^^^ Basta iyong sa amin, OEM central lock and alarm...
29.9K _/_/_/_/_/_/_/_/_/_/
Mga sir, question lang po..
Reasonable ba na gumastos ng almost 100k parts and labor para sa clutch component ng grand starex 2010 model crdi?
Need recommendations and suggestions kung saan shop magaling gumawa outside casa. Thanks in advance.
Guys, ano kaya problem if driving sa curved road and the steering has resistance? Parang kumakabig sa other way. TIA
Happens when turning slightly sa long curved but even road. Let's say you're turning the wheel to the right and kumakabig sya to the left. Will have wheel alignment done. Thanks!!
Also, how much atf do we need for a drain and fill ng vgt Starex? Will have the atf changed at 80k kms instead of manual stating 200k kms iirc
Hey Guys!
Alarm, sticky doors, defective door sensors and ATF change. Sapul lahat ang balak kong ikonsulta.
Sent from my Motorola Startac
had mine done before i sold it using dialysis method. total 15 liters. di pwede drain and fill lang di makukuha yung nasa loob ng torque converter. it took 10 liters before the oil draining out started to clear and was perfectly clean after 14 liters. The extra 1 liter is for insurance.
powertorq motors at congressional avenue. it is owned by a fellow tsikoteer (inactive, forgot his name). dun din ako nagpapa-oil change and brake flush, dealer siya ng motul and liquimoly oils.
PowerTORQ Congressional | Facebook
check mo na lang to.
Bro.,- if you're visiting your parents here in the area,- maraming services na ganyan along Zap-Alab Rd...
Customer Cradle in front of Perpetual Hospital offers this service.... [I engaged another gas station near our village for this, though]
40KKm for the ATF change.....
Iba ang AT ng VGT[5-speed] at ng TCi[4-speed],- and so, iba ang kanilang volume requirement, right?.....
TCi ang sa akin,- ilan kayang liters ang kailangan kong dalhin?
_/_/_/
30.2K _/_/_/_/_/_/_/_/_/_/
Looks nice bro...
I actually like that vs. the one I have, which is mounted on the rear wing....
Si bro.yebo,- ganyan din ang kanyang third brake light nuong kanyang unit (but it was already sold)....
_/_/_/
