Page 385 of 404 FirstFirst ... 285335375381382383384385386387388389395 ... LastLast
Results 7,681 to 7,700 of 8077
    #7681
    another possibility is the belt. sometimes, tightening it solves the problem.
    Yup, the belt, too. But in this case, doc, it's replacement of the tensioner. There is no manual adjustment for the serpentine belt tension, spring loaded assembly na siya. Non-repairable, too. Oem part was p1500 a pop in banawe way back in 2010 when i had to change one on my then grx. It is still the same part number afaik. Actually it is interchangeable with the tensioner on a santa fe engine.
    Pag kumalampag yung tensioner then nadamay na lang siya. It will be some other bearing that has low/lost lubrication and the tensioner is just reacting to the added tension. Pag yan nangyari almost all bearings the serpentine belt passes need to be changed.
    #7682
    Slightly OT. i know timing chains eventually stretch and chain guides can become brittle and break. kaso if timing belt are to be replaced anywhere between 80t and 150t kms (toyota ata recommend nito). roughly ilang dapat kilometrahe palit ng timing chain? kasi kun 100t kms lang parang wala syang advantage sa timing belt maingay pa at mas mahal palitan? thanks
    #7683
    Although the ps pump is always the prime suspect (low ps fluid causes this noise) any bearing outside can cause a whining sound. So anything that the serpentine belt passes like the alternator, water pump, ac compressor and serpentine belt lunch tensioner must be checked. Try to pinpoint the source using a pvc pipe. With one end close to your ear point the pipe as close to any suspect part (pump, bearing) and if the sound is loudest then that is your prime suspect.
    Was thinking of buying an automotive stethoscope for this. Hehehe.. 250 lang naman sa lazada and magagamit ko din sa ibang kotse namin. Sakto due for PM next week imention ko na lang sa SA.
    #7684
    we have never replaced our timing chains.
    according to google, timing chains are expected to last a very long time. some even say it lasts the life of the car or engine.
    timing chains daw, are replaced when they show engine issues that are traceable to signs of timing chain wear.
    however,
    in my old sentra, the chain did not break, but the sprocket nut loosened, stranding me. the mechanic simply nutted it back on.
    but it cost me several thousand bucks... for the towtruck.
    sigh...
    Jul 2014
    #7685
    Good evening starex owners. Tanong ko lang ano gamit niyo matting? Medyo mahirap maghanap kung ano ok tapos medyo pricey pa. My unit is vgt with swivel seats. Thanks.
    Sent from my G8342 using Tapatalk
    #7686
    Quote Originally Posted by r-rod81 View Post
    Ah, now you made me miss my grx! The grx never had this problem because of its linoleum floor. Mop lang ang katapat.
    Meron deep dish sa import elements, 8k.
    #7687
    Ganda din nung Outlander deep dish matting ni Import Elements ah. Was eyeing the hive mat at almost the same price but this one looks better.
    Jul 2014
    #7688
    Nakita ko nga ganda nga deep dish. May nakita ako parang ok din. Blackliner. Nakita ko sa olx. 8.5k yata.
    #7689
    Parang mas maganda yung bkackliner, looks like velcroed to the carpet and for 10 seater starex. Mas mahal lang konti.
    #7690
    LSD ba ang Grand Starex? Managed to spin the rear wheels on a steep angled slope kanina. Sandali lang dumulas pero after a while kumapit naman...
    HVX model sir may LD or LSD ,, diko alam CVX, ilang ulit ko na naramdaman na gumagana siya, kaya nakaka ahon ang van, ang VDC or ESP ang alam ko sa brake system , gumagana siya pag mag skid ang gulong kaya meron mag brake na tire at meron tuloy lang sa ikot para maiwasan ang pag slide, at mabalik ng driver ang control sa vehicle,kung tama ang natatandaan ko,
    #7691
    Quote Originally Posted by midz+dem View Post
    Just here to share that now I'm a believer. Na ooblong pala talaga stock nexen tires. 34mos old 24T km. Balanced already but oblong cannot be cured by balancing pala. Irritating feeling.
    6 tires ang pinalitan ko sir, 4 nexen 2 hankook, nanawa ako kaka palit, 2yrs higit lang na ooblong talaga, alaga naman sa tamang hangin, last na pa check ko 4 oblong,kaya pala reklamo mga sakay ko nakaka hilo daw sa xpress,,haha, sa bwisit ko nag palit ako mags at 4 tires goodride, 2yrs higit na ok pa naman
    #7692
    Quote Originally Posted by bobdetondo View Post
    In my almost 15 years of starex experience, i never had to use Nexen tyres.... Only Kumho, Hankook and Michelin... No bad experience in any of them...
    #7693
    Ano kaya problema ng Grand Starex ko,
    Walang problema sa shifting pero yung paahon kanina sa starbucks sa Tagaytay kaya naman pero i tried it via sportronic na 1st gear lang pero kahit anong apak ko sa accelerator it won't reach 2000 rpm. What could be a problem [emoji848]
    Sent from my SM-J730G using Tapatalk
    baka naka limp mode, nangyari din sakin yan same place, kaya umahon pro sagad na apak ko 1500rpm lang, pag paahon din ako sa mga basement ganon din, kakahanap ng prob turbo actuator pala dina nagana, pinalitan ko ok na ulit,
    Apr 2012
    #7694
    Magkano ginastos mo?
    #7695
    Kumho in my tucson bumukol less than 3 years, hankook in my older g starex 3 years bago bumukol and lately yung nexen sa 2016 g starex ko bumukol nadin. All these korean tires will not last more than 3 years. Shifted to trazanno for my tucson, dunlop for my older starex and gt for my 2016 starex. Dunlop madulas sa wet road, maingay. For the trazanno znd gt too early to comment.
    #7696
    brought the van today to Hyundai Pasig for its 35t km checkup. Told the SA about the whining noise i hear everytime i start the van in the morning. Idler Bearings & Tensioner daw which is not covered by warranty. Was a bit dissapointed na hindi pala covered ng warranty ito.
    #7697
    Magkano na ang tensioner bearing assy?
    Apr 2010
    #7698
    Sad to hear that. Napatingin tuloy ako sa service booklet ko, but I can't find those parts in the "not-covered list" since hindi naman siya maintenance services and parts like the belt itself. If you replace the belt and adjust the tensioner at ganuon pa din, maybe you can try another bigger casa for the warranty. Or email HARI for clarification. Kung false promises yung written in the service booklet, maybe DTI should also know.
    #7699
    wear and tear items.
    good luck claiming warranty for them.
    Apr 2010
    #7700
    Not all wear and tear items are in the exclusions list. Shock absorbers, struts, stab links, ball joints, tie rods, racks ends, pipes, hoses, clips and mountings are under warranty. I was able to claim for one of my cars. Hoping those are also included.
2008 Hyundai Starex (Gen. 4)
