Results 81 to 90 of 113
BANNED BANNED BANNED
- Jul 2010
- 106
July 2nd, 2010 10:44 PM #81Mga Hondas,what is the best gasoline sa honda civic vti 1997?Shell unleaded?Caltex Silver?petron unleaded?Yan lang mga kinakarga ko sa honda ko.Before when I still in province,Petron o shell lang.Pero nun nalaman ko na ang caltex silver daw ay maganda sa makina at matipid daw,caltex silver nako palagi.
- Jul 2010
- 106
July 3rd, 2010 02:43 PM #82Petron Blaze nalang yata walang E10 pero ang mahal.pero lalakas daw hatak sasakyan pag eto gamit.totoo?
- Apr 2010
- 18
August 17th, 2010 10:03 AM #83Does anybody have an idea if it's possible to convert a Fuel-Injected car which is not yet compatible to E10 fuel? I have a Honda City 1999 LXi (Not the Type Z model), and honda posted it that it's not yet compatible for E10. I have already loaded it up with XCS for a couple of months until I discovered honda's posting.
I'll be loading up with Blaze until there's a solution for conversion.
I'd like to know if you guys have an idea on how much it will cost if there's a conversion kit available.
Thanks!
August 17th, 2010 10:43 AM #84
I believe Petron's BLAZE also has blended enthanol.
Good thing that you have EFI . . . think of the other old cars that still has carburated engines. :twak: it is even much worse!
August 17th, 2010 12:38 PM #85
i have a 99 carb corolla that runs e10 blended petrol with no drama, apart from a corroded canister valve and somewhat bad fuel economy (1.3 engine gets only 7-8, wtf? minsan it's 6-7 pag barado na air filter).
my previous 96 and 99 civic a/t ran e10 just fine and dandy.
my 98 a32 even likes seaoil extreme e10.
so my opinion here is: if it ain't broke, don't fix it. run that baby on any petrol you like until the engine breaks. then replace the whole engine na lang (which, i think, is more cost effective than repairing the old one and converting it to run like a flex fuel vehicle) then run another 100,000 kms.
by then, wasak na yung kotse. time for a new one which ought to be compatible with e10 by then.
August 17th, 2010 02:24 PM #87
August 17th, 2010 02:27 PM #88
problems on EFI cars with E10 would include (but not limited to) the following:
-rust in the gas tank (from the water content in the e10 gasoline)
-hardening of the non-ethanol compatible rubber fuel hoses.
-erosion/corrosion of some metal fuel hoses (resulting in pin hole leaks).
- Dec 2006
- 234
August 17th, 2010 11:41 PM #89
- Apr 2010
- 18
August 17th, 2010 11:54 PM #90*ghosthunter
and also, what is the safest fuel to load for now? my first option, as what i've already stated on my first post, is Petron Blaze.
pag ethanol-blended lang yung fuel (not 10%-90% mixture), like XCS (if i'm not mistaken, is not E10 but still contains ethanol -- around 5%?), me negative effect pa din kaya sa kotse?
naninigurado lang.. i'm currenly draining the currently loaded XCS. just making sure na tama yung maikakarga ko after
thanks again.
That's what he actually did. He also retrofitted an eps to his 1970s era beetle. Btw, now...
A/c
