Page 34 of 65 FirstFirst ... 2430313233343536373844 ... LastLast
Results 661 to 680 of 1292
    Feb 2010
    #661
    Yes sir mahal talaga pag casa, pinatingin ko sa servitek pero walang available na piyesa, labor lang sinabi sakin. Pinabili nalang ako sa labas, NTN brand nakuha ko, 3700,made in japan(daw?) vs ordinary 2k+ na mukhang hindi pulido pagkakagawa nun pinakita sakin. 3700+600 labor sa servitek. Maayos sila kausap at gumawa lalo na yun mga may edad,sila nagsabi saan makakakuha ng parts.
    i need your opinions mga bro
    on my 2.0 s-l, there's a knocking sound that makes itself apparent whenever i'm maneuvering slowly (aka maniobra) at very slow speeds - usually when i'm positioning the car either to exit or enter a parking slot. sometimes the kalampag can also be heard when the car isn't moving pa while i'm directing the wheels to whichever direction i want the car to go. but when the car is already in motion - above say, 5 kph - the knocking noise is no longer there. i've changed all sorts of suspension part bits already (both replacement and oem) and yet it's still there.
    btw, naka electronic power steering wheel iyong kotse at mukhang ok pa naman iyong system na iyon kasi wala naman check steering wheel light (not sure if it's called as such hehe) umiilaw sa cluster gauge
    so if you guys can give me an idea what the possible culprit is prior to visiting a suspension specialist that would be a big help.
    thanks!
    #663
    thanks!
    Can you have this reproduced consistently?
    If yes, PHP500 says you can have this diagnosed at the casa (paid to them, of course) hehehe.
    Pero seriously, if you have no other place to turn to, I've heard nothing but good things from TFD people who go to the Honda SPA sa mindanao ave.
    Mar 2007
    #664
    *baludoy: Naka lowering springs ka ba? Baka naman yun ang natunog?
    Mar 2015
    #665
    thanks!
    baka shock mount
    https://www.youtube.com/watch?v=khZ16AOztT4
    Mar 2015
    #666
    Quote Originally Posted by jofed View Post
    sayang, late ang reply ko. P3,500 yun NTN Bearing at P500 para sa labor s JP Wheels Sucat. Yes, Japan made yan. Feedback naman sir about sa NTN. thanks.
    Feb 2010
    #667
    Quote Originally Posted by ads13 View Post
    1 day ko palang gamit bro yun NTN, mas ayos pagkakagawa compared sa ordinary na pinakita sakin. Sana lang matibay at tumagal din.
    Quote Originally Posted by mda View Post
    yep. it seems like the knock can be reproduced although the last time i had it checked by a mechanic, it took several minutes to make itself be heard.
    sa casa nga ang last resort ko kung sakali bro.
    Quote Originally Posted by Gecko Guy View Post
    hindi ako naka-lowering springs bro eh
    i already replaced my tie rods, rack ends, stab link, shock mounts, rubber stoppers, front shocks, and shock boots pero iyong ball joints ang hindi pa.
    last palit ko iyong oem shock mounts kasi akala ko ito din ang problema bro
    Don't want to make you feel bad pero mga 2.5k lang dapat yan wheel bearing a NTN.
    Mar 2015
    #670
    sir shadow,
    saan shop yan ganyan na price? sana malapit sa south hehe
    Mar 2015
    #671
    sana nga sir matibay yan. para yan din bibilhin ko sa future
    Mar 2015
    #672
    Mga sir saan po kaya may available na steering rack?
    Thanks!
    Feb 2010
    #673
    Sayang din sana yun. Mas mahal yata talaga parts dito samin sa probinsya kaysa sa manila. Nagtanong ako sa honda spa tandang sora, mas mahal parts pati labor ng casa dito samin. Pero ayos narin, tahimik na ulit takbo :-)
    sir shadow,
    Banawe
    thanks!
    naayos din finally itong knocking sound ng fd namin
    it turns out re-torquing lang pala ng steering mounting gearbox bolts
    #676
    nearly 130k kms na ako
    so far ito mga naging sakit ng fd
    replaced 2 front rotor at 110k
    replaced top engine mount at 100k
    replaced rear hub bearing at 70k left and 110k right
    replaced rear shock at 120k
    Mar 2015
    #677
    nice to know, sir baludoy.
    gagawin ko din yun info na binigay mo sa fd ko.
    thanks!
    #678
    anyone tried cleaning the throtle body?
    #679
    Saan ang possible oil leak location usually pag may traces of oil sa garage floor?
    First time kong nakita sa 2010 civic namin this morning. Tried lookin underneath but ground clearance is tight.
    Dadalhin ko mamaya sa servitek.
    #680
    ^^^Check the oil drain plug, its gasket might be worn already. Also, try to check where the oil filter is attached.
Honda Civic FD Body [continued]
