Page 4 of 51 FirstFirst 1234567814 ... LastLast
Results 61 to 80 of 3710
    Jun 2011
    Hey Guys, Im a newbie here. I got an '02 crosswind XT. May nadaanan akong baha kanina na hanggang bewang, while I was driving sa baha, umilaw ung mga Warning Indicator Lights ko (Handbrake, Batt & Oil) tas nung nalagpasan ko na ung baha, nawala na ung warning indicators... bakit kaya? dahil kaya nabaha lang ako? kc nawala agad ung lights pagkalagpas ko.. thanks
    Aug 2009
    [QUOTE=ackrite72;1774852]Hey Guys, Im a newbie here. I got an '02 crosswind XT. May nadaanan akong baha kanina na hanggang bewang, while I was driving sa baha, umilaw ung mga Warning Indicator Lights ko (Handbrake, Batt & Oil) tas nung nalagpasan ko na ung baha, nawala na ung warning indicators... bakit kaya? dahil kaya nabaha lang ako? kc nawala agad ung lights pagkalagpas ko.. thanks...
    * Normally ok lng yan bro. Pag may time ka check underneath of your engine kung may leak or madumi "maraming nakasabit na plastic" cause ng baha. Try murin buksan yung hood then air dry mo buong engine compartment. (inside the garage) If ever bumalik or nag on indicators mo while driving, double check mo yung "sensor" gauge nya at baka kaylangan ng palitan.
    Feb 2011
    i've got a sportivo 2010 mt and i also encountered that problem so i consulted the mechanic at isuzu about this problem and he told me that it is just normal whenever you go thru flooded roads, accdg to him there is this tendency of the fan belt to slip being immersed in water causing all that warning lights to go on and after a while return to normal when it recovers from slipping...
    Aug 2007
    Mine is xwind xuv2010, had fog lights installed at Isuzu Alabang last March..due to last week rains nagkaroon ng moist/water yung foglights sa loob...covered ba ng warranty ito...paano ba irepair ito. Hindi ko tuloy magamit yung foglights ...baka magkaproblema sa electricals.
    Buhay na buhay ang isuzu crosswind owners page natin sa facebook, feel free to join guys.
    My 08 xuv has excessive moisture at the back left portion panel when my acu is on at the rear. It even reaches the "xuv" logo at the back portion...sir benz what seems to the problem of my acu? TIA
    Jun 2011
    Tires (205 65 r15) for Isuzu Crosswind dito sa davao:
    Goodyear Assurance Fuel Max (casi mcarthur hiway matina)- 4000
    Goodyear Duraplus (casi mcarthur hiway matina)- 3600
    Michelin Agilis (philtyres sta. ana)- 5460
    Yokohama Aspec (philtyres sta. ana)-3987
    Hankook Optimo K415 (philtyres sta. ana)- 3645
    GT Radial Champiro GTX (everstrong monteverde)-3400
    Bridgestone Turanza (boston sta. ana)- 4600
    mga bossing, saan kaya sa mga to ang pinakapanalo based sa experience nyo? meron pa ba kayong masuggest na iba pa na panalo din ang performance at magkano din jan sa inyo? sayang kasi ang pera pag nagkamali sa pagbili. TIA
    Jun 2011
    Feb 2005
    Quote Originally Posted by lastpogi View Post
    If you feel that the cooling performance of your AC unit is not compromised, not to worry. The rear AC duct passes thru the driverside C-Pillar --- that's why there is moisture. If the cooling is compromised, there may be a leak in the ducts at the pillar (causing the moisture)
    If there is any consolation, it only shows how cold the AC system of the Crosswind.
    Feb 2011
    Bros, I own a 2003 crosswind xuv and my mileage is hitting 102k now. I am very happy with my crosswind. It was only recently that i've experienced a clicking sound when i switch the ignition key. Im suspecting its the battery.... Any experience like this with your ride? Im using a 2sn motolite excel, if the battery is the problem im planning to upgrade to 3sn would this fit? Or 3sn is overkill for our ride. Tia!
    Jul 2011
    good morning gurus, just got a 2006 sportivo. medyo mausok, san kaya ok magpa nozzle cleaning sa rizal area aside from the two casa's pasig and marcos hiway?
    another question, busted yung bulb ng driverside foglamps, magkano ba bulb nito?
    TIA
    Feb 2005
    Quote Originally Posted by astra22 View Post
    Does it turn? Nagre-redondo ba? If hindi, try using another battery. If it works, then you'd need to replace the battery. 3SM would be nice but I doubt if it'll fit your battery tray. 2SM would suffice (as recommended)
    Quote Originally Posted by sgotogs View Post
    That should not be that expensive. Regular H3 bulb lang yan. Less than P500 for a pair.
    Feb 2011
    Thanks Uncle Nick and Benzmizer for the reply. I' m observing my crosswind now with the borrowed battery. Seems to be working fine.
    If the "clicking" sound happens again, il have it checked by the CASA asap.
    Though, Does this really happen to older crosswind like mine? Starter, giving up due to wear & tear?
    TIA!
    Jun 2011
    *all
    meron naba nakapagtry ng diy sa interior detailing dito? Gusto ko sanang diy ung interior ng xuvi ko dis sat. Ano ba pwede kung gamitin panglinis gusto ko lang sana yung nkikita lang sa bahay like laundry powder, zonrox and water
    Aug 2011
    mga sirs, tanong ko lang kung anong ground clearance ng 2011 xuv?? TIA!
    Feb 2005
    Quote Originally Posted by bokista View Post
    188 mm for both XUV and Sportivo. XL, XT and XTi is 185 mm.
    Aug 2011
    Quote Originally Posted by Benzmizer View Post
    salamat sir benz!
    Jun 2011
    hello mga bossing.
    ask ko lang what brand of engine, manual transmission at gear oil gamit nyo sa m/t crosswind?
    my uncle, a car enthusiast and mechanic, has always been a fan of castrol and nakumbinsi ako. castrol magnatec (10w40) for the engine, castrol manual transmission fluid (EP 80W/90) for the trans and gear so i am also using the same. pls suggest other brands na panalo at di nakakabutas ng bulsa. TIA
    Apr 2010
    Quote Originally Posted by ydrion View Post
    hello mga bossing.
    The engine and transmission of crosswind(manual tranny) shares the same oil viscosity, that is 15w40. 80w90 grade is for the rear axle only.
    May 2009
    sir can we fuel up our car with seaoil?
Isuzu Crosswind Owners Thread [continued]
