Page 23 of 51 FirstFirst ... 1319202122232425262733 ... LastLast
Results 441 to 460 of 3710
    Feb 2011
    Mga bros, i have a problem with the radiator of my 2003 Crosswind XUV. Nagbabawas na sya ng tubig. Ang estimate ko isang baso ang nababawas every morning. Kaya pa ba ng overhaul ito or palit na. Baka may suggestions po kayo ng reputable shops in las pinas alabang area for the overhaul. Thank you.
    Feb 2013
    Coolant pa ba ang nakalagay sa radiator mo or just plain distilled water?
    How sure are you na sa radiator nga ang may problema?
    Jun 2010
    Quote Originally Posted by astra22 View Post
    Sir, may leak lang yan. Mine is also 2003 model and I've done repairs too on my radiator. Nagpa-overhaul lang ako and repair with "tingga" para sa tagas. Kalokohan po iyung 4.5k na overhaul =)). Sagad na siguro ang 1500 para sa maayos na gawa. Though I can't recommend any shops for you since I'm from Cubao area. Hanap ka lang sir ng reputable shop. Madali lang yan.
    Take note nga lang na sa fittings lang ang naging tagas ng sakin. Madali lang ma-repair ang ganun. The problem is, kung sa fins nga yan, ibang usapan na yun. From what my suki shop said, kapag doon daw ang tagas, maaaring palitin na nga. Better have it checked first.
    Jan 2013
    magkano po bagong radiator? baka onti na lang dadagdag mo sa 4500 bagong radiator na
    Oct 2011
    Quote Originally Posted by andrew_28 View Post
    3500 boss sa UE auto supply sa Masangkay ang bnew na radiator! :-)
    Feb 2011
    Quote Originally Posted by siopaonatoasted View Post
    Im using 50% water and 50% coolant. It was diagnosed in the CASA as having radiator leak coming fom the fins. The CASA is charging P4.5 k for the overhaul.
    Feb 2013
    Palit ka na radiator.
    Feb 2011
    Good suggestion bros! I was able to have my radiator overhauled. We found out that the leak was not really from the fins. I only spent 1k for the overhaul and repair. I hope this will be a good long time fix. Been using my crosswind for 3 days now without refilling the radiator!
    Jun 2010
    Good job bro. Saan mo pinagawa?
    Feb 2011
    Had it overhauled and repaired at Prens in Alabang. Almost halfday to finish the job.
    Jun 2013
    what pair of speakers ang magandang ipalit sa front and rear ng xwind xuv 03 model?? papalitan ko na kasi yung stock, pangit na ng tunog. naghahanap ako ng punchy bass replacement speaker for front and rear, 4inch sa front and 6.5inch sa rear. ayaw ko na sana lagyan ng subwoofer.
    Jun 2010
    Quote Originally Posted by Rob Echevarria View Post
    I upgraded to Sony explod. Pero sa tingin ko may limitation talaga ang speakers set-up natin. Yumayanig kasi yung pinto kaya hindi solid ang bass kahit gaano pa kalakas ang speakers mo. Unless magpa-install ka siguro ng insulation or sound deadener baka may improvement. Kaya in the end, I still resorted to an amplified bass tube para minimal lang ang space consumption. Oks na oks ang tunog niya for 6k.
    Apr 2008
    Quote Originally Posted by kafph2000 View Post
    if defined bass ang gusto u need the subs tlga.may limitation parin ung kayang ibuga na frequency ng speakers sa pintuan kahit ung mumurahin na SW with murang ampli malaki na difference
    ive tried the pioneer a series speakers medyo ok na ang bass para sa akin(maganda rin and presyo) just apply a deadener sa front and specially sa back....
    Sep 2009
    Quote Originally Posted by Sherwin Erive View Post
    mga boss. may nakapagparepair na ba sa inyo ng spare tire cover ng crosswind natin.. nabangga kasi yung likuran ko eh nabasag yung spare tire although maliit lang yung damage. cracked lang sa surface. pwede ba masilya at pintura lang yun? xwind '03 model po ride ko. Tia po.
    kung surface lang ang crack, oks pa masilya diyan. pero kung tagusan na yung umbot na sa ilalim yung lamat, dapat palapatan mo ng fiber yung likod tapis masilya sa ibabaw dahil yung vibration mabibiyak ulit yan.
    Sep 2009
    Quote Originally Posted by topz View Post
    Mga xwind masters, im newbie here from cebu city and just owned 2nd hand isuzu crosswind xuv 2004. May question po ako regarding sa foglamps dahil disconnected na po yong wire at gusto ko po sana e connect ulit. DIY sana po ay matulongan at magabayan nyo po ako kung paano ko gawin yon.. TIA
    panong disconnected, tanggal yung wiring? o baka naman pundido lang yung bombilya?
    Sep 2013
    Quote Originally Posted by holdencaulfield View Post
    disconnected po ang wire. naikabit ko na po kanina lng kaso hindi umilaw baka ponder yon bulb. anong fog bulb po ba pwede sa xwind xuv 2004 at paaano po ba tanggalin ang ponder na bulb? TIA!
    Sep 2009
    ot: nice handle name! yours or did you get it from "helmet's" former guitarist rob echeverria?
    the only difference is the "a" in your surname.
    welcome to tsikot!
    Sep 2009
    h3 yung lamps
    na pang fog para sa xuv 04.
    pano ko ba simulan?
    yung unang ginawa ko, gumapang ako sa ilalim tapos sinilip at sinalat ko lang. kaya lang ang hirap! mas madali sayo kasi mataas yung xuv kesa sa xto ko na mababa.
    yung pangalawa, tinanggal ko yung bumper. mas madaling procedure ito kasi kitang-kita mo yung paglalagyan mo ng bulbs sa likod ng bumper. tatanggalin mo lang naman yung 2 bolts sa magkabilang dulo tapos hatakin mo yung bumper.
    pero bago mo hatakin tanggalin mo muna ulit yung clip-socket (yan ba yung pinagkabit mo sa ilalim?), baka kasi maputol.
    kung natanggal na yung bumper, makikita mo na yung likuran ng housing ng foglamps.
    pag natanggal mo na yung bulbs, pa test mo muna baka okay pa.
    sorry ah, tagal ko na kasing ginawa ito kaya nalimutan ko na kung paano yung sa bulbs mismo. pero madali lang naman yan kung kita mo ng maayos yung housing ng foglamps.
    good luck chong at sana may makatulong pa sayo!
    Sep 2013
    h3 yung lamps
    pano ko ba simulan?
    Salamat sa input sir holdencaulfield! natanggal ko kanina ang foglamp at nilinis chinek ko ang bulb ayon pondido ang isa. yong isa naman ok pa. Salamat sir!
Isuzu Crosswind Owners Thread [continued]
