Page 333 of 404 FirstFirst ... 233283323329330331332333334335336337343383 ... LastLast
Results 6,641 to 6,660 of 8077
    #6641
    Quote Originally Posted by Wh1stl3r2 View Post
    4 years of Euro 2 fuel and mostly city driving was really bad for the egr.
    kaya ako basta diesel ever since lumabas ang euro4 di na ako nagfi-fill up ng euro2. the worst of the big 3 is petron diesel (mausok) followed by shell (low power, mabilis maubos). pag walang-wala na talaga naghahanap ako ng caltex. even now that petron say they are euro4 medyo mausok pa din ang regular diesel nila. yung dieselMax ok lang kaso mahal naman.
    Oct 2015
    #6642
    I think uusok pa rin talaga at load bro. Sa Europe may nakita akong Euro 5 engines na mausok. Ang hirap linisin ng egr ng Euro 4 GS, masikip yung side na dinadaanan ng egr. I wonder how the early examples of GS with Euro 5 engines are doing. 2011 yung amin pero meron na rin lumabas Euro 5 the next year. Matagal tagal din nakagamit mga 2012 models with Euro 5 engines ng Euro 2 diesel.
    Apr 2012
    #6643
    Sorry I missed this thread. Suspension was finally fixed by Fronte. Turned out to be a couple of bushings and stab links. Fronte only does the work in their parking area but at least the mechanics know more about Hyundais in general.
    GS had low power going uphill so I had the egr cleaned yesterday. Sobrang barado na. Egr tube, valve and intake manifold were all gunked up. So was the cat converter. 4 years of Euro 2 fuel and mostly city driving was really bad for the egr. I didn't have it blanked as it still had Hancars "warranty". It now runs like new.
    Next up will be the intercooler.
    Marunong na sila maglinis ng Euro5? 2 years ago i brought mine sa Goodgear di nila kaya pa. Iba daw kasi engine
    Sent from my LG-H818 using Tapatalk
    Jun 2012
    #6644
    No need clean the egr pag euro 5 di ba? Dahil may dpf. Tama ba?
    Sent from my SM-G920F using Tapatalk
    #6645
    Quote Originally Posted by dct View Post
    afaik need pa din boss. hiwalay function nun. yung egr recirculates the exhaust back to the intake manifold to lower engine combustion temp which in turn lowers NOx production. yung dpf nasa exhaust pipe mismo, it catches the sulfur soot from the exhaust. nagre-regenerate siya, burning the soot by injecting diesel into the dpf. yung dpf is positioned after the egr inlet e.
    Oct 2015
    #6646
    Forgot to mention sa casa ginawa yung egr cleaning, went back to Hyundai Cainta. No choice, sila lang kasi malapit sa amin. They did mention the Euro 5 engines's egr layout was easier to clean. We did the catalytic converter and exhaust cleaning at home. Ganda ng takbo after.
    Kelangan pa din linisin sir if you haven't blanked it. Specially if it spent a lot of kms on Euro 2 fuel we had prior to this year. DPF simply catches all the soot so it doesn't go out the tail pipe. It is downstream of the egr. Will get back to you re: brake pads. I'm testing a new set right now. We also replaced the front rotors last week.
    Jun 2012
    #6647
    Kailangan na rin replace ng rotor? Madugo ata gastos sir ah. Ang dami
    Oct 2015
    #6648
    57 Tkms na din natakbo sir, also mahina talaga parts ng Hyundai compared to Japanese makes. We also had a Tucson before, replaced front and rear rotors at 45 Tkms. Pwede pa naman gamitin yung rotors pero lampas na sa recommended wear limit which is 2mm. Mahina na kumagat.
    Jun 2012
    #6649
    Ouch. Kailangan pala paghandaan
    #6650
    San ok magpatingin ng A/C ng GS? Nabilad kahapon, matagal lumamig.
    Sent from my Motorola Startac
    Aug 2003
    #6651
    Try mo munang papalitan yung A/C filter.
    Nangyari rin dati sa GS namin yan. Di ko akalaing madumi na yung filter kasi less than 6 months pa lang mula nung huling pinalitan ko.
    Nung napalitan yung filter, naging ok naman, mabilis na ulit lumamig kahit nabilad yung sasakyan.
    Nov 2007
    #6652
    Quote Originally Posted by Automahn View Post
    Agree that mabilis magbara AC cabin filter. Few months pa lang, madumi na agad.
    May nakausap ako na mayari ng car shop noon na pinaka-important sa aircon na para hindi masira ay dapat malinis parati nag AC cabin filter.
    #6653
    Palit ba kamo, bro? Wow!
    Iyong sa akin nga 20KKm pa lang,- recommended na ng Hyundai,- refacing ng rotor...
    Nagpalit na lang ako ng pads,- kaunting liha,- tapos preno ng bigla.... Okay na...
    _/_/_/
    30.8K _/_/_/_/_/_/_/_/_/_/
    Oct 2015
    #6654
    _/_/_/
    Malaki na kasi nawala sa braking power bro. I thought of getting Brembo or DBA rotors para mas tumagal but the current state of BOC is scaring me from bringing anything in. They're replacing declared value with the highest online srp of items they can find.
    Ok pa naman brakes kahit over wear limit na yung rotors, hirap lang sa long drive na pababa or twisties, nagfafade na sya. 20Tkms I think too early to reface but you never know, stock rotors are like butter. Dami ka bang long drive/uphill-downhill trips?
    #6655
    Siguro nga bro.,- before it hit 20KKm,- apat na biyahe sa Baguio; 2 sa Quezon Province via the mountain road of Atimonan; at isa sa Bicol... Our ride is now 35KKm and I don't do long drives as I used to before, because of our kids' school schedule/assignments ...
    Siguro, next time when you travel,- you buy those stuffs and bring them in na lang.....
    _/_/_/
    May 2012
    #6656
    pag automatic trans. malakas talagang kumain ng front brake pads,tested na talaga yan
    kaya pag umabot na ng 10kms..silip silip din pag may time☺
    #6657
    Malakas pa naman yung buga. Pero sige will try that muna. Cheaper than repair [emoji4] thanks!
    #6658
    Agree with automatic transmissions being hard on your front brakes. Thankfully, nakukuha pa sa brake pad replacement.
    Come to think of it, need to check na din pala.
    #6659
    Same with me bro. Ours is already 35kkm and so should be at 40kkm...
    Any difference in usage rate between the OEM and the Hyundai pads bought from Goodyear? What I have now does not produce brake dusts....
    Oct 2015
    #6660
    _/_/_/
    Wow low mileage pa pala yung sa yo bro. I used to take that Atimonan route to Naga. Wala kasing trucks masyado. Same as you din, I don't drive on long trips anymore, pagod na haha.
    Wish I could bring in some rotors, hirap lang, mabigat. Maybe 8-9 kg/pc?
    Quote Originally Posted by skyflakes View Post
    Yep. Doesn't help that the GS weighs 2 tons+. Sana ginawa na lang nila 17" rims lahat ng GS para makafit ng bigger front discs.
2008 Hyundai Starex (Gen. 4)
