Page 80 of 89 FirstFirst ... 3070767778798081828384 ... LastLast
Results 1,581 to 1,600 of 1770
    Feb 2005
    #1581
    Quote Originally Posted by kaioz View Post
    mga sir, alarming ba pag bumababa ng 11volt ang battery kapag full load ang xwind?
    -aircon max
    -hazard on
    -hi HL on
    -fogs on
    -stereo HU volume 20, (60+ max volume)
    14v+ kapag off lahat.
    ano ba dapat ko pa check?
    Did you do some electrical-related modifications on your vehicle? If yes, check on the load requirement of that mod. If not, it could be bad grounding. You can be sure by bringing your vehicle to a reputable electrical shop i.e. Wizzard. have them check your wiring vis-a-vis alternator charging.
    #1582
    Quote Originally Posted by Benzmizer View Post
    san yung location ng Wizzard sir?
    may sakit kasi yung xwind, minsan di nag chacharge ng battery.
    one time galing kami nag grocery. i turned it off, then i opened our gate, pag balik ko sa car, ayaw na mag start. minsan pag mornings ganun din. turo sakin nung kakilala kong driver kargahan ko daw muna before turning the engine off. seemed to work. but i dont want to settle for this. hindi naman kasi sya ganun dati.
    small audio upgrade has been done
    replaced stock speakers sa harap(70wRMS) chaka sub(300wRMS) sa likod running on a v12 amp. very light setup lang. pero this was intalled AFTER the car developed this problem. baka na enhance din ng audio upgrade yung problem.
    also one night nag ddrive ako in front of an owner type jeep, napansin ko yung headlight ko nag didim then lalakas pag apak sa gas pedal(yung parang sa mga tricycle). asked my friends on what they think is the problem, sabi alternator daw malamang.
    May 2009
    #1583
    *Southwoods: Hehehe! Such as small piece but big in price......
    Ilang beses ko nga pinaulit yung presyo eh, parang na bingi ako eh. LOL
    May 2009
    #1584
    hi guys...eto experience ko sa crosswind ko...fill-up to the brim then reset trip meter sa odo..it already ran 764kms pero wala pang indicator light ang gauge ko kaya nag-fill up ako bale 49 liters ang nakarga so may 6 liters left pa sa tank kaso lang di siya umilaw di ba dapat iilaw na siya kasi 6 liters na lang or dapat mas mababa pa?pero ayus na ayus average ko 15++ per liter mixed hiway and city driving...hehehe tipid talaga ng crosswind natin...
    Feb 2005
    #1585
    Quote Originally Posted by jaz014 View Post
    Congrats! The low fuel indicator should light up when fuel hit the reserve level.
    May 2009
    #1586
    sir bob thanks...di ba dati sa post nyo nasa more or less 8liters remaining sa tank eh dapat maglight-up na yung indicator...6liters na lang remaining eh wala pa din..what do you think di kaya busted yung bulb or mag try ako 800kms on one full tank...hehehe kaya naman siguro yun ng crosswind...thanks...
    Feb 2010
    #1587
    Please help me on this. . .
    How can i remove the bolts attaching the filler and the fender. . .i wanted my headlight to be cleaned kasi nagmoist, kaso hindi ko matangal. . .sabi ng mechaniko, kailangan tangalin ang bumper para matangal yong bolt ng filler. . . btw, tong filler yong nasa baba ng headlight na nakaatached sa fender. . .
    thanks in advance. . .
    Feb 2005
    #1588
    Quote Originally Posted by atly View Post
    Dunno if this would help you.
    Crosswind 2001-04:
    Crosswind 2005-present:
    #1589
    [Mods, pakilipat na lang in case meron mas appropriate na thread.]
    I do recall a discussion about delays from LTO in issuing/releasing plates for new Isuzu cars. As far as I am concerned, this claim from the dealers is plain excuse. I have to check LTO pasay myself to learn otherwise (300 plates ang available at that time). Obviously, walang follow-ups from the Dealer. Mine is a regular plate (with specified ending for color-coding). Ayun, nakuha ko in a week after kung magalit at makulit ang dealer. Yun lang, kelangang personally lakarin sa LTO office. But If you're like me na ayaw ma-hassle while driving, esp in Makati, it's worth the time.
    Sabi nga ng LTO, ginawa pa silang sangkalan ng dealer inefficiencies.
    Feb 2010
    #1590
    Thanks Sir Benz. . .for 2005 up, please refer to No. 5. . . that can easily be remove becase of the gap between the bumper and the molding. . . however, the molding also bolted with the fender (not shown in the illustration). . . if the molding (filler) will not be removed, the bolts under the headlight (illustration no. 7) will also be hard to remove. . .
    pero i think i got an idea, sa ilalim baka pweding dukutin and screws under the headlight. . . then there's no need to remove the molding (filler). . .
    Thanks.
    Jan 2010
    #1591
    Mga Sirs, tanong ko lang if anyone know of any "loss of power" issue sa 2007 crosswind xuv or crosswinds, in general, with the same engine. There are time na kapag tinapakan ko na yung accelerator, instead na humatak, parang nabibitin yung makina.
    TIA!
    Feb 2005
    #1592
    Quote Originally Posted by jokulit View Post
    TIA!
    What is the mileage of your XUV? When was the last time you had your car changed oil?
    #1593
    Yung plastic chrome parts ng sportivo ko nagstart na magrust. Yung sa taillight saka yung gitna ng mags. Wala pang 1 year a. Pero bakit yung mga ibang nakikita ko sa parking lots kahit 2006 pa walang kalawang? Hindi yata maganda tubig dito sa amin sa las pinas. Matatanggal pa ba ito?. Plan ko to paint it black na lang e yung sa tail lights.
    Jan 2010
    #1594
    Hi Sir Benzmizer! My mileage is now at 60K+ and I just had my PMS. I was thinking if the XUV has a suction control valve (SCV) because the symptom is similar to the SCV issue of Mitsu Strada. Although I have never heard the the XUV had this problem.
    TIA
    Feb 2005
    #1595
    TIA
    Hmmm, I'm not tech guy buy a part of me says it has something to do with the fuel system/lines. Yes, it is not a common case among Crosswinds in general. The most I have heard is slow acceleration particularly on AT variants.
    Being a non-computer controlled unit, it should be a mechanical case. Have it checked by a competent mechanic/shop.
    Jul 2010
    #1596
    Sir, how much is your panel gauge? What is the mileage of the odometer?
    #1597
    TIA!
    Start with the simplest, replace the air and fuel filter (OEM for the air) and OEM or Bosch / Vic originals for fuel.
    #1598
    Guys na naka XUV/Sportivo:
    What mileage are you getting on your respective OEM tires? Are the Bridgestones better in mileage than the Michelins?
    Feb 2005
    #1599
    Nope. Michelins would last more. They seemed not to be rubbers... My '03 XUVi had the OEM Michelins until I sold them 2007.... clocked 100,000kms+ and with still about 65% tire thread left.
    #1600
    Yeah, I strongly agree, mine is already 5 yrs and counting but still the thread left at the rear is 95%, my front still has 80% but was worn unevenly due unbalanced wheel alignment.
Isuzu Crosswind Owners Thread [ARCHIVED]
