Page 276 of 425 FirstFirst ... 176226266272273274275276277278279280286326376 ... LastLast
Results 5,501 to 5,520 of 8497
    Sep 2005
    #5501
    Quote Originally Posted by sutan View Post
    Some more pics of the interior
    Steering wheel and instrument cluster
    Saken pala Euro version?
    Dec 2007
    #5502
    A nice modified Santa Fe, Custom intake, Front mount intercooler, Exhaust, Unichip and Alcohol/water injection.
    Nov 2007
    #5503
    Quote Originally Posted by DragonHeart View Post
    the local distributor of k&n filters has them in stock... I emailed kasi k&n and they had the local distributor contact me... you can order from autocircuit, they will then order from the local distributor, it will take 1-2 days... nag order na ako sa kanila and its already with autocircuit, 4.8k nga lang ang price...
    Sir pano pag nag pa pms kayo? inaalis mo ba yung k&n filter mo at binabalik mo yung stock mo? Naka sked ako ng 10k PMS sa saturday sa alabang then ask ko sa service if replace nila air filter..oo daw sabi ko ako na lang ang mag palit kasi nga balak ko mag k&n para lifetime na.Di pa daw sure kung papayag sa service nila..
    Nov 2006
    #5504
    Quote Originally Posted by SaberRider View Post
    limited ed?
    where did you get your unit?
    Nov 2006
    #5505
    very nice set up
    the fastest 2.2CRDi............
    any engine pics?
    Sir dvldoc can you post costs of the installations,thanks
    Aug 2004
    #5506
    Is this a locally sourced unit with cruise control, sir SaberRider?
    #5507
    Quote Originally Posted by matanglawin View Post
    Quote Originally Posted by C190 View Post
    very nice set up
    any engine pics?
    175BHP * 4000RPM not bad for a 2.2L engine. Yun nga lang void na siguro ang warranty ng engine. Magkano kaya inabut nito?
    May 2007
    #5508
    Definitely void na ang warranty ng makina ng SF nya Sir! Pero matanong ko lang, para saan ba ang modifications na yan para sa makina? Siguro sasali sa racing ng mga Sta. Fe si Doc kaya pina-modify nya! (hehehehe)
    Quote Originally Posted by ferdine View Post
    Dec 2007
    #5509
    very nice set up
    any engine pics?
    www.speedlab.com.ph is where you can look for install and current pricing.
    And if you did not notice the dyno was done before the new front mount intercooler was installed so it actually makes more than 175hp and 330lbs of torque. One of the fastest SUV's in the PI.
    And the thing people need to remember about dyno testing is that it test peak hp, People do not drive around at full throttle all day long. This motor will most likely out live all your stock engines, It runs cooler, more efficient, has more power at fewer rpms so does not need to be reved as high for normal driving, Much lower exhaust gas temperatures which equal longer turbo life and longer engine life, And not to mention the almost completely carbon/soot free internals it will have from the water/alcohol injection and the 70% to 80% reduction in emissions are not hurting anything as well.
    The water injection can be removed in about 10 minutes for trips to the dealer. Fortunately in the states it does not effect warranties, say your starter goes bad, or fuel pump, your front shock ect, all has zero to do with the water injection system being in use there for does not effect your warranty. It has to have a direct effect on a item to void it. Properly installed kits have zero downsides.
    Check out this thread if you want all the specifics or stop by Speedlab in QC.
    http://tsikot.yehey.com/forums/showthread.php?t=48442
    May 2007
    #5510
    Sa States po siguro hindi maapektohan ang warranties pero dito sa atin, I just dont know. I will consult my dealer at kung hindi maapektohan, I might want to consider putting one in mine too! (hehehehe)
    Kakayanin na ba ng SF ko ang bilis ng Hyundai Genesis pag nagpalagay ako nito? (hehehehe)
    May 2007
    #5511
    Teka, parang kotse ni Doc A. ito ah?
    Dec 2007
    #5512
    The owner is a Doctor, I believe a anaesthesiologist.
