Page 5 of 51 FirstFirst 12345678915 ... LastLast
Results 81 to 100 of 3710
    Feb 2005
    Quote Originally Posted by buknoi View Post
    sir can we fuel up our car with seaoil?
    Why not? Of course you can.
    Namely SeaOil, UniOil and Phoenix are some (the rest are the unmentioned "small players") that are considered "cleanest" fuels available locally. Why? They are mostly direct import from Japan -- a country considered to have one of the strictest standards before a product is released in the market.
    .... and that statement is coming from someone I know who works for Petron.
    May 2009
    Quote Originally Posted by Benzmizer
    sir salamat po sa info. doubt lang po kasi ako dahil sa humors na mai halo daw tubig. dati don ako lagi kc mas mura xa dito sa amin almost peso din. now babalikan ko cya ulit. thanks sir again! salute u!
    Feb 2005
    You're welcome, don't mention it.
    What you (and all of us) should watch out for are low-lying (located) gas stations that are prone to be flooded. Yan ang malalaki chances na unintentionally nahahaluan ng tubig fuels kapag naaabot ng baha yung station.
    Mar 2011
    Guys help naman, may alam ba kayo kung san ko pwede ipa-mod yung mga ilaw/bulbs ng gauge cluster/center console including clock and odometer? gusto ko kasi papalitan yung sa 2004 xuvi crosswind ko na stock green to blue TIA
    OT: share ko lang pics ng simple sound setup ng xwind ko
    Alpine 9887 HU
    Focal KRX2 installed on stock locations
    Phoenix Gold Ti600.4 (Tchernov RCA's and Stinger Power&Speaker wires)
    2 Polk Audio MM1040DVC on a simple sealed enclosure
    Feb 2005
    Quote Originally Posted by mjuane View Post
    Nice sound set-up. Congrats!
    As for the gauge panel lights, ang alam ko naka-condom lang yung nagpapajulay ng ilaw sa gauges/switches. If you can replace that from green to blue, ayos na yan!
    Alpine 9887 HU
    I like the subs, simple at malinis.. Saan ka nagpagawa nyan pre?
    Jun 2011
    *Buknoi: Am using Seaoil BioXceed Diesel for 3 years without a problem. I got the following info from a Seaoil lab technician report. "Per certificate of analysis (QCPD Report Feb 13, 2008) Seaoil BioXceed Diesel the ff specs: Sulfur content, % mass (ASTM D 4294 method) 0.0008 or 8 PPM (compared to PNS/DOE Specs: 0.05 max or 500PPM; Euro 5 Standard: 10PPM). Calculated Cetane Index (ASTM D 976 method): 54.5 (compared to PNS/DOE Specs: 50 min., Euro 3,4,5 std: 51*number*)"
    Related info from internet: The cetane index is the fuel quality without any additives or cetane boosters yet. Cetane number is the actual measured ignition quality, including the effects of additives.
    Euro 5 Standard:Cetane number 51.0 - ASTM D 613-052 / SR EN ISO 5165:012
    Cetane index 46.0 - SR EN ISO 4264-082 / ASTM D 4737-042 [The test lab is accredited by RENAR, in compliance with SR EN ISO/CEI 17025:2005 and has the accreditation certificate No. LI 333 / 04.02.2008.
    © ROMPETROL
    Released the above info first on >>>Read more: http://tsikot.com/forums/hyundai-car...#ixzz1Up1MmQPk
    May 2009
    sir gud pm ulit. kakatakot naman pag lumiko yung sportivo sa mga kurbada kasi parang matutumba. kaya todo break na lang ako para lang hihina yung angle of listing ng sasakyan
    May 2009
    repost lang po. thanks!
    Apr 2010
    pwede ka mag pa lagay ng rear stabilizer para mabawasan ang feeling na parang matutumba. nag palagay ako ng 25mm diameter anti-roll bar na nabili ko sa surplusan. ngayon OK na kahit 55km/hr- 60km/hr sa curve ay ok lamang.
    May 2009
    Quote Originally Posted by grandprix
    ganun po ba sir. salamat. maghabap pa ako dito sa mindanao ng ganyan
    Feb 2005
    Where are you located in Mindanao? If i'm not mistaken, the brother of the owner of Isuzu Davao has an accessory shop in Manila. He sells that stabilizer bar we are referring to. Try to inquire if you can get one thru Isuzu Davao or get his brother's contact details. Brother's name is Henry.
    May 2009
    *normaxuv
    sir napaka techy naman nyan.hehe. thanks din for u for d convincing info. kaktipid na ulit aq w/o comprimising the health of my car. hahah
    Aug 2011
    mga sirs hingi naman ako ng advice sa inyo.. Nkuha ko crosswind xuv ko nung july, nakaka 500kms plang at may naririnig akong sound pag nagbbrake ako, parang "tok tok". Ano kaya problema nito? Patulong naman po.. Salamat po!
    Aug 2011
    Mahirap po ipasok yung Reverse ko. What seems to be the problem? :\
    Quote Originally Posted by technowar View Post
    try mo paadjust ung clutch.
    Aug 2011
    But okay naman yung 1-5 gears, walang problema. Sa reverse lang talaga.
    Aug 2009
    *technowar
    Sir, normal nalang ata yun. Kasi yung saakin din, pag i-enter ko sa reverse kahit sobrang lalim na ng apak ng clutch, minsan sobrang hirap talaga.
    Aug 2011
    Quote Originally Posted by bokista View Post
    Guys up ko lang po itong tanong ko..
    Aug 2009
    *bokista
    Saan galing yung sound?
Isuzu Crosswind Owners Thread [continued]
