Page 173 of 186 FirstFirst ... 73123163169170171172173174175176177183 ... LastLast
Results 3,441 to 3,460 of 3710
    May 2009
    #3441
    Quote Originally Posted by einreb07 View Post
    Tanung lang po anu po kaya part no. ng Baldwin Oil filter fit sa Isuzu Crosswind xti 2010? Maraming Salamat po
    Baldwin
    Oil Filter B1446
    Fuel Filter BF954
    Jun 2016
    #3442
    Good day! newbie here..does an Isuzu NKR fuel pump assembly have a built in fuel filter? Should I install a water separator apart from the pump assembly? The assembly is fitted in my XUV2003..tia
    This is the model
    Circuit No. CFP- 1IS
    OEM No. 8-94154-754-5
    Model ISUZU NKR(8mmpipe)
    Brand: Circuit
    Apr 2009
    #3443
    Quote Originally Posted by andongskee View Post
    Good afternoon po! May alam po ba kayo na magaling na mag-aayos ng Manual transmission ng Crosswind(04XTRM)? Eto na nga po yung pinangangambahan ko...biglang may umingay...parang grinding high pitch sound sya especially kapag bibitawan mo ang accelarator kung naka third - fourth gear ka!!! Wala pong problema sa pagkambyo, pumapasok naman po with ease....its just that parang may mrt sa ilalim ng sasakyan ko pag release ng accelerator. Pag nerelease naman po sa kambyo mawawala ang tunog kahit tumatakbo ka pa ng 80 kph!
    Kala ko po nung una eh Axle bearings, so I had both replaced. Di pa rin po nawala. So I checked the Universal joints...same...di pa rin po nawala.
    Mga sir, baka po may alam kayong transmission specialist na may readily availbale na surplus parts? Checked brand new and its 38k kay jason. Surplus is 22k sa blumentritt!!! Tight po budget so kung ano lang po sira, yun lang po balak ko palitan!!! Ang sabi po sa akin nung pinasakay ko para maconfirm talaga na may naririg, ang sabi nya po eh baka main drive bearing ng transmission!
    Salamat po!
    QUOTE=einreb07;2747857]Boss tinignan nyo na po ba ung disk brake sa harap maigi, silipin nyo po baka napasakan ng maliit na bato.[/QUOTE]
    Andongskee baka makatulong share ko sayo. sorry now ko lang nabasa.
    possible kailangan mo ng palitan Clutch disk, pressure plate, release bearing and pilot bearing. gastos mo kasama labor around 6500. Napalitan na ba itong mga parts na ito sa sasakyan mo? nangyari kasi sa one of our delivery vans tumutunog pag change gears or pa tumatakbo, pinabayaan lang ng driver kasi nakaka change naman daw ng gears ang nangyari tumirik yung sasakyan nag lock na yung
    pressure plate sa disc. ayaw ng gumalaw ang kambyo. or kulang lang gear oil sa differential kaya may ingay and check also transmission oil. sa gas station lang palagyan mo mura lang.
    Aug 2014
    #3444
    help umiilaw yung oil sending unit ko pag naka drive yung kambyo ko pag naka neutral oark or iaabante ko nawawala naman. yung ilaw nya kurap kurap minsan steady ok ang level ng oil ko. ayokong isipin na may prob na ang oil pump ko
    May 2009
    #3445
    Quote Originally Posted by abduljhacull View Post
    kahit mainit o malamig ang makina at naka idle lang kamo umiilaw ang oil pressure warning light?
    pero kapag aabante ka na or aatras nawawala naman?
    nangyari na sa akin yung ganyan although ibang brand ng sasakyan. turned out na yung oil pressure switch ang salarin....subukan mo palitan tutal mura lang naman. less than P200 lang naman yung replacement brands.
    mas maigi pakonektahan mo muna ng mechanical oil pressure gage para makita ang hot idle oil pressure at maximum oil [presure. kung within normal range e walang problema. yari na kung mababa pa rin oil pressure kahit irev mo engine.
