Results 81 to 90 of 645
- Jun 2004
- 1,311
May 19th, 2007 03:44 PM #82Help! Anyone know a mechanic who can do home service - paranaque area? Car wont start, the starter may have to be removed and rebuilt or the solenoid has to be replaced. thanks.
May 26th, 2007 01:12 AM #83
Hello po sa lahat. Bago din ako dito I have also a 2005 7th gen. accord 3.0 V6.
Bossing ma correct nga lang po yong sabi ng mekaniko na lalakas ang kain ng gas kapag high tension wire and high perf. spark plugs ang gamit mo. Mali po iyon kasi po the more current from the wire and the hotter the plugs means much efficient ang burn ng gas in the combustion chamber meaning you have better gas travel and cleaner engine pero hindi po mas malakas sa gas kundi mas matipid. Mas lalong matakaw ang kotse kapag wala sa Tune up, out of time(either late or advance) faulty spark plugs/cable, dirty air filter and under inflated tire. Upgrading your car dont cost you much of the gas but deep pocket on the gadget and accessories on the other hand if you want to turbo/ super charge your engine into much stronger output then thats a diff. story your car demand more gas to unleash the power of the best.
thanks.
May 26th, 2007 01:30 AM #84
17 inch looks pretty small pero sa 18 tamang tama lang at ang recomended tire ay 225/45 /18 at siguraduhin mo na 42 or 45 ang offset ng wheel mo para walang problema sa rubbing ng fender mo. Kung i drop mo mga 1 to 1 1/2inch sa harap at 1 to 1.2 sa likod. Hindi ako sigurado kung kailangan mo ng LOWERING CAMBER KIT sa harap pero sa likod kailangan mo para mas nakaka sigurado ka. Pero kung money is not an option magpapalit ka ng gulong mo every 3 months.
- May 2007
- 22
- May 2007
- 22
May 29th, 2007 09:56 AM #88http://z3.invisionfree.com/HCP/index...&st=1340&#last
pls. go to this site
June 1st, 2007 08:06 AM #89
June 1st, 2007 10:16 AM #90
Having problems posting images as well.
Problems with viewing Tsikot on non-Chromium...
