Page 346 of 404 FirstFirst ... 246296336342343344345346347348349350356396 ... LastLast
Results 6,901 to 6,920 of 8077
    Nov 2007
    #6901
    Balitaan mo ako kung san ka papagawa sir ah. Positive kasi may leak unit ko nawala lamig ulit. Wala pa ako time pa ayos.
    Pero ng inquire akosa Home service at enough to gave me heart attack ang presyuhan hehe
    6800 ung labor lahat lahat. Flushing full refrigerant refill etc.
    Eto malupit sa parts price:
    Front evaporator 8500
    Rear 7800
    Drier 1650
    Front expansion valve 4500
    Rear expansion valve 4800
    Set oring (WURTH BRAND) 500
    Makatarungan ba na price yan?
    Sent from my LG-H818 using Tapatalk
    Nagawa na today unit ko sa frigidzone kamias. Paid 14k total. Una, cleaning ng dual AC is 5.5k. Nakita na may leak sa evaporator which costs 8.5k to replace. Original daw yung evaporator, hindi daw kaya repair ang old one. Hindi na pinalitan mga expansion valve. So I guess talagang 8.5k ang evaporator, but linibre na freon charging din. So far constant ang lamig naman but observe pa rin.
    Apr 2012
    #6902
    Quote Originally Posted by JJB View Post
    Wow punta nga ako diyan. Pwede ba kahit papaano. Unlike dun sa quote sa akin
    #6903
    Kasama na sa cleaning charge yung freon sir
    Dec 2009
    #6904
    Ano ang refrigerant specification ng aircon ng starex?
    It can be found on the manual
    Sent from my GT-P3110 using Tsikot Forums mobile app
    Nov 2007
    #6905
    Didnt have time to canvass na since naiinitan mga kids ko and matagal na ako nagpapagawa sa frigidzone so trusted ko na sila. Pinakulit ko lang sa driver at pumayag naman sila na evaporator lang palitan and pwede pa raw ibang parts. May 2 leak sa from evaporator. Never knew na 2 pala evap ng starex.
    #6906
    Alam ko R134A pa rin ang freon ng mga kotse 1990 pataas.
    Dec 2009
    #6907
    ^thnx for that info
    Now how many grams or g for the quantity of refrigerant in a starex?
    Its in the manual alright
    The reason im asking, kapag nagparecharge kayo ng refrigerant this is the specification that needs to be followed
    The bigger the car the higher should be the amount of refrigerant
    Thats how one owner could protect themselves from a raw deal
    #6908
    That one i have no idea. Baka nasa owners manual
    #6909
    [QUOTE;2814696]^thnx for that info
    Sent from my GT-P3110 using Tsikot Forums mobile app[/QUOTE]
    how does one know, just how much refrigerant was put in?
    Nov 2007
    #6910
    What i know is may pressure range ang refirigerant sa car ACs that you need to measure with proper gauges
    ^thnx for that info
    it could be only 25g but nobody weighs refrigerants in the Philippines. 25g is for some refrigerators
    most ac specs only provide highside and low side pressures.
    Apr 2012
    #6912
    Aside from evaporator ano pa gusto nila papalitan na parts? Ilang hours ginawa?
    Dec 2009
    #6913
    Thats what im trying to figure out myself, my current ride is a mirage hatchback and the refrigerant volume for such a car is 250 to 290g already
    If i need to recharge it, it doesnt need to be refilled by the same amount unless the coolant is completely depleted (the air con does not get cold at all)
    The most important thing to know is how to measure the volume of the coolant because refilling means restoring it back to the specified volume. Any thing less is a raw deal
    Hence, i reiterate my question how much is the volume of the refrigerant in a starex air con system?
    Dec 2009
    #6914
    g is a metric unit for mass and it indeed stands for as gram
    Since gas has density and is measured in terms of mass over volume, then we can derive the volume of the freon gas with mass as given in the manual specification sheet
    If the latest starex contains pretty much less volume of freon, for a car this size then that could be the reason why its air con coolness doesnt last that long
    #6915
    What's funny is most a/c service shops will charge you for refrigerant recharging even if you don't have a leak. They basically resell to you the old refrigerant they harvested from your a/c system.
    #6916
    ^^^ I trust the ac shop. Or the feel of the air...
    If we have the means, weigh the vehicle before filling the ac system with the refrigerant. Then weigh if after...😉
    May 2012
    #6917
    Ang charge ng freon per kilo
    Sent from my SM-G610Y using Tsikot Forums mobile app
    May 2012
    #6918
    Kaya ako alaga s linis ng tubig at hangin ang condenser sa harap para iwas muna sa malaking gastos
    May 2012
    #6919
    Quote Originally Posted by skyflakes View Post
    Pati cabin filter...alaga dn s linis,lublob lng sa detergent soap, banlawan at ilagay sa dryer ng washing machine..ayos na!😄
    May 2012
    #6920
    Yun nga palang evaporator ng GS tci...6700front at 6200back sa seiring araneta ave.
2008 Hyundai Starex (Gen. 4)
