Page 364 of 404 FirstFirst ... 264314354360361362363364365366367368374 ... LastLast
Results 7,261 to 7,280 of 8077
    May 2005
    #7261
    Hi to all,
    Pls help me on two items for my 2008 GS VGT A/T:
    1) aircon switch not turning on: went to Ceejays car aircon shop in Las Pinas and they said it's the aircon module inside the dashboard; I then went to Hyundai Las Pinas where the defective module was confirmed; estimate expense: P 16,981 for the module and P 2,314 for labor
    2) unbalanced front braking (RH side not working): went to Hyundai Las Pinas in August - they re-surfaced the disks which did not work; I went back to Hyundai which recommended replacement of suspension bushings which I doubted; I then went to Shell gas station about 1 week after to have the brake pads replaced and wheel alignment done which did not work too; went back to Shell which did brake bleeding and confirmed that RH side is not working and they referred me to Hyundai because it's a brake module which controls it; went to Hyundai Las Pinas and they attached computer to the unit and it worked; after 1 month, the unbalanced braking is back; now, Hyundai's recommendation is replacement of the ABS module assembly; estimated expense: P 62,345 for the assembly P 4,500 for labor and P 1,415 for misc materials
    Can you recommend an alternative solution without replacing these very expensive modules? Or do you know car repair shops which does repair of these modules at fraction of the cost to replace?
    Would appreciate any suggestion. Thanks much.
    #7262
    Quote Originally Posted by jrln View Post
    Hi to all,
    Try mo itawag sa Goodgear, Sering and Fronte. Sa Goodgear ako bumibili ng parts at nagpapa install, tinatawag kolang and then reserve sa date kung kailan ako pupunta. Sa Sering okay din kaso wala silang mekaniko, lumilipat pa ako sa Servitek sa unahan ng Sering. Fronte diko pa na try. Most cases, 40% of casa cost ang price nila.
    Ask kolang, nalubog ba sa baha GS mo?
    May 2005
    #7263
    Thanks for the suggested shops.
    I tried Goodgear before with a fuel filter but had to replace with original immediately after because the engine almost died on me uphill on a flyover.
    But will try them again with these parts. Hirap lang makakuha ng parking slot sa kanila.
    Hindi nabaha. Low mileage (53k only) and casa maintained for all PMS. I love how it drives kaya alaga ko. But now I'm a bit disappointed with this Hyundai.
    Thinking of selling it once I have these repaired.
    #7264
    Hi to all,
    after ondoy there were posted in olx shops that repair ecu, bcm and tcm units. i did a casual search in google, lumabas e berima diesel, ramsa electronics, haltech philippines and speedlab. i suggest do more research on these 4 and call them. no need to buy a new module if it can be repaired. sabi nga nga yumao kong tyuhin, "gawa lang ng tao yan kaya pwedeng ayusin. yung gawa ng Diyos lang ang di narerepair."
    May 2005
    #7265
    Thanks for the reply and, yes, I agree with your uncle.
    Will research on the shops you mentioned.
    Nov 2007
    #7266
    Just think na 9 yrs old na ang GS mo at lumalabas na mga sakit kahit low mileage pa sya.
    Actually known din na may mga maaga masira sa GS, from rubbers to electronics and big parts like turbo.
    Walang ibang magandang alternative sa GS kasi. Grandia, urvan or tepee ang mga choices lang
    May 2005
    #7267
    Quote Originally Posted by JJB View Post
    Am comparing it kasi with my previous cars before na walang problema tulad nito and we still have a 2005 Sorento CRDi in tiptop shape but with 105k kms already. Did not replace anything major on the sorento so far.
    #7268
    Alagang casa pala, sang casa madalas yan.
    May experienced na ako na tinira yung ABS sensor at pressure limiter ko sa casa.
    Yung 2016 GS ko, mas nasisisra habang sa pinapa PMS ko sa casa.
    Mahirap talaga parkingan sa Goodgear, kailangan itawag then agahan, madalas andon ako before 7 am.
    At that time may mga nakapila narin. Pag tinanghali ako, sa Sering ako dumederecho tapos sa malapit na Servitek ipapagawa.
