Mahirap talaga EPS. Pag nagloko mahal
Yes sir. Delivered straight to our door.
Medyo mahal lang siya, 80$ total for two pieces. Halos double the price vs the red H people are selling here.
Too bad local resellers don't have this. Pero makes the car feel newer than it is and (pasesya sa mga naka red H at hindi nakasetup yung kotse) hindi mukhang try hard.
Pinatungan ko lang yung binakbak na H. Hindi ko tinanggal yung luma. Medyo may konteng awang, pero okay lang. If it gets loose, I'll use thicker double sided tape nalang.
Old, nabakbak na steering wheel
New, pinatungan ko lang. Medyo may awang pero so far quite happy with this.
Curious, hindi ba siya kaya na irepaint lang yung silver part?
I have some paint chips on the door handle of my Mazda and that's what I was planning to do...
Fake chrome bit kasi yan, not exactly silver.
The chances of ever nearing OEM look is very close to 0. And you need to be very precise with the paint.
And super panget ng white plastic chipped part.
just got a hold of an oem glove light assembly w/ wire harness.
now the next step is to figure out how to make it work the easiest way![]()
Keep us updated sir!
Recently got Nightbreaker Unlimiteds for the '06. Parang luminaw naman. Yun nga lang, nagkaka fog na yung loob ng headlight. Hassle.
Call me paranoid but I just want to ask if should I be worried that I drove my FD to a gutter level flood? I think it was around 20 cm water. Also back home after that, I washed the under-chassis with a pressure hose.
^ i wouldn't worry too much about that. just as long as you drove w/ deliberate caution while fording through that flood, i don't see any foreseeable problems arising from that watery experience
I finally got to replace this burned out hazard button light bulb and the hassle wasn't as bad as i thought it would be.
The problem now is i just noticed that the bulb of the rheostat switch for the gauges is busted as well. At least that's an easier chore to do
btw, thanks to bro gecko guy for helping me out![]()
for those equipped w/ the vsa option, do you happen to know if the vsa button itself illuminates in the dark? i just want to confirm because mine isn't lighting-up and i suspect i've got another burnt-out bulb situation here.
thanks!
bakit kaya yung fd ko pag 120 & up yung speed e ang lakas ng vibration? below that speed ok naman. no kaya problem?
i finally had the glove light assembly installed this morning
the problem now is i have a leak on my vtec solenoid gasket spool![]()
Gud pm sir. Where can i find oem wiper blades? Wala kc dto sa ilocos
San pede o magandang bilhan ng parts ng FD sa banawe sir (e.g. Foglights, accesories)
