Page 342 of 404 FirstFirst ... 242292332338339340341342343344345346352392 ... LastLast
Results 6,821 to 6,840 of 8077
    #6821
    ∆∆∆ Samahan mo pa ng Curved TV....
    At Kabayo (ng plantsa)...
    #6822
    yung kama nga kasya e. tignan mo yung gs ng st. peter.
    #6823
    Walandyo bro.
    Last trip iyan, pantay ang paa....
    Puwede pala kabayo, - itali at hilahin sa labas....
    May 2012
    #6824
    Hahaha..loko kayo mga sirs
    Sent from my SM-G610Y using Tsikot Forums mobile app
    May 2012
    #6825
    Malapit ng mag 5yrs GS namin....36k+ pa lang tinatakbo😊
    May 2012
    #6826
    Saan kaya makabili ng ganitong emblem😀
    #6827
    Went to Hyundai Pasig to reserve our Grand Starex na. 1 week lead time for unit delivery.
    Snapped some interior and exterior pics of their spare units on the dealer yard.
    May 2012
    #6828
    May 2012
    #6829
    Trip lng kaya ng may ari
    #6830
    Quote Originally Posted by skyflakes View Post
    Daig ka ng lolo ko bro.,
    Iyong GS namin 7 years na,- 37K pa lang tinatakbo...
    Bumili lang ako ng malaking paperweight sa garahe namin...
    _/_/_/
    32.0K _/_/_/_/_/_/_/_/_/_/
    #6831
    Nakakatakot namang sumakay riyan,- parang masusubsob...
    _/_/_/
    #6832
    ....why..?
    Nov 2007
    #6833
    ....why..?
    If you can't perform, japorm [emoji23]
    #6834
    Hi guys meron ba kayong copy or link ng site para maka download ng service/repair manual ng grand starex? Thanks in advance...
    #6835
    no such animal bossing, no atf filter on the grx and the gs. there is a strainer inside the tranny but this is made of stainless steel wire. you'll need to open the bottom cover of the tranny to get to it to clean it.
    i found this out the hard way when my grx was flooded, bumili ako ng "filter" worth p2500 yun pala washable naman. the thing was nilista lang ng hyundai balintawak sa job list e wala naman ako alam during that time na strainer pala itong filter na to.
    good day po,, ,,, sir yebo wala tranny filter ang GS? strainer lang? may naka pag sabi kasi sakin baka barado ang tranny filter kaya need ko palitan, so kung strainer lang meron nagbabara din ba yon? kelan siya need nililinis? napansin ko kasi pag bigla ang apak o tuloy tuloy apak sa gas pedal yung Rpm lang ang umaakyat, yung speed mabagal,delayed mag shift,kahit mag manual din,, pro pag normal apak sa pedal ok naman ang shifting niya, kahit sa manual gumagana lahat ng gear,, basta pag binigla lang ang apak dun siya delayed sa shifting, kaya naiiwan ako sa arangkada, parang ang fourth gear ang ayaw agad pumasok,, bagong calibrate at repair ang 4 injectors, na check narin ATF ,naka blank na EGR, HVX 09 matic nga pala GS ko,, salamat po
    #6836
    Quote Originally Posted by bobdetondo View Post
    strainer lang. need open yung bottom transmission cover to access. nalilinis using any degreaser or cleaner.
    pero baka hindi lang yun ang problema mo. ilan na km sa odo? baka worn out na din ang friction belt ng planetary gear o barado solenoid na nag-activate ng belt kaya delayed ang reaction.
    #6837
    102K klm odo na GS ko sir yebo ,, napa check ko narin sa friend ng kapit bahay naming na koreano na may obd na Malaki, ok naman daw lahat ng sensors, pati engine sounds normal naman daw,, sabi sakin ok mga solenoid pro nga baka barado ang valve body ng tranny,o filter,, yun nga kaya yon?
    #6838
    well kung papacheck mo yung strainer palit atf na din yan. ganyan nangyari sa tranny ng grx ko dati na-ondoy kasi kaya barado yung strainer. kahit nagpalit na ng atf 2x mabagal pa din arankada. ok naman after mabuksan.
    hopefully strainer lang. di ko lang kasi maisip san galing ang dumi kasi sealed na ang tranny ng gs kung hindi sa friction belts.
    #6839
    yun din iniisip ko sir sealed naman ang tranny,, pro tulad ng nabangit mo galing nga daw yun sa tranny mismo ang mag papabara don,, inisip ko na ATF lang need palitan,pro wala nagbago,, may nag sabi rin sakin na dapat pa dialysis daw,, makukuha ba ang mga bara sa dialysis?
    #6840
    no. need talaga open yan. madali lang naman basta may vehicle lift yung talyer na gagawa.
2008 Hyundai Starex (Gen. 4)
