Results 711 to 720 of 3710
- Jan 2011
- 24
January 17th, 2011 04:27 PM #711Ung white smoke ba during warm up lng or kahit mainit n ang makina? Hindi b nag ooverheat ang makina? check u po ung coolant level nu bka mababa n, white smoke means nagsusunog kna ng coolant at dahil sa tubig na humalo sa fuel ang makina ay mnginginig. could be cylinder head gasket warped n po.
- Dec 2010
- 46
January 18th, 2011 02:48 PM #712
Hi Uncle Nick - Please elaborate.
Just a side note: I know one mechanic that is claiming that he can reset or overwrite the default setting of a car.He said he can remove the delay(response time when we press the gas,normally it will take time before the vehicle moves)
- Jan 2011
- 58
January 18th, 2011 03:36 PM #713Thanks again BENZ.... Mga bossing, just wanna know, pagka binaba ang gearbox ng xwind to fix it, would there be any misalignment sa wheel pgkabalik ng gearbox???.. necessary ba na ipa align ko e2?? chaka meron na ngbebenta ng aircon treatment d2 stin to sanitize the a/c?
January 18th, 2011 04:20 PM #714
- Nov 2007
- 412
January 18th, 2011 06:57 PM #715
- Jan 2011
- 193
January 19th, 2011 03:24 PM #716This is basically true. For example;
He can reset the transmission to respond sooner, but then, the transmission could require power when the engine is "cold", and/or the turbo is not quite ready. The factory settings take care of such possibilities.
I would be pleased to elaborate.
However this is a subject with many twists and turns and is too complicated for a quick answer to all possibilities.
Let us be specific to you.
What vehicle do you have; year, engine, mileage (odometer)?
What do you wish to achieve? increased fuel mileage or, more acceleration or, more power etc?
You cannot have the all. If you increase one, you will probably decrease the other two.
Tell me more about you and how you drive (high altitudes, sea levels, highway, city etc) and, I will respond.
OK?
Ciao!
Uncle Nick.
- Nov 2008
- 125
January 19th, 2011 07:18 PM #717ayaw mag-start yung sportivo namin. try namin series ayaw talaga. jumpstart ayaw din. possible na starter problem
how much kaya pag papalitan ang starter? tsk. sakit na to sa ulo ha
January 20th, 2011 11:28 AM #718
- Nov 2008
- 125
January 20th, 2011 01:00 PM #719baka daw hindi starter ang problem, kasi pag switch mo wala yung heater indicator. ok naman daw yung starter . san kaya yung heater nito. di rin kabisado ng mekaniko eh.
January 20th, 2011 01:31 PM #720
^Thanks for the advise guys. Already replaced all.
Rubber boot question (repair or replace)
