para-Lux Epoxy Primer Gray EP-1500"... * Sir. "Confuse" Any sa 2 binigay nyo pwede or sabay kung gamitin? hehehe.... No need na base paint?! O isa lng!? & also sir can you give me a exact brand name ng "rust converter"? How much? Kiskis to the max sa kalawang ng Steel brush? (Gamit kulang "brush" paint ba sir or air compressor?) Pcencya na 1st time ko lng gagawin ito. Thanks! Nice device sir! Mine... HOB (Hydro octane booster)
    Aug 2009
    #1135
    Magkatalikuran lang pala tayo Sir dave ng Village,V.M.3 ako....... Kung dika Busy sir any day.... kita kits tayo!? Para masilip kurin yung auto nyong nalagyan ng under coat. Kung Ok's lng sir!
    #1136
    Sorry if i made you confused.... Dapat pala "or" ginamit ko instead hehehe.... Isa lang gamitin mo and no need na base paint kasi 'yun mismo ang epoxy primer ang gagamitin as base paint.... You need to add thinner or reducer but I recommend acrylic thinner(Any brand will do kahit mura pa) kasi madaling matuyo and mas maganda ang result lalo na pag gagamit ka nang compressor and a spary gun..
    What you need:
    - Epoxy primer w/ hardener(kasama na 'to for free)
    - Epoxy reducer or Acrylic thinner(recommended para madaling matuyo)
    - Paint brush ok na din kasi sa ilalim lang naman ang pipinturahan mo but an advantage
    if you have a compressor kaya lang mahirap if wala kang ramp hehehe...
    Optional:
    - Spray Gun (if may compressor)
    - pang kiskis
    - rough sandpaper
    Eto additional steps on how to apply "Epoxy Primer":
    The surface to be painted has to be properly free of rust,grease,water,etc.The epoxy primer has to be mixed thoroughly and then mixed with hardener in 4:1 ratio. If paint brush lang gagamitin 15% to 20% pwede na i mixed with epoxy thinner/reducer but If gagamit nang "Spray Gun" 25%--30% Epoxy Thinner has to be mixed with the mixture and stirred properly before spraying.
    Pasensya na kasi nalimutan ko kung anong brand ang ginamit ko na rust converter pero madaling mahanap yan sa kahit maliliit na hardware store meron ganyan at napakamura pa... Maliit na nasa 500ml na bote lang ang binibili ko palagi...
    Eto nga pala sample video(youtube link) on how to use it....Huwag lang malito kasi parang iba ang packaging dito sa atin...Hope it could help...!!
    [ame="http://www.youtube.com/watch?v=tKjhcq7q7SE"]YouTube - Rust Converter | How to Use Gemplers Rust Converter www.gemplers.com[/ame]
    Jan 2011
    #1137
    Good day guys,
    kaka-balance and align lang ng xwind ko last dec 2010.. napansin ko kase may slight na wiggle when i reach around 80kph.. nawala naman yung wiggle after balance and align.. ok pa naman daw yung ibang parts ng suspension..
    recently naman, nag-wiwiggle ulit pagdating ng 50-60kph pero nawawala kung nasa 80kph na.. tsaka parang mejo lumuwang yung manibela.. hindi naman kumakabig..
    ano2x kaya posibleng sira sa suspension ko guys? nagtaka kase ako, ang bilis magkaproblema, 3 months pa lang.. pangit kase talaga kalsada ng mga highways dito sa amin..
    TIA!
    Aug 2009
    #1138
    What you need:
    Optional:
    - pang kiskis
    - rough sandpaper
    After applying RUST Converter sir.... No need to wipe or wash? Direct apply na ng Epoxy primer!? (24 or 48 hours ba talaga sir curing time ng r. converter.) Maraming salamat sir sa reply at info's.... Problem knlang yung "Ramp" Planning to coat it before holy week, uwi kami sa province at doon kunarin gagawin.
    * tata ismael - Do check your "center link" kung umaangat or may kalog kapag kuamakabig manibela nyo.
    #1139
    You have to wash it with soap and water ... Sa akin kasi di aabot nang 24 hours ok na... May titira pa namang rust minsan pero kunti nalng kikiskisin mo....
    May 2010
    #1140
    sir red hindi sa oto yung naka paint ng epoxy paint kundi sa otj ( owner type jeep ) namin lagi kasi nababayhe dati sa malabon navotas yun nasasabak sa baha.. cge sir one of these days pwede naman tayo magkita.. pm nyo nlang sakin contact # nyo.. tama yung binigay na steps ni sir zalphyro sundan nyo lang yun
Isuzu Crosswind Owners Thread [continued]
