Results 71 to 80 of 113
February 9th, 2010 05:14 PM #71
- Feb 2010
- 227
February 10th, 2010 06:42 PM #72
- Jan 2006
- 13
April 2nd, 2010 09:07 PM #73Here is the list of automobiles or vehicles compatible with E-10 Gasoline: (source: honda phils)
Honda Civic
Civic 1.6L VTEC (Civic SiR Body) 1998 ~ 2001
Civic 1.5L (Civic SiR Body) (Group Fuel Injection, GFI) 1998 ~ 2001
Here is the list of automobiles or vehicles NOT compatible with E-10 Gasoline: (source: honda phils)
Honda Civic
Civic 1.6 VTEC 1996 ~ 1998
Civic 1.5L (Group Fuel Injection, GFI) 1996 ~ 1998
Ano ba ang difference ng engines ng Civic 96-98 sa Civic 99-00? Bakit kaya 99-00 lang ang compatible sa E10?
- Mar 2010
- 37
April 17th, 2010 08:02 PM #74guys gusto ko lang sana malaman kung pwde ba gumamit ng e10 fuel sa Honda civic ESI 93 model? PGM-FI na din yung makina e pero natatakot lang ako kargahan ng e10. ang hirap din kasi mag hanap ng gas station na walang e10 at medyo may kamahalan na din yung mga Blaze and other premium gas. pls advice thanks
April 17th, 2010 08:35 PM #75
- Mar 2010
- 37
April 17th, 2010 08:52 PM #76yup read the thread, pero wala po kasi akong nakita about 93 Civic esi 1.6 PGM-FI compatibility with e10. may mga ibang mechanic na nagsabi na basta fuel injected pwde na daw pero duda parin ako. hope you can give advice thanks!
The following are NOT E10 compatible:
Honda City:
1. City 1.5L (Group Fuel Injection, GFI): 1998 – 1999
2. City 1.3L (Group Fuel Injection, GFI): 1996 – 1999
3. City 1.3L (Carbureted): 1996 – 1999
Honda Civic:
1. Civic 1.6 VTEC: 1996 – 1998
2. Civic 1.5L (Group Fuel Injection, GFI): 1996 – 1998
3. Civic 1.5L (Carbureted): 1993 – 1995
4. Civic 1.2L (Carbureted): 1992 – 1996
5. Civic 1.2L (Carbureted): 1991 – 1992
April 17th, 2010 09:36 PM #77
Taken from:
http://www.mukamo.com/honda-e-10-gas...y-philippines/
Also:
http://www.hondaphil.com/ver2/e10.php
Honda E-10 Gasoline (Fuel) Compatibility – Philippines
E10 is gasoline blended with bioethanol (10% bioethanol and 90% gasoline), which is an alternative energy resource produced from organic matter.
Honda Jazz
Jazz 1.3L i-DSI 2004 ~ present
Jazz 1.5L VTEC 2005 ~ 2006
Honda City
City 1.3L i-DSI 2003 ~ present
City 1.5L VTEC 2000 ~ present
City 1.5L (Type Z) (Group Fuel Injection, GFI) 1999 ~ 2003
Honda Civic
Civic 1.8L SOHC i-VTEC 2006 ~ present
Civic 2.0L DOHC 2006 ~ present
Civic 2.0L DOHC 2004 ~ 2005
Civic 1.6L SOHC 2001 ~ 2006
Civic 1.5L SOHC 2001 ~ 2004
Civic 1.6L DOHC VTEC 1998 ~ 2001
Honda Accord
Accord 3.5L SOHC i-VTEC 2008 ~ present
Accord 2.4L DOHC i-VTEC 2009 ~ present
Accord 3.0L V6 VTEC 2004 ~ 2007
Accord 2.4L DOHC i-VTEC 2004 ~ 2007
Accord 2.0L DOHC i-VTEC 2003 ~ 2004
Accord 2.0L VTI-SOHC 1998 ~ 2001
Accord 2.3L VTI-L SOHC 1998 ~ 2001
Accord 2.0L VTI-SOHC 2001 ~ 2002
Honda CR-V
CR-V 2.0L SOHC i-VTEC 2007 ~ present
CR-V 2.4L DOHC i-VTEC 2008 ~ present
CR-V 2.0L DOHC i-VTEC 2005 ~ 2006
CR-V 2.4L DOHC i-VTEC 2005 ~ 2006
CR-V 2.0L DOHC 1997 ~ 2002
Other Honda Vehicles
Odyssey 2.2L SOHC 1997 ~ 1998
Pilot 3.5L V6 2006 ~ 2007
HR-V 1.6L SOHC 2000 ~ 2002
S2000 2.0L 2001
Civic Hybrid 1.3L 2004 ~ 2006
Legend 3.5L 1997 ~ 1998
Here is the list of automobiles or vehicles NOT compatible with E-10 Gasoline: (same source as above)
Honda City
City 1.5L (Group Fuel Injection, GFI) 1998 ~ 1999
City 1.3L (Group Fuel Injection, GFI) 1996 ~ 1999
City 1.3L (Carbureted) 1996 ~ 1999
Honda Civic
Civic 1.5L (Carbureted) 1993 ~ 1995
Civic 1.2L (Carbureted) 1992 ~ 1996
Civic 1.2L (Carbureted) 1991 ~ 1992
Honda Accord
Accord 2.2L 1994 ~ 1997
Motorists should only use E-10 gasoline from oil companies/distributors who complied with PNS/DOE QS 008:2006 E-gasoline specifications or look for the marking that says “This E-gasoline contains 10% Bioethanol. Generally recommended for fuel-injection engines” on their dispensing pumps.
- Mar 2010
- 37
- Jun 2010
- 36
June 15th, 2010 02:25 PM #79Same question with agp. May difference po ba sa engine ng vti 96-97 and vti 98-00?? Bakit hindi pwede e10 sa 96-97??
June 16th, 2010 06:25 PM #80
Even if my 1.8 SOHC i-VTEC engine is compatible with E10 and other flex fuels, I noticed a substantial drop in fuel consumption when I tried E10. From the usual FC of 11kms/liter, my FC worsened to 8kms/liter when I used a full tank of E10. So it's back to high octane fuel for me.
repair kit lang. car care nut says, for toyotas, he recommends entire assembly replacement for...
rack and pinion repair
