Di ko alam kung skid plate pa rin tawag dyan eh. Sa pagkaalam ko skid plate is further in front. Ito halos sa may front axles na nakakabit.
Skid plate usually is made of steel to protect the oil pan when off-roading. This one looks like a splash guard.
Boss, saan mo nascore yan EPS protector and how.much? OEM ba to ng Ford or aftermarket? Me abang na ba pagkakabitan or need to drill holes for the mounting screw/bolts? Sorry dami tanong...gusto ko din protect yan EPS...its very expensive pag nasira yan.
..I guess its IP67 RATING naman kse they claim na pede wading depth na it is subjected to full immersion
That metal will somehow protect sa bumps
Ford adds Waze navigation to Sync 3 platform - Pocket-lint
*jiggs,
Ford original part. You have to buy the screws and washers. You need 4.
Ito ung part number: EB3C 5B018 AB
*jiggs,
You can order the part at any Ford casa. If they have stock sa planta then good. Kung wala, they have to order it sa thailand pa. Not sure if FordMaz has that part though.
Guys do you know the paint code of the White Everest? Blank kc paintcode sa door. Thanks
ano magandang battery pamalit sa stock? may gagawin pa ba kung hindi orig yung gagamitin na kapalit na battery brand, like disable something via forscan?
^^^ ako din i just had 30k km pm done. my eve's battery is already at just 51% capacity according to their battery test. does the eve require a particular battery type? all i know is the size is 3sm.
Proper way:
Use DIN 60 upto Din 75
Calcium Calcium type
Reset battery SOC monitor using forscan/ids
Done.
Others pero not sure kung ano mangyayari:
Palit kahit ano batt basta 12volts at kasya sa tray. LOL!!
Done.
Bad trip kahapon, nabunggo rear bumper ko ng tricycle. Nung tiningnan ko, sabi ng tricycle driver, biglaan daw kasi hinto ko. Napangiti na lang ako kahit nakita ko na meron dimple dent tsaka small scratches sa ilalim ng bumper (sa silver Grey part).
Pwede ba Paintless dent repair sa
why is there a need for a reset? i have disconnected the battery twice, once for more than 30 minutes and there was no displayed warning or error after i reconnected the battery. hassle naman yan kung baterya lang papalitan mo tapos need mo pa pumunta sa casa para magpalit ng baterya at magpa-reset. paano kung nasa dulo ka ng sampulanggit ibig ba sabihin nyan di aandar ang eve kung di mareset?![]()
Any ford provided reason why the ECU needs to be reset after a battery replacement?
