Page 331 of 404 FirstFirst ... 231281321327328329330331332333334335341381 ... LastLast
Results 6,601 to 6,620 of 8077
    #6601
    Quote Originally Posted by Eiso View Post
    I was thinking on getting the rear wing. Kaso masyadong mahal at medyo useless ang rear wing and im aiming for additional safety.
    Kaya I decided to get the OEM third brake light alone.
    IMO bro.,- you made a very good decision! [I would have made the same if the OEM light was available six years ago,- it was not. And bro.yebo I think had it imported. And so, I had no choice but to get the rear wing with the third brake light]
    _/_/_/
    30.2K _/_/_/_/_/_/_/_/_/_/
    #6602
    same reasons, price and usefulness. useless naman talaga yung rear spoiler.
    #6603
    At, puwede pang maging cause ng leak.... I had it on the first day,- kaya giniyera ko ang Hyundai...
    _/_/_/
    #6604
    Quote Originally Posted by Sindong View Post
    Sir ilang kms nung nag pa change ATF kayo?
    Sent from my IMBA_S5_v2 using Tapatalk
    40000 km ang atf change ng hyundai and kia pero lumampas ako ng konti, a little over 42000 km na. the atf was already color dirty red (blackish hue na). better spend 10k on atf than 150k on a new tranny.
    #6605
    Bro.,- if you're visiting your parents here in the area,- maraming services na ganyan along Zap-Alab Rd...
    Customer Cradle in front of Perpetual Hospital offers this service.... [I engaged another gas station near our village for this, though]
    40KKm for the ATF change.....
    Iba ang AT ng VGT[5-speed] at ng TCi[4-speed],- and so, iba ang kanilang volume requirement, right?.....
    TCi ang sa akin,- ilan kayang liters ang kailangan kong dalhin?
    _/_/_/
    Hey bro! Musta? I'm at close to 45t kms, kaya palitin na ang ATF and gear oil.
    Sent from my Motorola Startac
    #6606
    Porma lang actually. Can do without it.
    #6607
    Yikes! Papalitan na po! [emoji4]
    Btw, anyone encounter problems with their front power locks (not locking) and door switches (not registering that doors are closed)?
    Nov 2007
    #6608
    Matagal nang site mga door sensor ng unit ko. Driver side na Lang gumagana with the ceiling light. Pati driver power window switch nasira na rin.
    Nov 2007
    #6609
    had mine done before i sold it using dialysis method. total 15 liters. di pwede drain and fill lang di makukuha yung nasa loob ng torque converter. it took 10 liters before the oil draining out started to clear and was perfectly clean after 14 liters. The extra 1 liter is for insurance.
    What atf fluid ginamit mo? Tama ba Zic atf SP-IV ang equivalent ng red-1? Yung castrol multi vehicle is SP-III only
    Apr 2012
    #6610
    Quote Originally Posted by JJB View Post
    Yeah that's what i used when i changed mine
    Sent from my LG-H818 using Tapatalk
    Nov 2007
    #6611
    Thanks again. Time to look for a shop with dialysis near Katipunan.
    #6612
    Driver's door bro.... kapag nababad sa init na araw, ayaw mag lock o bumukas.... Else, okay naman, and so i always double check...
    #6613
    Sent from my LG
    Thanks for confirming bro.
    I'll start looking and stocking up on the zic atf sp4 as our unit is over 35kkm now. I'll check if our tci at uses the same atf as that of the vgt at
    Apr 2012
    #6614
    I'll start looking and stocking up on the zic atf sp4 as our unit is over 35kkm now. I'll check if our tci at used the same as that of the vgt at
    I think yours is sp3 compatible! I'll check sa manual later
    #6615
    Just a thought. Dialysis coz di daw natatanggal yung nasa torque converter.
    What if you did the regular ATF change but at a shorter interval, di kaya maghahalo na din yun at maisasama sa pag-drain?
    #6616
    Re door switch, had to have the driver's door and passenger sliding door replaced. Baka rear door na sunod.
    Front door locks had to be repaired this year. Ayaw maglock/unlock with the remote. Diagnosis nung electrician ko is ubos na carbon nung motor. When he got through with it, buhay na ulit pareho. Although, di na umiilaw yung signal light to acknowledge the doors are locked via keyless.
    Strange that I haven't had these problems with my Jap cars previously.
    #6617
    pwede naman bossing drain, fill up, run for few kilometers, drain, fill up. the end result will be a much cleaner atf compared to just a single drain and fill. pwede na diy.
    #6618
    I know, medyo tedious din nga naman especially if always on the go.
    Yung dialysis kasi takes up mga twice or thrice the amount of a drain and refill kaya medyo masakit. so if one had the time and chance, tyagaan naman with shorter intervals.
    #6619
    That is actually a novel idea, bro....
    I just have a couple of questions,- what's the approx volume of the ATF in the torque converter? what is the approx volume of ATF overall? With this, we can compute for the purity of the ATF after x drain/refill, assuming the ATF becomes homogeneous after X Kms of driving....
    _/_/_/
    30.3K _/_/_/_/_/_/_/_/_/_/
    #6620
    Hehehe! Now that's the tricky part to this theory. How long before it'll actually work...
2008 Hyundai Starex (Gen. 4)
