Page 59 of 65 FirstFirst ... 949555657585960616263 ... LastLast
Results 581 to 590 of 645
    Oct 2009
    #581
    newly accord owner here 95 exi AT, ask ko lang whats the normal idle ng accord nyo? yung nakuha ko yung oto the idle in cold start is 2.5krpm
    on neutral its 1.5krpm on drive its 1krpm.. masyadong mataas or normal sa accord to?? galing ako sa esi na ang idle is playing between 700 - 900rpm.
    another question: nag ffuel check yung prang takore is always blinking if naka stop ako or on break, may Gas naman ako. ano kaya problema?
    #582
    taas ng idling...same lang din ng esi dapat, 750 will be fine. adjust mo nalang, madali lang yan i DIY...just remember lang na dapat when you are setting your idling, dapat naka short yung service connector...HTH
    #583
    Mga Sir,
    May kilala po kayong magaling na mechanic sa area ng Pangasinan? Dagupan - San Carlos area po?
    Thank you
    Jun 2004
    #584
    Normal yung mas mataas ang idle sa cold start, pero alam ko nasa 1500rpm lang, pero pag mainit makina nasa 750-850rpm dapat, pwede mo disconnect yung connector to iacv at adjust idle speed.
    Check engine light yun, baka naman mababa brake fluid or engine oil?
    Jun 2013
    #585
    New and proud owner of a '99 Accord VTI here. Previous rides are: Lancer, Corolla, Feroza4x4, CR-V (1st Gen), and a Pajero. Looking forward to getting to know you all. Thanks and More Power to all Accord owners here at tsikot.com
    #586
    saan ba nakakabili ng parts ng accord??
    Accord 2000 A/T
    1. Headlight stanley
    2. Dome light **yung harap ng part na may lalagyan ng salamin
    3. Garnish stanley
    eto nalang kulang ko para mapapinturahan na yung cotse
    #587
    Quote Originally Posted by polista View Post
    Accord 2000 A/T
    3. Garnish stanley
    Check mo sa Alabang Parts or Partstar Pasay.
    Jun 2013
    #588
    sirs, need your opinion. Just this morning, i noticed water droplets coming out of the exhaust muffler, does that mean na may tama na yung cylinder head gasket? my ride is a '99 accord so I guess it's possible since it's already 14 years old. (105K millage)
    I acquired it just recently so I have no knowledge of it's history. I noticed na naka rekta na yung cooling fan and the thermostat was disabled already. possible na pina rekta na nung previous owner because of rising engine temp especially during rush hour traffic.
    pero hindi pa naman ako tumaas ng half sa engine temp kahit mainit at traffic sa edsa.
    do you think na dapat ko ng paghandaan yung replacement ng cylinder head gasket? medyo mabigat yung estimate na binigay sa kin ng aking trusted mechanic. 7-8K kasama na labor.
    Jun 2004
    #589
    Quote Originally Posted by cyberquest_11 View Post
    I think condensation lang yan, nothing to worry about. Check if the oil appears normal (not milky) and that the radiator coolant appears normal as well.
    Jun 2013
    #590
    thanks for the input.
    maybe it's condensation. Just this morning the water droplets disappeared. Hindi kasi masyadong malamig ang panahon kaninang umaga. So possible na condensation nga.
Calling All Accord Owners
