Ok ba yung Michelin na gulong para sa Crosswind?
In my personal experience, satisfactory performance Bro after 4 years doin the terrains in MIndanao!
Michellin 235X/70 R15 103S LTX A/T Tubeless. Of course, since day 1 and to date , maintained by Nitrogen with proper pressure as per Isuzu. Til now, displayed only minimal normal wear, but foremost didnt have any explosions-of course porper tire maintenance (rotation, balancing, pressure monitor/rectification, periodic lift up for injurious pebbles-removal in between threads etc..).
good pm everyone just wanted to ask if anyone here knows where i can make mods and upgrades in my xmax sportivo 2010 here in cagayan de oro city??? anyone?
guys just wondering if nakakita na kayo ng 06 sportivo na naka h.i.d? parang wala pa akong nakikita na crosswind na naka h.i.d or super dalang lang. can you guys post pictures. thanks!
Hi everyone. Just bought my xwind xuv manual c. green. Proud new owner![]()
hi there ask ko lng po sa mga guru natin kc ung door lamp ng bago sportivo naka on kahit patay na makina. May way po ba para ma off ito. Thanks!!!
kung na ka on yung door lamp, most probably may isang door na hindi properly closed. baka yung sa rear door. kailangan mo kasing i slam talaga para ma close. i check mo kung yung door ay ka level ba dun sa rear na part ng car. kung naka usli ng kaunti, hindi properly locked ung door. to double check, i lagay mo yung switch ng ceiling lamp sa center, where dapat iilaw siya once na open yung door, at ma turn off naman siya kung properly closed lahat ng door. kung naka ilaw pa rin siya kahit close na lahat ng door (at on din yun door lamp) malamang hindi properly closed ang isang door.
just had a 20k checkup sa isuzu makati, grabe 10k php!
punta kse kming ilocos tom kaya pina full checkup...
san ba mas murang magpa full checkup aside from casa?
yung oil filter nila 600php eh yung nabili ko dati 200php tsktsk...
mga chong, saan ba puwedeng mag pa-compression test? yung within q.c. or caloocan lang sana. galing nako sa speedlab as suggested here in tsikot, but to no avail.
pina-check ko na rin muna sa Denso banawe pero normal lang daw yung XTO ko.
kahit na------- may usok na puti sa dipstick tube and bumubuga rin dun ng langis???
pero bukod dun, lahat ayos pa.
TIA sa mga sasagot!
Bro, 'sama na ako dyan..totoo masakit sa bulsa.But in fairness, sa "full check up" done, advantage mo pa rin. Unit mo undergone quality check dahil pag sa casa ka, they used precision tools, gadgets and equipment which is one thing bihirang mangyari "outside casa". Medyu may kamahalan nga kasi...special tools nila needs periodic calibration, maintenance, 3rd party certifications. This also includes mechanics progressive training on latest industry technical know-how...good for us clients. Then, they maintained a safe and clean working environment which practically good for our serviced units . These are few examples why a 'lil bit high cost compared "labas".Although mga beterano din ang ibang mechanics sa labas, pero many lacks the aforesaid tools. BTW 600PHP is the orig item...pareha lang d2 sa Isuzu casa in Mindanao, kaya no worries. Have a safe journey!
Bro, so many plus with nitrogen. My friends in aviation/car maintenance gave some technical advises but I did my homework too about it and would like to share with you some of my references before I decide to apply it. Please see: Nitrogen Information and Advantages. it helps. Full nitrogen gas fill up/tire is 40PHP in my place , Cagayan De Oro. re-fill is 20PHP/tire. Dunno how much in Manila.
Honestly, the differences between Nitrogen and Air (already 78% Nitrogen) is hotly debated. In a typical day, the temperature variation is about 10C; this corresponds to a change in pressure of about 2 psi on the tires. N2 and air both act the same to temperature and pressure conditions inside the tire. If somebody wants to give you nitrogen for free, take it. If they want you pay, skip it. Just keep your tires inflated to the correct pressure with compressed air and you will be fine. Having said all this, your 40 peso/tire is great price.....in the USA some tire stores are charging up to $25 for set of 5 tires.
Dagdag gastos lang yan sa mga madaling mauto. Common sense na lang. Yung "nitrogen" kuno machine nila eh mukhang glorified air compressor lang. Correct me na lang if mali ako, saan naman kinukuha ng "nitrogen kuno machine" ang nitrogen na ilalagay sa gulong mo? Paaandarin lang yung makina then may nitrogen na nagawa? Daig pa ang chemical factory ah. :D
goodluck chuck,
you should have check it thoroughly before you bought the car.
p.check up mo na lng yan sa casa or sa mga ibang shop para mas makatipid ka,for sure mas madaling malaman ang problema pag nasa actual na.
Paunti unti naayos kuna yung crosswind ko ano pa ba kulang?
Change oil, fuel filter & oil filter
overhaul ng mga brakes
tune up & valve clearance adjustment
Change of tires from 205 65 to 205 70 tapos na balance na rin
binili ku na rin nito bagong floor mat, rain visor, rear spoiler, pati na beverage & cellphone holder
Sa tues papa hilamos ko tapos palagyan ko ng carbon fiber sticker yung hood imbes na pa repaint ko yun na muna.
Planning to put 1 din dvd tv monitor next month
Decals na lang kulang, mga magkano kaya decals sa CASA? or may mabibili sa mga suking auto shops?
