Results 21 to 30 of 1710
May 2nd, 2011 01:37 PM #21
May 2nd, 2011 02:57 PM #22
And yet the threadstarter says that the sound was lessened with Shell 93 and went away completely with Blaze.
There's your answer. Stick with higher octane fuels. Not all 93 RON fuels are the same. Hell, some "95" and "97" fuels are horrible compared Shell's "95".
The problem is they all use different additives to obtain that RON rating, which means different effects despite the same RON number... and furthermor, some stations don't mix properly... others have experienced different levels of knock resistance between different batches of Blaze 100... to the point that the Blaze 100 in some stations isn't even as good as the 96 V-Power from Shell.
It's possible that the calibration can't make up for the piss-poor energy content of ethanol enriched 93 RON... which means you'll have to stick with premium fuels.
My suggestion to the threadstarter is to stump up the extra moolah for "premium"... experiment with loading 95, run it for a while and see if the sound disappears. If it does, it's not your motor. It's the fuel.
Hyundai is not alone with this... other manufacturers occassionally have issues with fuel here. Blame poor quality control at the station-to-station level and changing additives and organics.
May 2nd, 2011 04:39 PM #23
Good point Niky, but should've Hyundai warned its client's (accent owners) not to use lower RON?
, yep I know this is the Philippines and we are a third world country and all, but this is very irritating.....
This issue will actually create a big hassle to them in many ways (repairs, claims, spare parts, sales, image). I hope Hyundai addresses this issue quickly....
May 2nd, 2011 04:55 PM #24
They should... when they figure out what the exact problem is. I know of several cases involving other manufacturers where similar has occurred, and with some test units, we are warned by the service departments or sales representatives to use a very specific brand and level of gasoline.
Yes... it's irritating. And a good case for adapting the US Anti-Knock Index for grading gasolines instead of the simplistic RON rating. RON testing does not measure for knock under load. MON (motor octane number), which the US uses to generate AKI numbers in combination with RON, measures knock resistance under load, and is more important for consumers.
May 2nd, 2011 05:01 PM #25
to me, its more acceptable na lemon yung unit, than saying na its a fuel problem.
May 2nd, 2011 05:16 PM #26
Why? If the problem is fuel, replacing the unit will not make the problem go away.
Personally, I've experienced bad gas here. I've seen brand new diesel engines go into limp mode after loading fuel from an unfamiliar station... after running them for days prior with no problems. I've had my car "knock" on fuels that were supposedly high octane... and I've seen some 95 and 96 RON gasolines produce more power from ignition advance than supposed "97 RON" fuels.
Yes... there's a problem with the car, since it's supposed to adapt for poor octane (all modern engines are), but there's always an aggravating factor, otherwise the car would not stop knocking on high octane fuel.
May 2nd, 2011 05:16 PM #27
Thanks for this info.
I hope Hyundai will be the first manufacturer to address this issue head-on, lalu na bago pa ang accent.
The gasoline issue in the Philippines is known form long before, its a given fact and I am sure all manufacturer's know this, actually they should not blame the fuel.
Isang term lang ang maisip ko sa reasoning nila..................."PALPAK''.
May 2nd, 2011 05:45 PM #29
Then why did other guy (zackek) with problems get a refund from the dealer rather quickly?
May 2nd, 2011 05:52 PM #30
Sayang wala pa 1.6 GLS Blue owner dito. Gusto ko rin malaman kung nagkaka-ganyan din sa 1.6 GLS Blue. Para yun nalang ang kunin than 1.4 A/T..
The assumption that the vehicle runs on the road, the ECU is more than likely a match. Try cleaning...
***HELP*** iding problem
