Page 293 of 389 FirstFirst ... 193243283289290291292293294295296297303343 ... LastLast
Results 5,841 to 5,860 of 7777
    Jun 2017
    #5841
    *rexer29, *yebo Thank you!
    Mar 2016
    #5842
    Quote Originally Posted by Rush14 View Post
    Just got my Trend Unit. nakakapanibago. Pinagana kp agad navigation nya papunta bahay. Works just bahay. May blessing na sa chapel namin dinadagdagan pa ng ulan nun nakapark na sa bahay.
    Totoo ba na pede gamitin within 7 days. Un kasi sinabi sa akin eh. Sinabi ko nga as per LTO hndi pwde. Kaso pwde pa din dw.
    Pag wala pa or/cr in three weeks, byahe ko to Isabela. Bahala na si batman.
    Sent from my F3212 using Tsikot Forums mobile app
    [/QUOTE]
    Ano Sir Balita, ano masasabi sa bago nating Eve Trend.. Same tayo ng unit..
    Apr 2016
    #5843
    meron seller ng micro II fuse tap sa lazada. cod so no worrries if it will be delivered or not.
    Tama sir yebo, meron nga din pala sa lazada.
    Huling set up ko ng power magic pro sa OLX ako nakabili ng micro2 fuse tap, masmura kaso bank transfer.
    #5844
    Quote Originally Posted by rexer29 View Post
    i find olx more expensive kasi most of the time yan nga bank transfer or cebuana/western union (so additional P50 fee), meet up so spend another p50 for parking, not to mention the time you will spend travelling and meeting up. sa lazada pag cod iwanan mo lang sa maid yung bayad ok na.
    meron ngayon p500 for 3 pcs may kasama nang fuses.
    Feb 2003
    #5845
    Will it not drain our battery kapag ganyan direct tap ang dash cam na yan? Worried ako kse garage queen for 15days lagi si Eve ko. Baka pagbalik ko drain na batt
    Mar 2004
    #5846
    Tap it on a fuse that gets power only when key is in ACC or ON position ... usually it's the radio ...
    #5847
    it is more on what not to tap. all those things that work with the key out and doors locked and remain powered all the time should be avoided - door locks, tail gate, all lights except drl, alarm and immobiliser, power seats, power windows, moon roof.
    all those that turn off when the key is out and you open the door are ok. example is the hu as walter suggested. the best is the one that turns off automatically even when the key is in accesories position - the power outlets. this one will power down after 45 minutes or when the battery power goes below a certain minimum level.
    Jul 2017
    #5848
    good day,
    hi poh sa lahat nang eve owner, have plan to buy car kasi, dn unfortunately wala poh talaga ako alam about car, tapos were 8 in family pah, so dapat malaking car bilhin namin, and eve is one of my choices. tapos my naring pa poh akong dpat euro 4 capable na ung car. is eve, euro 4 ready na poh bah?
    salamat poh sa mga sasagot
    Jun 2011
    #5849
    Quote Originally Posted by motion View Post
    good day,
    Family of 8... You a need a van...
    Max number of passengers on SUV is only 7.
    Van ang bilhin nyo
    #5850
    Van ang bilhin nyo
    Kasya 8 sa Innova though to be sure, best bet would be a Grand Starex or Grand Carnival.
    #5851
    Van ang bilhin nyo
    Agree. Grand Starex, Grandia or Carnival nalang imbis na 7 seater PPV.
    Technically, pwede nyo pagkasyahin ang 8 pax, pero for short trips lang since di sya na comfortable. Plus, wala ka nang cargo space in that particular scenario.
    good day,
    baket meron "h" and pa and po?
    as for the euro4, its euro4. not an issue imo. the fuels are all euro4. emission-wise its also not an issue.
    it will only seat 7 comfortably. if you want to seat 8 comfortably. Then the starex or kia carnivalare diesel 8seaters
    Jul 2017
    #5853
    thanks po sa advise sir, grand starex also in my list, dahil sa mga feed back nyo, parang tangal na sa list si everezt. thanks mga pops,
    Jul 2017
    #5854
    Quote Originally Posted by ssaloon View Post
    thanks po sir sa advise, delete ko na sa list si everest,
    plan to buy kasi before end of the year. :-)
    Nov 2007
    #5855
    Ano ba amp ng fuse kailangan for a standard dashcam?
    Mar 2004
    #5856
    Van ang bilhin nyo
    Or buy 2 Toyota Vioses ... or one Toyota Innova and a motorcycle ... you're not going to drive around with 8 persons ALL the time ...
    #5857
    Quote Originally Posted by ryanmamaril View Post
    check the power supply that comes with it. baka wala pa 0.5 amps ang current draw. so the smallest fuse you can find, maybe 5A.
    note you can not supply 12 vdc direct to your dash cam. 12 vdc is the input voltage of the power supply and MAY NOT be the input voltage of the dash cam. baka 5 vdc lang yung dash cam
    so you need to solder wires to the contacts of the power supply and that is what you connect to the fuse tap.
    Aug 2009
    #5858
    Sir san ka nagpalit sa casa? Pwede ba palitan sa battery shop ng amaron? Hindi ba magkakaerror sa dash board. Sabi kasi sa casa may reset pa daw ginagawa kapag nagpalit ng battery... parang inconvenient naman kung bigla na dead battery mo tapos malayo ka sa casa...
    Quote Originally Posted by bigeebabee View Post
    Just had my 30k pms done, they updated an body trim clip and I changed my battery, size is Din 80 not reverse amaron no any other model can fit after 18 months of use casa fomoco battery is 14k plus hehehe
    Jun 2017
    #5859
    Isang beses ko palang naibyahe from qc to manila back and fort. Nasa garahe lang sya, paandar ko kpag gusto ko itry un nabasa ko sa manual. Ala pang wiring diagram manual natin, good to have sana for future references. Naiinip na ako dko pa ma break-in, baka sa sabado nalang byaheng probinsya. Magkaalaman sa up/down hill na zigzag road with trailers to overtake. So far more on HU lng kinakapa ko for now. Hndi ko pa magawang ma palitan presets ng radio stations of my choice. Ano Sir Balita, ano masasabi sa bago nating Eve Trend.. Same tayo ng unit..
    Sent from my F3212 using Tsikot Forums mobile app[/QUOTE]
    #5860
    Hi all!
    What's the cheapest Android Phone that is compatible with SYNC3?
    I want to get one just for Waze.
    Mukang malabo pa magkaroon ng Waze sa CarPlay so might as well go the Android Route.
    Thanks!
Ford Everest 2015
