Results 721 to 730 of 3710
January 20th, 2011 01:56 PM #721
- Nov 2008
- 125
January 20th, 2011 03:24 PM #723
January 20th, 2011 04:16 PM #724
January 20th, 2011 04:29 PM #725
- Dec 2010
- 46
January 20th, 2011 09:34 PM #726
Hi Uncle Nick - First of, thank you for your time in attending to my queries.
My xwind details-
07 Sportivo MT, 4JA1
ODO is 51K
Im from the lowlands, Tarlac City, high way and City driving, just an average driver, max speed ranging from 60-80 kph, i shift the gear when the tach hits 2-
Is it possible to increase a little bit of acceleration(just to remove the delay) and increase fuel mileage or I only need to choose one, from the three? If I only have one shot, that would be the mileage.(parang genie may tatlong kahilingan)
thanks in advance uncle.
- Jan 2011
- 193
January 21st, 2011 11:10 AM #727My observation is that you are an "average" driver and that is what your ECU is programmed for....no offense to you is meant.
To make any adjustments to the ECU would result in very minimal fuel consumption gains but very noticible performance losses.
My advice, forget the ECU adjustments unless you know a real expert with credentials.
ECU adjustments are better suited to gasoline fed engines in light weight unibody cars.
You are better advised to look at other factors which are not so costly and easily reversed;
Increase your tire pressures.
Lose weight i.e. heavy tools or other items.
Remove your roof rack or other proturbances (if present).
Use your brakes sparingly i.e. slow down to a gradual stop.
Accelerate slowly.
I know, I know, you have heard this before, but they do work to increase fuel mileage, really.
Long term, get a D-max or Alterra as soon as you can to get both better fuel mileage and acceleration at the same time.
Ciao!
Uncle Nick.
- Dec 2010
- 46
- Jan 2011
- 7
January 24th, 2011 07:52 AM #729:hide:[SIZE=4]gud day po bago lng po ako dto. ask ko lng po about the timing chain ng crosswind, if pwde bng lagyan ng grasa if malakas na yong ingay,, thnkz po mga master!!!!!!!!!!!!![/SIZE]!
- Jan 2011
- 176
January 24th, 2011 07:53 AM #730Good day guys!
Anybody here selling his stock/OEM crosswind/sportivo 5.6 LCD headrest monitor? yung 5.6 inches ang size like this..
and model nya at the back of the monitor is Necvox FD-2560 TFT LCD Monitor..
please PM me if you have even at least one monitor..
Thanks and God bless!
Mas ok yung may easy access na cap. My Panasonic battery with i-stop (most of the time I missed to...
