Page 36 of 65 FirstFirst ... 2632333435363738394046 ... LastLast
Results 701 to 720 of 1292
    Sir baludoy, saan ka bumibili ng replacement ng wipers mo? Hirap humanap sa labas, at walang 23". Hindi ko pa nasubukan sa casa, pero isip ko agad mahal dun. Yung mga refill naman sa labas din, walang 10mm puro 8mm kaya di kasya.
    blade refills sa casa ako bumibili pero alam ko iyong ga team fd marami na nagchange sa bosch banana wipers na sakto sa specs ng fd. si sync3 at sa banawe sila nakakabili
    check mo na lang sa team fd website para sigurado bro
    Mar 2007
    #702
    1,8K lang 1 pair sa casa paps.
    Jan 2016
    #703
    Salamat sir baludoy, bukas holiday, check ko ang bosch sa Ace.
    Sir GG, refill lang yan o assembly na? I think the NWB brand retail for 1.4k each.
    Mar 2007
    #704
    *papi smith: Refill lang ng blade yun paps, buo pa kasi housing ko parehas
    Jan 2016
    #705
    Thanks Paps GG, mahal pala at refill lang, anyway I'll just keep my old wipers for summer use and try bosch 26" 24". Sinubukan ko lagyan ng 1" cardboard extension yung 23", hindi sila nag-aabot. may safety play pa since the 24" is only 0.5" long on both ends.
    Marami na banana type wiper replacement for FD. punta ka true value. I think meron na elevo brand less than 1k siguro for pair meron na rin sa landmark hardware section. Mas marami and mas mura never heard Lang nga mga brand. But I guess it's better to have a never heard brand new wiper than an old branded ones.
    Jan 2016
    #707
    Thanks for reminding me sir shadow, nakita ko nga yung elevo sa true value atc, di ko lang kinuha kasi walang 23". Ok lang sakin mag try ng mura, aabot naman yan ng 1 rainy season cycle at least, then kung pangit, try na lang ulit ng iba.
    Apr 2009
    #708
    i bought the elevo banana wipers for my fd last year at concorde,wala talaga sila 23" so i opted for 26" and 24" combination,sabi ko bahala na kung magkasabit,turned out di naman sila nagtatama, bought it for 318 pesos each.
    #709
    Quote Originally Posted by ozcity View Post
    front disc brake saka rear bearing, very common yan sa FD
    Sir ano po sintomas pag front disc brake ang problema..salamat
    Jan 2016
    #710
    Quote Originally Posted by donnatian View Post
    Salamat sa info paps!
    baka may naghahanap ng online repair manual para sa fd
    http://civic.hondafitjazz.com/manual2.html
    Feb 2010
    #712
    Planning to replace both rear tires sana. Ito po details 215/45/R17, stock rims ng 2.0s
    Ano kaya pwedeng ipalit para maging mas comfortable? O same specs din talaga dapat?
    Mar 2007
    #713
    215/50/17 is a great alternative. Pede din 225/45/17
    Jun 2016
    #714
    Hi newbie here. Ano po maganda tire and rim sizes po para sa 2008 1.8s fd? At saan po kaya maganda lang bilihan within metro Manila? TIA
    tumawag kanina honda alabang saying na they want to schedule my fd for servicing re change of passenger side airbag mechanism. i didn't know kasama pala ito sa recall kasi last october pinalitan na iyong driver side airbag mechanism ng kotse at akala ko i'm done w/ it na
    unfortunately, the car is presently admitted in a paint shop so 2 weeks from now pa ako nag-pasched
    #716
    Hi,
    Honda replaced my tie rod and tie rod ends plus the end comp. It took them 2.5 days kasi daw ibababa ang transmission. Nang mapalitan na and nailabas ko na ng casa, naging stiff ang ride, para kang sumasakay ng kabayo literally.
    Sabi ng casa, iniwan kasi sa hoist ang car and na fully extend ang shock. They advised me na gamitin several days baka bumalik. Kung hindi most probably Sira na ang shock. It's a stock shock 2008 FD model with 44K mileage.
    Totoo kaya sinasabi ng casa? Sabi pa nila May mga shock daw na ganun like 2003 CRV.
    Hope for your enlightenment on this issue. Or baka may nka encounter na sa inyo nito. Patulong naman
    Thanks.
    Ano yun end comp? Kung rack end and tie rod lang Pagawa sa labas siguro wala pang 2 hours tapos na, but if it's under warranty and wala ka binayaran ok lang.
    Dati narinig ko rin yan sa CRV hinde daw pwede i-lift ng matagal dahil nasisira shocks. Ewan ko kung totoo never pa naman kasi ako nagpagawa since before na inabot ng 2 days
    #718
    Meron bang alternative brand na good wheel bearing hub apart from casa? Almost 7.5k ang quote nila sa akin per pc.
    Mar 2015
    #719
    Quote Originally Posted by gumusut_amige View Post
    meron bang alternative brand na good wheel bearing hub apart from casa? Almost 7.5k ang quote nila sa akin per pc.
    Sent from my sm-n9005 using tapatalk
    ntn, p1500
    #720
    Hi sir,
    End Comp... Eto po yung parang lock ng rack and pinion sa passenger side. Pinalitan nila kaya inabot ng 2.5 days dahil binaba pati rack and pinion including yung pinatungan ng rack n pinion. ok lang sana sa akin yung 2.5 days kaya lang nadale yata pati shock.
    Puwede bang replacement shock nalang ipalit o dapat genuine Honda parts pa rin?
Honda Civic FD Body [continued]
