Nice! Motul ATF is indeed Red-1 as seen in the spec sheet! Sana meron din sya sa S&R para isang bilihan nalang with the Oil.
Pero sabagay, minsan lang naman ang ATF dialysis so I guess pwedeng puntahan nalang mismo yung Autoplus.
Update: I just called Autoplus and they told me that the Motul Multi ATF is priced at P1,440/liter (OUCH) - and it's out of stock. Mga october+ pa daw ang dating.
Around how many liters ba kaya ang kailangan kung papa dialysis ko? (FYI - Dialysis labor cost sa Autoplus is P1,950) - mas mura sa Fronte and sa Servitek.
You can use Castrol transmax multi vehicle ATF for the GS. That's what a few tsikoteers are using here including myself. Red-1 of hyundai and Kia is equivalent to Nissan matic-J. Castrol meets both. Around 330php/liter iirc.
I emailed Castrol philippines for a dealer near me. visit mo website nila. Tel: +63 (2) 884 1478; contact*castrol.com.ph
Sayang talaga. Nasa huli pagsisisi. 😫
Ok lang yan sir kahit 30 or 40 wt if you change oil at 10Tkms or less. Potentially mas matagal mag shear to a lighter weight yung 40 kasi mas malapot sya pero in theory lang.
Re: Motul ATF yup ginto talaga. Sabi mo kasi sir if cost is not an issue hehe. I also use Castrol transmax multi vehicle on the GS because it is cheap.
Will try Zic on the GS for the next ATF change.
Just had the 5k checkup of our HARI GS sa Hyundai Pasig. 2.5k lang inabot kasi top-up lang ng engine oil. Pero palit ng oil filter.
Nakalimutan ko sabihin ung issue sa brightness adjustment ng gauges. Ipabalik ko na lang next week kasi warranty claim iyon.
i think thats the same guy that sells RP oils
1. I use Zic x7000 CI-4 fully synthetic diesel oil, paired with original or sometimes baldwin. Kapag Baldwin pinaabot ko 7k kms. Pero pag original filter 5k kms lang.
2. ATF, i use ZiC fully synthetic SP-IV. I called Hyundai about this one, they told me na SP-IV daw gamit ng casa nila. Sa Hyundai Sucat to.
3. Brake pads, original lang gamit ko. But will try Brembo OEM next time.
4. Rotors, never replaced pero baka original na lang din for confidence.
5. Shocks, KYB yata okay din.
6. Tires Kumho Portran KC53 gamit ko. Yung Nexen ko noon nag oblong kaagad.
Sent from my LG-H818 using Tapatalk
I would still choose GS anyday kaysa sa mga Hiace. Pero can't deny na mas okay talaga pag ilalim ng Hiace kahit yung commuter variant lang nila.
Time really flies, 8 years na pala yung GS ko, no immediate plans of replacing it as of now. Papalitan ko lang yan kung mag labas ng bagong Starex or Hiace, pero balita ko sa next gen Hiace sa harap na daw ang engine, if that is the case I'm leaning towards the Hiace, although ok naman ang Starex, talagang mas matibay pa rin ang Hiace
Looking for floormats for the GS. Are there ready made ones for the GS? Or they have to be custom made?
Maganda sana yung Hippo Techmat brand. Or any brand that has the same design.
Kaya minsan mas maganda magtanong sa forum kaysa sa casa.
Re ATF, nagresearch din ako for the appolloil red-1. May reply 1 company sa 1 forum na equivalent sya sa nissan matic J. May isa ring local hyundai technisian sa hyundai local forum nagsabi na sp-IV ang ginagamit sa GS vgt.
Castrol transmax meets both specs kaya yung ang pinili ko. Sya rin pinakmura at 330-350/ liter. Zic yata is at 450 and not sure if red-1.
Ito pala spec sheet ng castrol transmax multivehicle. Red-1 is under subaru.
