Page 4 of 10 FirstFirst 12345678 ... LastLast
Results 61 to 80 of 192
    Aug 2004
    #61
    Quote Originally Posted by AG4 View Post
    Twist the rotary knob of the lights to the headlight position, then pull the knob (2 positions for models equipped with front and rear fog lights). An indicator light (icon) should appear on the instrument panel when the fog lights are in use.
    Thanks... I've driven several Focuses (last time, we had my Dad's car for three weeks) but I could never get that one... :hysterical:
    #62
    another question for the focus gurus out there, where is the aux located? i noticed in the radio na may aux button, but i cant seem to find where the inputs are located
    #63
    Quote Originally Posted by jazon View Post
    The auxillary audio jack (For MP3 players etc)?
    Open the glovebox, its located at the upper right portion (right side of the glovebox latch).
    Apr 2006
    #64
    hi white hatchback,
    how long have you been driving your Focus 2.0 TDCi? What can you say about it's performance? are you happy with it? What about Ford's service? Where do you have it serviced? Thanks in advance for your kind reply.
    Jun 2009
    #65
    For Ford Focus owners, inquiry lang po, planning to buy a brand new car and type ko sana ung 2009 jazz a/t pero ang mahal naman para sa size nya. Kaya thinking of the 2009 Focus a/t ung 1.8 na gas, kamusta naman ang FC nya and how about the 1k km and 5k km PMS? Para magkaroon lang po idea sa maintenance and Fc nya. Sana meron mag answer and thanks in advance. Greatly appreciate.
    #66
    i also posted ito sa thread ko, baka po mas appropriate dito so post ko na din, i hope the mods wont mind. but feel free po to delete kung bawal.
    sana meron din maglist down ng overall advantages ng TDCi (yung madali po maintindihan ha, wag masyadong technical terms) so far kasi, ang advantages nya in general
    1. it's diesel
    2. at matipid sa diesel (efficient FC)
    although mahal sya, in the long run mas makakatipid po ba ako in terms of fc ng TDCi vs Jazz naman (kasi jazz ang mataas din ang overall rating)? i mean, pwede ba sya iconsider na 'investment' or something like 'bang-for-the-buck'? again this is my first brand new car so malamang im gonna keep this for a very long time with no plans of reselling it in less than 5 years.
    TIA
    Oct 2008
    #67
    magkalapit ang FC ng jazz sa focus tdci pero mas mura ang diesel. sa 350k na price difference, matagal pa kung fuel savings lang ng diesel ang usapan. kapag sa teknolohiya sa pyesa bawi yang 350k. paki basa na lamang ang madalas na masirang mga pyesa sa dalawa at kung may malapit na casa ka na mapagkakatiwalaan. pareho silang bang for the buck.
    Jun 2008
    #68
    Sirs,
    Ask ko lang po sana kung ano ang fc ng 1.8 focus hatch. Thanks.
    #69
    May bidding bonanza ngaun ang BPI
    Ford Focus 2008 TDCI, minimum bid price is 655k. Ok lang kaya kumuha ng mga repossessed units? Gusto ko talaga ung ford focus TDCI and I think this is a chance to own one. Kaso nga lang, antaas ng mileage nya - 45,786 kms. Mukhang sinulit ng previous owner talaga...
    Aug 2009
    #70
    guys anong exactly kong gawin para masaksak ko yung mp3 ko sa aux, ano kailangan bilhin para maconnect ko yun? salamat.
    Oct 2008
    #71
    standard stereo plug both ends. pareho sa stereo plug ng headphones/speakers na sinasaksak sa likod ng computer.
    #72
    sir niky, how does the tdci's turbocharger work/function nga pala?
    also just an observation:
    medyo mahina ba talaga ang kagat ng brakes sa sudden stops? or is it just me? i think this might be because i used to drive a M/T car, nasanay ako na mas madali magdownshift to stop? though di ko pa ren natry yun PS manual mode. tanong ko na lang din muna dito kasi im not sure, pero baka meron ibang reason like what ive read somewhere before about the everest na tires ang may prob na medyo madulas when braking? i was only doing ~50kph tapos sudden stop (dahil sa isang jeepney na walang pakundangan huminto pabigla bigla) tapos yun nga napansin ko medyo madulas. ayoko kasi sana masanay ng hard braking hindi good sa health ng auto, or so i read. thanks!
    Aug 2004
    #73
    The Powershift goes into "neutral" at a certain speed... the loss of engine-braking can feel like a loss of brakes, because the engine-braking is so pronounced.