    Nov 2007
    #7269
    Sorento has good long term reviews sa mga kaibigan ko. Wala daw major nasisira so far.
    Starex talagang marami nasisira. Suspension parts, aircon evaporator and leaking ATF hose nasira sa akin.
    Another friend had a broken timing chain at 80k kms only.
    Another friend had an engine swap, buti na lang under warranty sa standout
    May 2005
    #7270
    I used to have it serviced at Hyundai Pasig then transferred to Hyundai Las Pinas.
    Actually, I'm suspecting the same thing as what you said. Parang nasira lang nung pinaservice ko sa kanila a month or two before.
    I called Goodgear already. Ino-order daw nila mga parts na yan kasi bihira daw masira and they need the part numbers which Hyundai won't give to me.
    May 2005
    #7271
    We used to have a Hyundai Tucson as company car of my wife. Maraming issues din.
    Mahina pala ang parts ng Starex. Sayang, ang ganda pa naman tumakbo. Matulin saka comfortable to drive. It's my favorite actually among our vehicles kasi maski malaki sya ay madaling dalhin.
    If ever, this will be my last Hyundai.
    #7272
    Mukha ngang by order basis yang mga parts na kailangan mo, yung 2011 ko na GS hindi pa naka encounter ng ganyan problema.
    Cebu based yung 2011 na GS ko sa Hyundai AS Fortuna ko pina pa PMS, ni minsan hindi nagka problema naka ilang road trip narin yun from Cebu-Manila-Cebu, brake pads at rotor lang napalitan.
    Pero itong GS ko na 2016 na Manila base , wala pang 2 years dami ng lumalabas na sira, ang suspetsa ko talaga tinitira sa casa, kaya nilipat ko sa Hyundai Sucat, so far honest naman sila, hindi na nadagdagan ang sira.
    Kung parts number kailangan mo, try mo sa Sering, may parts manual sila, mas maganda kung pupuntahan mo. Dalhin molang yung work estimate ng Hyundai para makita yung parts na papalitan.
    Aug 2003
    #7273
    Try this site: PartSouq Auto Parts Around the World
    On the home page, no need to click on the Hyundai link. Just enter the VIN (Vehicle Identification Number) or Chassis/Frame Number of your GS on the blank at the top then click search.
    The parts catalog you will see is specific for your GS model. Eksakto yung mga part numbers na makukuha mo diyan. :-)
    #7274
    Hi to all,
    As far as i know normal braking has nothing to do with ABS. ABS only reacts when there is a tendency for the wheels to lock when braking.
    Have you checked whether the brake piston on the “uneven” side is stuck?
    Another thing you could do is flush the whole braking system.
    May 2005
    #7275
    Thanks for the replies and tips.
    Will update you later on this.
    #7276
    well it does because the 4 brake lines going to the 4 calipers all go through the abs module. if the particular valves inside the module to that caliper are malfunctioning then that brake will not work properly.
    i suggest you google "abs schematic diagram" so you can see that the abs does indeed control all the brakes even when there is no brake lock involved.
    #7277
    I stand corrected then. Thats why i always say “as far as i know” palagi. [emoji16]
    Baka makuha pa sa brake fluid flush. O baka stuck up ang piston. In car troubleshooting i always replace the cheapest first kung hindi obvious ang problema
    #7278
    or as simple as wrong grease used on the caliper.
    #7279
    09 VGT matic GS ko ,, 107K na odo ,, napalitan sa engine bay =brake master, turbo actuator at Egr palang, (Egr nadengoy lang ako nga Casa,pinalitan daw ng bago, pro wala ako nakitang bago,luma parin nakakabit, singil 15K) ,,
    Apr 2012
    #7280
    What would you suggest?
    Nag oblong yung isang Kumho ko so pinalit ko yung Nexen na spare ko na sobrang kapal pa. Should i buy a cheap tire for spare o hanap ako ng second hand na same tire na lang? Sa spare ko lang ilalagay naman.
    Sent from my SM-J730G using Tapatalk
2008 Hyundai Starex (Gen. 4)
