nakita nyo na yung bago price list ng ford? bumaba pick up. mahal na ng trend
2018 Prices (Top Gear)
Ambiente MT > 1,518,000
Ambiente AT > 1,578,000
Trend > 1,718,000
Titanium 4x2 > 1,918,000
Titanium + > 2,058,000
Titanium 4x4 > 2,288,000
mga lodi goodpm po. 2017 ford everest need po ba ng canbus for h.i.d kit. kase nag install po ako pero once i start the engine nag shut down headlight pero pag ignition on lng (engine off) the hid works fine
not yet sir tinanggal ko muna. sa weekends ill try to put relay yun din sabi ng friend ko . ang problem po sir when i installed h.i.d on low beam h11 kapag ignition on lang testing no problem at all. pero nun gagamitin ko na sana para makita yun focus nun ilaw pag start ko ng engine ayaw na umilaw kahet off/on ko h.i d nag blink lang. tapos try ko off engine ayun okay ulit gumagana both.
I think you need to change in forscan the bcm from halogen to hid
Sent from my SM-A720F using Tsikot Forums mobile app
726-27-01 0000 xxxx xxxx - Front Light Outage Detection Disable when adding aftermarket LEDs/HIDs in Halogen Bucket
1. Di pede Relay lang, you need equivalent sized resistor to fake the BCM into thinking na may nakakabit pa na halogen bulb.
2. Di mavoid warranty using forscan.
3. Mas ma void warranty if nakita nila may nakakabit na chingchongching HID kit and Relay sa engine bay mo.
4. Just buy a BCM friendly HID kit kung alang forscan.
5. Switch to clear tints for windshields(anytime baka maghigpit na rin naman LTO) + upgraded halogen bulbs like osram NB.
Hindi na void warranty if you change settings using forscan.
Mas ma void if makita nila may relay kinabit and wire splicing.
Forscan is free but you need to buy OBD that will support forscan.
my wife made a trip to zambales today to fetch my mother's caregiver. she went at 170 kph at sctex. maingay na daw yung engine starting at 160 kph. i did changed the air filter with a huricane filter, baka siguro kaya naingayan siya. and then there is the issue with the mud terrain tire she bought when the right rear nitto got slashed.
and my top speed on the eve was only 145 kph and she starts to scold me at 130kph! unfair!![]()
more air sounds good on gas engines.. so sa diesel hindi? 170 lol talo pa nya ako hahahah
maingay yata talaga basta washable filter. i remember someone here used k&n on his eve and maingay din ang report. i did noticed an increase humm when i first put it in 3 weeks ago.
kaskasera talaga e. di pa naman nabigyan ng speeding ticket kahit na-flag down na sa sctex noon. nahuli daw siya kanina sa sbma not for speeding but for failure to stop at a 4-way stop. dinaan na naman sa pa-cute. sabi ko nga di lang tiniticketan kasi babae siya.
ask ko lang mga sir, sino may roof basket sa everest nila? especially sa naka panoramic roof..? thanks
Sent from my RNE-L22 using Tapatalk
me. pero inaalis ko pag di ko naman ginagamit kasi malakas ang wind noise. i just have the chipipay generic roof basket na tig 5k from banawe. the roof crossbar is the slim type so di siya gaano maingay. that one stays on permanently.
make sure when you install the roof cross bar that the forward half of the panoramic roof can open upwards (2 modes di ba, 1st mode the roof opens up for ventilation to get rid of hot air, 2nd mode the roof moves down and slides rearward). when they first installed my crossbars i could not do mode 1. so i had to slightly make the crossbars shorter for the clamp to fit the next notch back of the roof rack.
this is it's position now. the crossbars cost 8.5k in banawe, the exact same model is being sold by some seller active in the ford everest club for 35k before.
yan din problem ko ngayon may konting whistling noise lalo kung nasa 80kph ka na.. even may wind fairing na ung roof basket, baka dagdagan ko na.lang ng wind fairing hanggang dumikit sa roof ng everest para wala ng butas sa harap. ewan ko kung dahil lang ba sa panoramic roof kaya rinig ko ung whistling wind noise na yun, na kung walang pano roof, baka di mo na yun maririnig
