Page 341 of 389 FirstFirst ... 241291331337338339340341342343344345351 ... LastLast
Results 6,801 to 6,820 of 7777
    Jun 2010
    #6801
    Quote Originally Posted by Janemar View Post
    May forscan ka sir di ba?
    Check mo if may dtc. It will log a dtc for hvac blend door and vent door position error if may problema man.
    If pinatay mo na engine, nag re-calibrate ung position sensor. Maingay sya pag sira ung motor, di nya makita ung position na target nya.
    wala naman kakaibang ingay nung nag turn off ako ng engine, normal lang lahat. meron ako forscan sir kaso nag loloko ung cable ko, minsan ayaw, minsan pwede.. check ko pag nakakuha ako ng bago sir.. thank you..
    Sent from my RNE-L22 using Tapatalk
    Sep 2012
    #6802
    May naka-experience na ba ng sudden rev while on P. Happens to my wife twice, una while waiting for green light then nung paguwi bago gumarahe ngrev na naman sya for about less than a minute daw. Hindi naman daw nya natapakan accidentally yung gas. We have Premium titanium 2.2 just acquired Oct 2017 lang.
    Jun 2010
    #6803
    Quote Originally Posted by yangmen View Post
    no, owner since jan of 2016, sua ng ford? kung may chance, kuhanan mo ng video sir (as long as safe ka habang kinukuhanan mo)
    nung nasa garage, naka P nung nag rev?
    #6804
    Compressor engaging?
    Aug 2017
    #6805
    RPM reading. Is that a sign of sua? Still lucky your in P. Stay safe.
    Maybe compressor engaging lang.
    Sent from my iPhone X using Tapatalk
    Sep 2012
    #6806
    Quote Originally Posted by gomez_ea2 View Post
    Yes sir..naka-P sya on both incidents. We'll try to take a video pag naulit pa.
    Jun 2010
    #6807
    stay safe always sir,
    Sep 2012
    #6808
    Quote Originally Posted by montro View Post
    Umabot daw ng 5k sir.
    Compressor engaging?can you pls enlighten me sir..
    Second car namin ito. Napabili lang dahil sa TRAIN
    #6809
    Pag umabot 5K RPM... disregard my comment hehe.
    Nov 2017
    #6810
    Quote Originally Posted by mda View Post
    Grabe hindi na sa compressor yun
    Aug 2017
    #6811
    Aircon compressor. But if 5k rpm. Pretty sure its not. 2 times is not normal anymore. Send your car sa casa for check up. Better safe than sorry.
    Sep 2012
    #6812
    Thanks mga sirs..
    Mar 2004
    #6813
    ... or maybe accelerator got stuck on floormat ...
    Jun 2010
    #6814
    ito din ang hinala ko..
    Jul 2016
    #6815
    Malamang niyan na stuck ang floormat.
    Pero 5k rpm? Ganun ba kataas ang redline ng Everest?
    Jun 2010
    #6816
    may solution na ba sa nag lean to driver side ang everest? after owning for 2 plus years, ngayon ko lang napansin na naka lean sa driver side, 80% full ung tank ko, same parking slot, tapos may car seat lang sa loob, pero obvious ung lean nya sa driver side.
    Jul 2016
    #6817
    Upgrade shocks and lift kit sir.. hehe
    measure the fender gap left and right?
    Jun 2010
    #6819
    shocks pwede.. lift kit baka hindi sir.. not a fan.. hehehe
    Jul 2016
    #6820
    Thanks mga sirs..
    Ibalik mo sa casa sir and kwento mo naexperience mo. Mag set naman mg DTC yan sa memory ng module if may problem man kahit walang check engine lights.
Ford Everest 2015