    May 2009
    #3446
    Quote Originally Posted by anthon05 View Post
    pressure plate sa disc. ayaw ng gumalaw ang kambyo. or kulang lang gear oil sa differential kaya may ingay and check also transmission oil. sa gas station lang palagyan mo mura lang.[/QUOTE]
    kung pilot bearing kasi, maingay kahit nakaneutral or sa kahit anong vehicle speed...
    kung release bearing naman, everytime na apakan mo ang clutch ang tumitindi ang ingay nito..
    kaso 3rd-4th gear lang daw nangyayari, kaya i assume na nasa synchronizer, hub o mismong gears ng 3rd o 4th.
    pinakamaigi pa rin na diagnosis e ibaba ang transmission at idisassemble ang laman loob nito.
    Aug 2009
    #3447
    good pm, may nakapag palit na ba sa inyo ng sun visor? nabali kasi yung amin... bukod sa casa san po ba nakakabili? salamat!
    Sent from my H940 using Tapatalk
    #3448
    recently acquired xuvi turbo a/t. while driving it along commonwealth, it doesn't or having a hard time go beyond 40kph. parang mamatay. at one time. kahit anung apak ko sa gas wala nangyayari kahit baon na. i switched it off then restart nag ok pero ayun super bagal. kung baga parang naka 1st, 2nd gear lang. RPM seems can't go pass 2k.
    baka may ma recommend kayo shop in qc/commonwealth area. thanks.
    #3449
    Try bringing your unit to Isuzu Commonwealth.
    AK
    Quote Originally Posted by ineedmorehp View Post
    #3450
    Quote Originally Posted by AnitoKid View Post
    AK
    aside from that? any other place where i can have it checked?
    Apr 2009
    #3451
    What you can do first bring to your trusted mechanic have the fuel filter replaced and palinis yung
    sedimentor. also palinis din air filter or replace. then observe mo if ganun pa rin might be your injection
    pump. Sa mechanic ng gas station kaya nila replace filters. ano na mileage ng crosswind mo? mausok ba?
    Jun 2010
    #3452
    May nakapansin po ba sa sudden 50k price increase ng mga isuzu vehicles sa Isuzu official site, Any thoughts for it? Sa mga natatanong ko na SA puro clueless lahat parang impossible naman na nagkamali lang sila sa pagpost. Anyone na may inside report hehe.
    #3453
    mga master, magkano po radiator assembly ng crosswind '02? nagtanong ako sa casa 72k ang price quote nila, sabi ko ano yan, turbo? nasa 7k to 10k po ba ang range or mas lower pa ang price? salamat...
    Apr 2009
    #3454
    Quote Originally Posted by anarki View Post
    yung XTO ko pinalitan ko ng radiator nung 2010. ang brand evercool.. dati 5k lang bili ko. maybe
    tumataas na ng kaunti ngayon. .canvass ka na lang sa mga auto supply. for OEM ask mo Jaysons sa
    a. rivera manila.
    #3455
    got it. change filter (fuel / air) and it is normal again. highway driven only. almost 100k km pero di pumupusit
    will this improve if malagyan ng intercooler? speed? bagal eh turbo AT btw...
    Apr 2009
    #3456
    Ganyan lang talaga speed ng crosswind up to 120 to 130kph delikado na maingay na engine.
    I don't know kung puede intercooler.
    Apr 2009
    #3457
    Tanong ko lang po kung sino na nakapagreplace ng speedometer cable ng crosswind.
    Bumigay na speedometer cable kanina huminto sa 20kph yung pointer.
    narerepair ba yun? mahirap ba palitan?
    thank you
    #3458
    a. rivera manila.
    Salamat sa info...
    May 2009
    #3459
    thank you
    hindi mechanical (cable) ang connection nyan kundi electronic.....mayrong vehicle speed sensor sa right rear side ng transmission.
    either the sensor, connections or the gauge ang may sira.
    Apr 2009
    #3460
    Quote Originally Posted by miked View Post
    Akala ko cable pa ang crosswind.
    Thank you Sir miked.
Isuzu Crosswind Owners Thread [continued]
