Page 35 of 65 FirstFirst ... 2531323334353637383945 ... LastLast
Results 681 to 700 of 1292
    #681
    Saan ang possible oil leak location usually pag may traces of oil sa garage floor?
    First time kong nakita sa 2010 civic namin this morning. Tried lookin underneath but ground clearance is tight.
    Dadalhin ko mamaya sa servitek.
    Update lang mga bros.
    Damaged oil filter is the culprit... hindi siguro maganda ang lapat at sobrang higpit ang ginawa during the last oil change.
    Vic oil filter ang available sa aking suking shop kaya yun ang pina-install ko. But bought 1 liter of oil from the casa for my top-up.
    Apr 2013
    #682
    mga boss, I am planning on purchasing a used 2007 or 2008 1.8 FD. may nakikita ako dito sa province namin priced around 340-370k. mileage is around 65-80k kms. fair price na po ba ito? Thanks in advance sa feedbacks ninyo.
    Mar 2007
    #683
    Quote Originally Posted by xmfreak View Post
    Sobra mura na yan basta maayos yung car...make sure walang hidden problem kaya benta ng mura.
    Apr 2013
    #684
    Quote Originally Posted by Gecko Guy View Post
    thank you boss! mga ano po ba dapat ko titingnan when I go for a test drive? Been reading this thread and most problems are engine support and power steering. Is there any other specific usual "sakit" ng FD sir?
    #685
    front disc brake saka rear bearing, very common yan sa FD
    Apr 2013
    #686
    Quote Originally Posted by ozcity View Post
    Thank you boss! Will keep that in the checklist when i go test drive used cars. Thanks!
    i found myself wondering last night and consequently reading about the life span of a vehicle's timing chain and so i'm asking if you guys are familiar w/the time frame/mileage of the fd's timing chain before it needs replacement
    Pinapalitan ba timing chain? When I had a Nissan Sentra way, way back in college bearing lang pinapalitan never change the chain hanggang nawala na yun kotse.
    ^ actually hindi ako sigurado pero may cases daw kasi na nadadali din ng wear and tear or poor oil circulation kaya kinakailangan palitan
    #690
    Okay ba 2010 civic 1.8s polished metal color 53k mileage for 380k?
    Mar 2007
    #691
    Timing belt ang fd natin paps not chain sa pagkakaalam ko.... normal life ng belt 80-120K klms pede ka na papalit kapag 80K+ at huwag na paabutin sa 120K mileage
    ^ timing chain na siya bro - at least iyong sa 2.0 namin ganun. mga twice ko na din siya nakita
    pero alam ko lahat ng fd timing chain na ang gamit bro
    Jan 2009
    #693
    Yup, timing chain is used in both the R18 and K20.
    Mar 2007
    #694
    Ay hindi ko alam yun! Thanks sa info mga paps!!
    i finally replaced the burnt out rheostat bulb on my dashboard. ang tagal din dumating ng order ko na iyan via casa pero it took me all of 10 minutes to do the deed
    Mar 2015
    #696
    saan po makakabili ng coil spring para sa FD 2.0?
    #697
    Which light is this? hehe. Restoring our 10 YO FD. If it is cheap, I am interested!
    ^ iyong switch sa dimmer ng lights ng instrument gauge cluster. for a small bulb w/ a "condom", i won't exactly declare it as cheap. parang P300 + /bulb din siya sa casa (if i remember correctly) pero sulit din naman kasi ganda tingnan
    bought several gaskets because i have an oil leak w/c suddenly sprung. already replaced the vtec spool gasket thingy but it wasn't the remedy i hoped it would be.
    ads13: bro try mo kay ky bos dondi of jdm select. google mo na lang for his shop's contact #s
    Jan 2016
    #699
    Sir baludoy, saan ka bumibili ng replacement ng wipers mo? Hirap humanap sa labas, at walang 23". Hindi ko pa nasubukan sa casa, pero isip ko agad mahal dun. Yung mga refill naman sa labas din, walang 10mm puro 8mm kaya di kasya.
    Jan 2016
    #700
    nung mabasa ko ito, check ko agad warranty booklet, wala nga naka lagay na timing belt replace sa maintenance schedule!
Honda Civic FD Body [continued]
