Team FD,
Pwede patulong, baka may kilala kayo marunong magayos ng problema ng FD ko.. thanks
Continuous blinking / resetting behavior of all gauges and display panels.
finally done the recall
Sent from my SM-G925I using Tapatalk[/QUOTE]
Team FD,
Team FD,
punta ka sa j6 sa banawe along kaliraya street. diyan puntahan ng team fd kapag may problem iyong electronic dashboard ng mga members
traveled 850kms yesterday and managed a 14.5km/liter on 91ron
Hi, I'm a new owner of 2010 Civic 1.8s at around 60k km.
Just did an oil change last sunday, fully synthetic. Shop also did some check ups and found some problems and things need to be replaced. Cost estimate is high, around 40k for everything. Another shop quoted me around 7k (but not as complete as the first one). To lessen cost, I know some mechanic who can do home service but I need/want to provide parts. The only store I know is Alabang Auto Parts, in front of good year. I'm residing in alabang area too.
Here is the list of parts / repairs I need:
1. Cracked bushings
2. Tie rod, rack end
3. Iridium spark plugs (I want iridium too, ngk, as said in manual)
4. Braked pads and resurface rotor
5. ATF change or flush. The current on seems never been changed nor flushed and it is color brown. Manual says ATF Z1, can I use ATF DW?
6. Cylinder head cap and valve gasket, may leak kasi
7. Cabin filter
8. tail light bulb (yung nasa boot lid)
9. Tail light
I need your help guys.
1. Is my plan ridiculous? (home service repair but buy parts myself-a noobie, as much as possible I want to buy with someone knowledgeable but... ), or just shop so wheel alignment is immediately done
2. How much these things usually cost? Is this all the parts I need? (especially the tie rod / steering parts.
3. Do you other part stores near alabang area, laguna is fine,
4. Do you any reputable shops that I can trust? (plan do build long term relationship, cheesy I know)
Thank you very much.
100k ang palit ng plugs..60k is too early
my fd 09 1.8 is nearly 160t kms only major problem was the top engine support, replaced front rotors and rear bearings...yun pa lang.
DIY mo na lang atf, PSF and Brake fluid change...
for bushings, cruven sucat. P600 bushing, 450 ang labor.
JP wheels for tie rod, rack end.
pag engine, benmawi
I see, sabi kasi sa manual "Replace every 3 years or 60k km and check every 1 year or 20k km." Kaya medyo decided na magpalit. Medyo nakita ko din naman na madumi/luma na though not really a close look, di pa din naman ako confident sa judgement ko eh. Nagtataka din ako nung nalaman ko ng 100k ang lifespan ng iridium pero sabi sa shop need to replaced na raw at sabi sa manual replace every 60k (car is now 64k). Anyways, patignan ko na lang ulit sa matinong shop/mekaniko then palinis muna pag kaya pa. Di din ako confident gumamit ng hindi iridium, may mga nababasa din ako na as much as possible kung anu sabi sa manual/manufacturer.
About sa gas, dami pa din naman factors to consider, isa lang dun yung spark plugs ayon sa research ko. First, my driving habits, nabasa ko na wag masyadong galit sa acceleration, well dumating nako sa point na ang bagal ko mag accelerate at inoovertakan lang ako at binubusinahan nako ng mga nasa likod, hahaha, iniisip ko na lang defensive drivng :P. 2nd, front tires need to be changed.
Eto po yung trips ko, 9km 20-30min drive, light to moderate traffic, usually traffic lights lang ang stop. Daang Hari-Commerce Avenue, before 7am and 4-5pm (before rush hours), so around 20km everyday, for 5 days. Costs around 500-600 on gas per week. Shell Vpower. Is it normal or tanggapin ko na na malakas sa ito sa gas? di ko pa macompute fuel economy ko, lagi ko nakakalimuta i reset yung meter hehe.
Wow, thank you sir! Ang dadali puntahan! Ang laking tulong po nito
Wala ako tiwala sa previous owner/s. Parang oil change lang ang ginagawa. Even yung cabin filter, empty nung nag check ako.
off topic: I am new in tsikot (pero matagal na ako nag register)
1. Talaga bang maliit ang message box?
2. Talaga bang di nagana ang edit?
Thanks!
^ best way talaga to know your car's fuel consumption is through the full tank to full tank method. or you can use apps like waze and the like although it works hand-in-hand w/ the full tank method
it seems that hindi naman kalayuan daily drive mo kaya hindi talaga magiging efficient ang konsumo mo bro especially a/t pa ang drive train mo.
ok naman ang alabang parts ctr. suki ako sa sister store nila sa las pinas (atco) and they're pretty dependable. pero sa customer's cradle las pinas na ako nagpapa-ayos o install ng mga parts na nabili ko since kumpleto gamit nila at experienced din ang mga mechanics nila
Looking into FD for light track racing. Okay ba mag k20 manual? How's the parts price and availability compared to the r18 manual? Also malaki ba difference sa power?
My options are :
1. 2006 k20 manual - mahirap mag hanap ng sariwa
2. 2011 r18 manual - easy to find
Thanks!