    With the speed and weight of the TDCi, yeah, it can feel like sometimes the brakes aren't strong enough for the car, but it stops all right. You just have to get used to pushing harder and earlier. Remember, the TDCi weighs about as much as a Mazda6, and is heavier than many older mid-sized cars.
    A turbocharger uses pressure from the engine exhaust to increase pressure at the engine intake. In other words, the high speed air that would normally just be going out of the muffler is used to spin up a propeller that is attached to another propeller that pushes air into the engine's intake. More air = more power.
    This is not a function of how fast the turbo pushes air, mind you, but how hard it pushes it. That's why those electric turbochargers they used to sell don't work. Doesn't matter how fast the fan spins, if it can't push the air hard enough (working against pressure), it isn't worth beans.
    The TDCi turbocharger is a variable geometry design. At low speeds, it acts like a smaller turbo, giving you quick response (boost at under 2000 rpm)... once the engine revs up, the vanes open up and the turbo acts like a bigger unit, giving you more power up top. As opposed to gasoline turbo units, which give you pressures of about 8-16 pounds per square inch, the TDCi turbocharger is somewhere in the 20-30 psi range. Gotta love them diesels.
    It also features an overboost function, where the boost and power are raised for around ten seconds or so to allow you to accelerate faster. When you're not accelerating, this function turns off, to allow you to conserve fuel and to preserve your engine's longevity.
    #74
    Took my TDCi to Baguio for the holidays and so far this is my 2nd fav car to take on long drives. It gives up nearly a hundred horses to the FXT on the flats but it's not only better on the twisties (well, the FXT IS a cuv) the dual-clutch also makes really good use of the torque on the uphill.
    It doesn't load quite as much as the Foz (hey, it's a hatch) but I can fill up on NLEX, go up to Baguio, run around and leave the engine on all day, and STILL get back to NLEX before I need a fill-up! Meaning on a long drive, i'd probably beat the FXT if I didn't have to go to the bathroom a lot anyway.
    If it weren't for the low ride height and the FXT's incredible suspension, it might've been a close call. But still, for the price/value/car class combo, I'd say it's a steal. And they still have that zero interest thingy going on too!
    Aug 2004
    #75
    Quote Originally Posted by pup2 View Post
    Hmmm... with a few bolt-ons... you can lower that 100 horse deficit to just 30 or so...
    Actually, on the dyno, a TDCi already makes 125 whp, suggesting around 150 bhp. A few bolt-ons takes that to nearly 200.
    Only issue is the fiddly ECU. Too much power and you get a check-engine light. But some guys drive around with it with no issue.
    #76
    Oh stop temtping me you devil you. Hehehe. Nah. Won't touch it. Not only because it goes to my 65-year old dad when my car gets fully restored, but Im not really a modder. Mas gusto ko stock-to-stock.
    Kainis lang they don't have nice colors like yellow (on the Escape) ano? I think they only had 4 colors and only 2 were immediately available!
    #77
    Dec 2009
    #78
    hi, planning to buy a brand new car and ford focus is on my list. tanong ko lang, lahat ba ng ford focus (1.8 M/T, 1.8 A/T, 2.0, etc..) e fuel efficient? how about the PMS? mga how much kaya magagastos ko for that? and yung spare parts po, mahal din ba?
    those are the things i consider kasi when buying a brand new car. hope someone answers my questions.
    Aug 2004
    #79
    The gasoline 2.0AT, obviously, sucks in the city... but it's just as good as the other 2 liter cars on the market. The 1.8 MT sedan is better, but don't expect 1.6-level economy. It's still a heavy car with a relatively powerful engine.
    Spare parts. Dealership parts are obviously expensive (just like all dealers are), but there are aftermarket and replacement parts now available outside. The one thing I'm not sure about is replacement shocks... Haven't updated myself in a while, but you can visit the Ford club ( http://forum.fordclubph.com ) and ask if anyone has a lead on them.
    #80
    Yung TDCi ko though is bang for the buck as far as fuel/performance is concerned. Before break-in, I got 12 kms/liter with lots of idle. After break-in, I'm now at 14+ kms/liter mixed city/hiway.
    Nami miss ko na ang gas station, chewing gum, mags, etc. For a car with that performance ... sulit na sulit lalo't nakuha ko siya ng zero interest pa.
    Di ko alam ang parts dahil 1st 1K PMS pa lang ako (libre lahat). Mukhang mas maganda ang HINDI nasa eastern side na dealers though -- they're extremely Ondoy busy.
Ford Focus Questions
