Good day po sa lahat... newbie here... Hingi lang po sana ako ng recommendations kung saan po pwedeng magpa Nano Ceramic Coating sa Bicol Region - particularly po sa may Legazpi area. Also, magkano po kaya (rough) estimate para sa Ford Everest? Thanks po in advance...
ang galing! local supplier or import?
^ local lang. Ordered thru ford dealership. As I've said, no need naman ito for 4x2 models. I've just wanted an extra protection for the EPS motor.
Kwento ko lang sa inyo nangyari sa akin kanina lang. While maneuvering to park my everest sa isang establishment, from D hindi ko magalaw yung shift knob at all, in other words, nag LOCK siya, even if todo press na ako sa shift button on the knob. Only after a minute or so, nung pnuwersa ko na (i'm causing traffic already kasi), tsaka lang gumalaw ung shift knob. Then, when I parked, hindi ko na mabunot ung susi. I noticed that the P is not lighted up on the instrument panel, but is lighted up naman on the transmission panel on the shift knob. When I got home, I had to use my spare key to lock the car. After an hour, I checked the everest again, okay na bigla, nakailaw na ulit ung P sa dashboard and I was able to pull out the key. Did several shifts again to see if P would light up, and it works again. What do you think caused this problem? Should I be worried?
maduming brake switch? pag nagalaw galaw lumilinis?
Badtrip din yung ayaw pumihit ng susi. Twice na nangyari sakin yun then once sa sister ko. Kahit anong galaw ko ng manibela ayaw pumihit ng susi. Not sure paano ko napihit susi eventually lol
ive had that issue sa eps ko 3x when my car was 1yr old. never had it since. learning experience
Question lang mga sirs...while engine is on, pag pinipindot nyo yung gear shift button sa shift knob nyo while on P, without shifting it, nawawala yung ilaw sa P sa gauge cluster?...napansin ko kasi sa akin nawawala, pero pag nasa R-N-D naman, kahit pindotin ko hindi naman nawawala yung ilaw...ganun ba talaga?
Ford Endeavour 70-degree near-vertical drop | The Great Ford Endeavour Drive Bangalore - YouTube
need mo push in ng konti yung key before turning para alisin. habit ko na yan na push in before turning off kasi most cars key start switches have a lock where you can not remove the key if you don't push it in before turning to the off position. so hindi ko na pansin kung ganyan ang key start ng everest. i would be surprised though if it is not.
baka kailangan ng picture..😅
how do you upload a photo
Actually pinush ko na din susi before pihitin from Lock all the way to Start and also slightly turning the steering wheel during turning the key pero both ways di nagstart initially. Di ko talaga alam paano ko naresolve. Hehe
Edit: When starting ko lang pala naexperience to. I don't remember kung pati pagpatay naging issue sakin