    Install and kit on a digital progressive kit is 20500P total. Expect 20% more overall power depending on nozzle size and alcohol mix. Most CRDI engines pick up much more.
    Feb 2007
    #5513
    Quote Originally Posted by LadyRider View Post
    Ha!.....Magpapalagay ka pa sa SF wag na!....... bka pwede sa beetle?..hehehe
    Nov 2006
    #5514
    [quote=dvldoc;1123056]The owner is a Doctor, I believe a anaesthesiologist.
    Common rail engines will pick up the most power, The Starex being one of the highest factory rated Turbo diesels around will easily and I mean easily pick up 30hp to 50hp depending on nozzle size and mix. A DO3 nozzle will get you in that HP range. A DO4 will be close to 50 to 60hp but consumption will be high.
    But if you just want around 25hp to 30hp the 2gph nozzle will work well. The proven best combo is the DO1 pre-turbo and DO3 or DO2 nozzle at the intake.(quote)
    Is this the same combo used in Santa Fe- DO1 pre turbo/DO2 nozzle intake?
    Dec 2007
    #5515
    No this vehicle did the single DO3 nozzle (3 gallons per minute/ 189ml minute) Your type of alcohol and percentage also play a big role in power. But even with water you can get a major bump in HP. You just have to find a mix that works best for you. 20% to 15% alcohol is about all you need for a nice power increase and a complete burn of your diesel fuel.
    For example on this 1997 MPV gives you a Ideal on how the kit works, This is with just a 2gph nozzle. He has since put in a 1gph nozzle pre-turbo and makes even more power. Fastest MPV in the PI, pulls like crazy from 1500 to 3000rpms. The more inefficient the engine is the bigger the gains, Mazda, Isuzu and Ford Turbo diesels tend to get huge gains.
    #5516
    what is the correct bulb type for santa fe foglight? h11 or h8 or 881?
    #5517
    Tanong lang po. May nakapag tow na ba dito ng trailer with a 4x2 CRDI? Balak ko kasi magpagawa ng custom trailer for very long trips when I go on holiday with my family. Mahilig kami sa inter-island hopping.
    Nov 2006
    #5518
    Sir ferdine saan ka magpa fabricate ng tow hitch?magkano estimate nila?
    mas ok nga siguro fabricated......
    para medyo dagdagan ng konti ang end part (3")
    masyadong malapit sa bumper yung dulo ng OEM(prone sa gasgas)
    ano ba hahatakin mo?
    $350 presyo sa abroad, Sa Hyundai Global pwede umorder-nasa 19K
    dapat less than 10K lang para affordable
    #5519
    Sir C190 naghanap hanap pa po ako kung sino magandang mag fabricate ng custom trailer. Naghanap din ako sa internet at within that price nga $350. Kung 19K sa Hyundai Global, mahal.
    Balak ko kasi maghatak ng trailer for some other essential things like camping gear, additional spare tire, personal things, at pati narin mountain bike. Gusto ko kasi on leasure trips dala ko lahat family members pati na mga househelp para masaya. At kasyang kasya sa buong car ang tao na sasakay. Actually, I don't like roof racks. Nakakasawa na tingnan. Kahit sa city kahit walang laman, lalagyan lang ng roof racks kahit useless pang-eye candy lang.
    At naisip ko custom trailer na siguro up to 1300 kg ang weight including the things I mentioned above. I read in some forums that an SF can do up to 3000lbs towing capacity. But I have doubts that this is only applicable to a 4x4 V6 gas version.
    Anu kaya tingin mo sa 4x2 na CRDI kaya ba? Tow vehicle with 2 househelps in the 3rd row, my wife, my mom and 2 kids in the 2nd, I and my driver for alternate driving in the first + approx. 1200kg gross for trailer. Of course on-road leisure driving lang.
    Jun 2006
    #5520
    Diba there's a rating on how heavy the SF can tow? nasa Manual ata yon if I remember correctly.
    If I am not mistaken, may restriction ata sa license ito diba (towing)? (Please correct if I am wrong).
Hyundai Santa Fe (Gen. 2) Thread
