Page 366 of 404 FirstFirst ... 266316356362363364365366367368369370376 ... LastLast
Results 7,301 to 7,320 of 8077
    Nov 2007
    #7301
    Quote Originally Posted by bobdetondo View Post
    ganyang ganyan din sakin sa Casa,, nagpa check ako ng kumakalampag sa ilalim, nasa 65K daw magagastos ko,, nalula naman ako,, buti nalang may naka usap ako na naka starex din,, siya nagturo sakin sa paranaque,, may mekaniko pa sila non,, nagastos ko 5,700 lang parts and labor na, dami pang napalitan sa pang ilalim,, rack-end left and right,( yan ang kumakalampag ),,stabelizer 4pcs harap at likod, at 4pcs na rubber na humahawak sa sway bar ba tawag don, diko alam tama mga nabangit ko,,hehe, basta mga pang ilalim yan,,
    Tubong lugaw talaga mga hyundai casa.
    Ganyan kamura din sa fronte banawe. Good to hear meron din sa paranaque.
    May 2005
    #7302
    Besides the possible clogged brake line on the affected side, baka nga may “kink” ung brake line causing the brake fluid to not flow properly. Either sinasadya or di sinasadya.
    Another update on my brakes problem.
    I went to Goodgear in Pasay yesterday to have it inspected and if possible for them to do flushing.
    They looked at it and found no problem with the line.
    The chief mechanic, Arnel, advised me to go to another Hyundai casa for reset or reprogramming because it could really be the ABS module.
    He also said that OBD scans may not really get the ABS module problem. The appropriate tool is the scan tool of Hyundai.
    Goodgear does not have the ABS module but contacted another shop which sells it for Php 44k but without warranty because they will not install it. The said part is better installed by the casa because it needs brake bleeding with an instrument.
    I then went to Hyundai Manila Bay but the service advisor said that most likely they will also conclude it to be the ABS module also and advised me to save the money for the re-scan (?) to buy the needed part. They do not accept parts bought from outside.
    I am now at the point of deciding to buy the part from Hyundai and have it installed. Hyundai Las Pinas said they can give me 15% discount for the parts and P3500 for the labor. This will come to around P56k in all. It will just take 1 or 2 days to deliver the part.
    Any last minute advise/s from this forum will surely be appreciated before I commit myself to this expense tomorrow.
    #7303
    The thing is, casa “concludes” that the ABS module is the culprit for your dilemma. But, they are also not 100% sure that by pushing through with this procedure it will solve the problem.
    Hindi mo rin masisi ang casa kasi this kind of problem is uncommon so they wont keep a spare abs module to swap out for tests like this.
    Nagkataon lang na sa GS mo nangyari and you have to fork out a big amount to solve the issue.
    Since you already had a second opinion with reputable shops and they all seem to pinpoint the ABS module, for your peace of mind go ahead and replace it.
    Hintayin din natin sagot ng iba they might have other opinions about your case
    May 2005
    #7304
    Actually, fourtimes ko na kasi dinala sa Hyundai Las Pinas. Di ko lang nasabi dito earlier.
    The first time, they recommended re-surfacing of the disk which I had them done.
    The second time, they recommended replacement of suspension parts which I did not believe so I went to a Shell repair shop to have the suspension inspected and turned out that the suspension is solid. Pina-replace ko nalang ang brake pads sa Shell.
    The third time, I think Hyundai did the reprogramming of the ABS which seem to work after a few trips but it returned. I'm saying ''seem'' because I was able to use the unit a few times only (Sundays) and short trips lang.
    When I noticed that the front right side was not braking again, fourth time, they recommended replacement of the ABS module na.
    During the 3rd and 4th time, it took them quite some time tinkering with my GS before concluding the replacement. They might have done the re-set/reprogram during these times but I'm not very sure because I'm not allowed at the service area all the time. BUt during the last check, I saw them use a wireless tablet to diagnose the problem. Just don't know kung paano naka-connect sa GS yung scanner nila na wireless - bluetooth, WIFI, etc???
    #7305
    Quote Originally Posted by jrln View Post
    Or pwede rin sila nakasira ng abs module mo sa kakalikot nila. Try mo Hyundai Sucat, for a fourth opinion, but dont tell them anything, let them diagnose the problem if it will be the same abs module.
    #7306
    the abs module is an electro-mechanical device. di naman nabubuksan yun. a hydraulic tube connects from the brake master and 4 hydraulic tubes connect to the wheel brake pistons. there is also a wire harness that connects it to the computer box. there is nothing there that you can "kalikot" and go wrong. it is a solenoid valve block. pretty solid. UNLESS the valves are the ones that go wrong.
    my guess, and i am no newcommer to hydraulics, is that the particular valve going to the front right wheel brake is stuck closed. it happens. the thing with hydraulics is either there is pressure or not, or too low a flow to effect an action. there is no pressure because the valve is stuck closed.
    and no they do not do repairs on those blocks nor replace valves. i would if i knew the part numbers and know where they sell them. but the casa? fat chance.
    May 2005
    #7307
    You must have read my mind.
    Yes, I plan to go there tomorrow for a fifth opinion before I commit myself to the P 56k expense at Hyundai Las Pinas. Fifth opinion kasi magiging pang-fifth ang Hyundai Sucat tomorrow.
    So far, the opinions of the following sources are:
    Hyundai Las Pinas - replace
    Berima Diesel - ABS module not faulty
    Goodgear chief mechanic - replace
    Hyundai Manila Bay - replace
    #7308
    Quote Originally Posted by gastromd View Post
    Saan sa paranaque yan sir?
    green parts na name ng shop ,, natatandaan ko hospital ata katapat nila, kalimutan ko name ng kalye, pro pag galing ka naia terminal 2 deretso lang yung huling kanto pakanan bago umabot sa crossing ng coastal pa roxas babaybayin mo lang yon nasa kanan siya,,
    May 2005
    #7309
    thanks for the info.
    my concern now is what if it still does not work even if the ABS module is replaced? will they return the old unit and refund me the amount of the module assembly?
    Jun 2009
    #7310
    Noted sir. Thanks!
    #7311
    Most casas won’t give any guarantee in your case. Process of elimination lang yan. I’ll be dumbfounded myself if it still not the ABS module.
    Aug 2003
    #7312
    One of the global moderators at the Santa Fe Club Phils forum has a Hyundai GDS (scan tool). I'll try to get his contact number. He can scan your GS.
    Aug 2003
    #7313
    The GDS connects via wifi.
    whats the abs module partnumber? i can check the price in a few days..
    Nov 2007
    #7316
    *jrln: Id try to have 5th and 6th opinions with fronte banawe and asko banawe.
    No way that theyll refund you the 56k abs module if hindi pa rin maayos. By elimination na lang kasi sila
    Aug 2003
    #7317
    If I'm not mistaken, it's 58920-4H710. ;)
    #7318
    Quote Originally Posted by Automahn View Post
    http://ipartskorea.com/genuine-hydra...rex-2007-2015/
    #7319
    Napalitan naba brake fluid mo?
    When and where?
    #7320
    Quote Originally Posted by JJB View Post
    10000% correct, casa will never admit that they replaced a completely working part. They will always find another faulty part.
2008 Hyundai Starex (Gen. 4)
