^ pwede na replacement shocks. ang ok na brand is kyb. iyong akin sa banawe ko nabili kasi maganda ang presyo nila. sa labas mo na pagawa para hindi masyadong mahal
Problem ko po ngayon sir, pag check ko ng parts kung nailagay ba yung tie rod and tie rod ends... Nailagay naman, kaya lang malinis na ngayun yung cv joint sa driver side. And ordinary wire nalang pinang lock ng inner rubber boot nito. Nireklamo ko ngayun sa SA and mechanic ng Honda, sabi naaksidente tanggal. Naga lit ako bakit di sinabi sa akin, ang apprehension ko now, Baka pinalitan yung cv joint na yun. How will I know kung original pa rin yun?
Not sure paano malaman bro. Ask natin sa mga dalubhasa sa ganyan dito
Iyong binibenta ni benmawi na oem assembly bale reconditioned na, surplus, O brand new bro?
Sent from my ASUS_Z00AD using Tsikot Forums mobile app
sakto may nadidinig akong humming sound pag mabilis na ang andar, sabi sa akin wheel hub. mahal pala sa kasa yan.
my fd 09 nearly 145t kms ...
only problem encountered so far
rear Left amd right hub bearing at 70t kms
replaced both front rotors at 100t kms
replaced top engine mount at 80t kms
replaced rear shock (oem still ok, no leak) at 110t kms
Sent from my SM-G925I using Tapatalk
I don't usually do this but I am getting rid of two things that will fit the FD.
1. LED High-mount/3rd brake lamp assembly. This is a OEM Honda part typically found in the Accord and US Civic Hybrid. This was removed from my FD before I sold it. No issues with it.
2. A pair of speaker spacers for the front doors.
2k+ lang replacement wheel bearing hub pag umabot ng 3k Mahal na yun. Max siguro 2.5k
